1760 with vic 4fxs/did card
diastiago
I have a 1760 router that have two wic cards on slot 0 and 1. And 2 vic 4fxs/did cards on slot 2 and 3.
Problem is that the two vic4fxs/did cards, don't show up on hardware list, there is a green light on the slot 2 and 3 that is OK, the 4 ports on each card are amber, but the router doesn't reconize the card.
Is ther any comand that I have to do to enable the card on the slot, for fxs?
paolo bevilacqua
Most likely you're missing the necessary DSP module to support the voice interface.
Do "show diag" to see what do you have in the router.
For example, a PVDM-256K-8 would be enough for 8 analog voice ports, but not for additional ones.
paolo bevilacqua
Slot 0:
C1760 1FE VE 4SLOT DV Mainboard Port adapter, 12 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 6.0
PCB Serial Number : FOC091716SP
Part Number : 73-7167-06
Board Revision : A0
Fab Version : 04
Product (FRU) Number : CISCO1760
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 16 41 06 00 C1 8B 46 4F 43 30 39 31
0x10: 37 31 36 53 50 82 49 1B FF 06 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Packet Voice DSP Module Slot 0:
Not populated
Packet Voice DSP Module Slot 1:
Not populated
WIC/VIC Slot 0:
Serial 1T
Hardware revision 1.0 Board revision J0
Serial number 0028151857 Part number 800-01514-01
FRU Part Number WIC-1T=
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 02 01 00 01 AD 90 31 50 05 EA 01 00 00 00 00
0x30: 98 00 00 00 11 11 02 01 FF FF FF FF FF FF FF FF
WIC/VIC Slot 1:
Serial 2T (12in1)
Hardware revision 1.0 Board revision B0
Serial number 0031961241 Part number 800-03181-02
FRU Part Number WIC-2T=
Connector type PCI
0x20: 01 12 01 00 01 E7 B0 99 50 0C 6D 02 00 00 00 00
0x30: 58 00 00 00 04 03 26 00 FF FF FF FF FF FF FF FF
VIC Slot 2:
Quad FXS DID Voice Interface Card
Daughter card-Version 4 TLV Cookie Format
Hardware Revision : 3.1
Part Number : 73-6918-02
Board Revision : E0
Deviation Number : 0
Fab Version : 02
PCB Serial Number : FOC11131MR4
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Top Assy. Part Number : 800-17016-02
Connector Type : 01
VIC Slot 3:
Board Revision : E0
Fab Version : 02
PCB Serial Number : FOC11131MSQ
RMA History : 00
Connector Type : 01
So you need a minimum of PVDM-256K-8.
Thanks for the appreciation and good luck!
Thanks for the support
