04-04-2012 12:09 AM - edited 03-04-2019 03:54 PM
Hi, All
thanks in Advance,
while power off and power com the router went to rmon mode
and its shown like this
how to trouble shoot this problem
System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
Copyright (c) 2007 by cisco Systems, Inc.
C1860 series platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
program load complete, entry point: 0x80015000, size: 0xb700
program load complete, entry point: 0x80020000, size: 0x1dac7e0
Self decompressing the image : ################################################################################################################################################################################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
Bad FIO_0 EC220 vendor device id 0xFFFFFFFF
*** System received a SegV exception ***
signal= 0xb, code= 0x400, context= 0x84636be0
PC = 0x0, Vector = 0x400, SP = 0x84637cec
ID MEMORY_REQ TYPE
rommon 1 >
04-04-2012 03:57 AM
Likely a faulty unit that will require replacement.
In these case, no repair or corrective action possible by the user.
