1721 router rebooting automatically
Hi to All
My Router is getting reset/reboot automatically. I am using 1 mbps Internet Lease line from my ISP. i had put console running & got following message....
System Bootstrap, Version 12.2(7r)XM2
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
C1700 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x46b830
Self decompressing the image : ##########################################
Please help me out....IOS version is
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(8)YJ, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
Sanjay Tiwari
Anand Narayana
Level 6
Level 6
Hi Sanjay,
try to get in to ROMMON prompt by pressing ctrl+Break key during the booting process & set the register value as 0x2102 by entering "config-register 0x2102" & restart your router.
if still it doesn't help you out, please let me know abt that.
hope this helps.
rate this post.
Sir
it is showing the same value at sh version command.
may be something else....
thanks
Hi Sanjay,
i think this might be because of improper ground or earthing problem i belive. if you say its not the problem with that, try to reload the IOS with a different one.
