05-10-2007 05:17 AM - edited 03-03-2019 04:55 PM
I have 1751 router which is giving problem at the instance when I power ON it. below log message appears at console and not even coming in ROM monitor.
System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 2001 by cisco Systems, Inc.
Kindly suggest to overcome this problem.
Hardik..
05-10-2007 05:24 AM
I missed to point one more thing.
While doing Clt Break to enter into ROM Monitor below error displays..
*** Software Emulation Exception ***
PC = 0x0, Vector = 0x1000, SP = 0xff002500
Need your assistance.
Hardik..
05-10-2007 11:42 AM
Harware fault
05-11-2007 02:18 AM
Hi Hardik ,
Most of the times it is because of software i.e the image which you are using on router.Better go for IOS uogradation and check the status once you completes the upgradation to newer image.
The below link may be useful for you...
Satish
05-13-2007 11:11 PM
Hi Satish,
Thanks for url; the problem is that I tried to get into ROM monitor and wanted to upload some upgraded IOS. But even ROM is not accessible.
Is there any other way I can get into ROM?
Hardik..
05-14-2007 02:24 AM
As I told you before usually this is hardware fault especially in capacitor - have few cases when capacitor just swell up and need to be replaced.
If you know ccna course you should know if ROMMON can't be accessed that because hardware don't pass POST tests.
