1800 series router - Trunk port \ L2 Switch question
Hi People,
I'd just like to say right at the beginning,.. I'm a complete n00b at this so please forgive me if these are really easy, stupid questions!!
Currently I have a 4510-48g HP\3COM switch as a core switch for my 4 VLAN network (which I hope to send back cause it doesnt do what I wanted it to do... PBR, which is what I need to route specific VLAN's to specific interfaces on the sonicwall,.. cause sonicwall dont understand trunk or spanning tree,. meh!) This may not happen so I've dug out an old CISCO 1800 sdsl router that has 1 FE0 port and 8 other ports, FE 1-8
The first thing I need to do is get everything to talk to each other. So I plugged the switch into it via its configured trunk port, and configured 4 sub interfaces on the router 1800 and all seemed happy as larry and working.
The problem I have is I dont seem to be able to create sub interfaces on the other ports!?
EXAMPLE:
User Access Verification
Password:
Router>en
Password:
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int fa0.100
Router(config-subif)#exit
Router(config)#itn fa1.100
% Invalid input detected at '^' marker.
Router(config)#
Why is this? I'm struggling to understand why you cant create 4 VLAN's and assign the VLAN the ip instead of the sub interface and then assign the port as a trunk
I dont know if I'm making any sense,.. but bassically,.. on the HP, you create 4 vlans,.. go into each vlan interface and assign the ip you need. then either assign the relevent port interface to access or trunk. if its a trunk, tell it which vlans you want to give access to and you away,... doesnt seem as simple on the cisco,.. can my device do this?
Many thanks in advance,.. Network drawing attached
Shaun
running config:
Router#show run
Building configuration...
Current configuration : 2358 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$XdN.$MwSFWx3ahZIkRxcfmdrqX1
enable password sys1881
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
interface FastEthernet0
no ip address
duplex auto
speed auto
no cdp enable
interface FastEthernet0.1
encapsulation dot1Q 1 native
no snmp trap link-status
no cdp enable
interface FastEthernet0.100
encapsulation dot1Q 100
ip address 172.16.32.252 255.255.224.0
no cdp enable
interface FastEthernet0.200
encapsulation dot1Q 200
ip address 172.16.64.252 255.255.224.0
no cdp enable
interface FastEthernet0.300
encapsulation dot1Q 300
ip address 172.16.96.252 255.255.224.0
no cdp enable
interface FastEthernet0.400
encapsulation dot1Q 400
ip address 172.16.128.252 255.255.224.0
no cdp enable
interface BRI0
no ip address
encapsulation hdlc
shutdown
no cdp enable
interface FastEthernet1
switchport access vlan 100
switchport trunk native vlan 100
vlan-id dot1q 100
  exit-vlan-config
mpls ip
no cdp enable
interface FastEthernet2
shutdown
no cdp enable
interface FastEthernet3
shutdown
no cdp enable
interface FastEthernet4
shutdown
no cdp enable
interface FastEthernet5
shutdown
no cdp enable
interface FastEthernet6
shutdown
no cdp enable
interface FastEthernet7
shutdown
no cdp enable
interface FastEthernet8
shutdown
no cdp enable
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
interface Vlan100
no ip address
vlan-id dot1q 100
  exit-vlan-config
ip classless
no ip http server
no ip http secure-server
access-list 100 permit ip 172.16.32.0 0.0.31.255 host 0.0.0.0
no cdp run
route-map WebTraffic permit 100
match ip address 100
set ip next-hop 172.16.32.254
control-plane
line con 0
line aux 0
line vty 0 4
password sys1881
login
no process cpu extended
no process cpu autoprofile hog
end
Router#
IAN WHITMORE
Level 4
Level 4
The fe0 is a routed port. The others are "switch" ports. So you need to configure it like a switch. You need to create the vlan interaces:
int vlan 100
ip address x.x.x.x
int vlan 200
ip address x.x.x.x
etc.
The you need to go to fe1 for example and do:
#switchport mode trunk
#switchport trunk allowed vlan 100,200,x,x
Your router will probably complain if you use the same vlans as on the subinterfaces of fe0/0 cos of overlapping IP addresses. You will need to remove these first.
Then plug whatever into the f1. You can use your f0 for something else
HTH,
Ian
6 Replies 6
IAN WHITMORE
Level 4
Level 4
int vlan 100
ip address x.x.x.x
int vlan 200
ip address x.x.x.x
etc.
HTH,
Ian
Thanks iwhitmore,
Ok, so I've configured the VLAN interfaces with IP's now,.. looks a lot better,.. switch and firewall can both now see ti with the correct VLAN tagging which is good,.. just gotta try work out the policy routing now!! :S ekkk
Can I ask though,.. what are the sub interfaces for then on FE0 ? if you cant give them the same subnet addresses as the VLAN's,.. are they there to be able to route WAN traffice or secondary networks into the current network
Please forgive my ignorance
new running config:
Current configuration : 2386 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
no ip routing
no ip cef
no ip address
no ip route-cache
duplex auto
speed auto
no cdp enable
no ip route-cache
no cdp enable
no ip route-cache
no cdp enable
no ip route-cache
no cdp enable
no ip route-cache
no cdp enable
no ip route-cache
no cdp enable
interface BRI0
no ip address
encapsulation hdlc
no ip route-cache
shutdown
no cdp enable
no cdp enable
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
interface ATM0
no ip address
no ip route-cache
shutdown
interface Vlan1
no ip route-cache
vlan-id dot1q 1
  exit-vlan-config
interface Vlan100
interface Vlan200
interface Vlan300
interface Vlan400
ip classless
no ip http server
no cdp run
control-plane
line con 0
line aux 0
line vty 0 4
password sys1881
login
no scheduler allocate
end
subinterfaces on a fastethernet routed port are mainly used to do inter vlan routing (router on a stick method) when you have not a L3 switch.
Regards.
Alain.
Please rate the helpful posts.
Ian
I'm trying
Doesnt seem to do much though?
Lol. It does plenty, thanks.
Ian
