1721 Cable Gateway Question
mstaffeld
I'm trying to config a 1721 to work behind my cable modem/"router".
Cable modem has one ethernet port, one public "gateway" IP and 11 other public IPs all on the same subnet.
I'm trying to get the public IPs onto the WIC or at least a few of them? Is this possible?
wic0 = 1enet 10bt ethernet
How do I add multiple publics to the wic and how can I connect to the cable gateway?
Here's the config so far:
CORP_CABLE#show config
Using 1116 out of 29688 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname CORP_CABLE
enable secret 5 nixed
enable password nixed
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip dhcp excluded-address 10.224.24.1
ip dhcp pool internal
network 10.224.24.0 255.255.255.0
default-router 10.244.24.1
dns-server aa.bbb.cc.53
ip audit notify log
ip audit po max-events 100
interface Ethernet0
ip address aa.bb.cc.115 255.255.255.240
ip nat outside
half-duplex
interface FastEthernet0
ip address 10.224.24.1 255.255.255.0
ip nat inside
speed auto
full-duplex
router igrp 1
redistribute connected
network 10.0.0.0
network 71.0.0.0
ip nat inside source list 1 interface Ethernet0 overload
ip classless
no ip http server
ip pim bidir-enable
access-list 1 permit 10.224.0.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
snmp-server community public RO
line con 0
line aux 0
line vty 0 4
password nixed
login
end
Below you can find a link for what you want to do.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093f31.shtml
Please let me know how it goes,
m-haddad
Level 5
Level 5
Didn't get your question to have more IPs on the WIC1ENET? What are you targeting for?
Sorry, I'm basically trying to PAT some ports from outside IPs to inside IPs.
You cann't PAT ports from outside to inside. From outside to inside you have to use static NAT.
Let me know if you need anything further,
