1760 WIC-1Enet subinterface support
scottwilliamson
Level 2
Level 2
Hi All,
Does anyone know if subinterfaces and VLAN encapsulation is supported on a WIC-1Enet card in a 1760? If so which IOS version/feature set is required?
Many Thanks
Scott
Collin Clark
Scott-
It's not supported, you must have a fast ethernet interface.
Hope that helps.
Collin Clark
Scott-
Hope that helps.
Hi Collin,
That's what I was thinking - Thanks for confirming it.
Scott
