1811 NAT Problem
umbernaut
(I hope this is the proper place to post a NAT/routing question; if not, please move or let me know)
Some time back, I successfully configured a 2811 to do NAT.  I am having difficulty with an 1811 router using the same config.
Here is the 2811 config that successfully performed NAT from our private to public:
(I've removed everything except the critical information)
interface FastEthernet0/0
ip address [public ip] 255.255.255.240
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex half
speed auto
no mop enabled
ip nat pool [name] [public ip] [public ip] prefix-length 30
ip nat inside source list 1 pool [name] overload
ip route 0.0.0.0 0.0.0.0 [public gateway]
access-list 1 permit 192.168.1.0 0.0.0.255
Here is the 1811 config that will not do NAT:
ip nat outside
speed auto
half-duplex
interface FastEthernet1
ip address 172.16.1.1 255.255.255.224
ip nat inside
speed auto
half-duplex
access-list 1 permit 172.16.1.1 0.0.0.31
IOS version on the 1811 is:
Version 12.3(8r)YH12
Any help/advice is appreciated
9 Replies 9
Edison Ortiz
Can you ping from the router to the internet?
Can you turn debug ip nat and see if there are failures on the translation?
Can you post your NAT translation table?
Thx for the reply.  I am working through the NAT trouble shooter here:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094c32.shtml
Yes. On both my 2811 (doing NAT just fine), I can ping 77.125.65.99 (google.com).  I can do this from the 1811 too.  When I source on both to the inside interface, the 2811 works, the 1811 does not.  I can ping from a switch on int fa1 to the 1811 just fine on the inside.  I can also ping from a laptop in that switch to the int fa1 inside too.  NAT does not work.
I ran:
"debug ip packet 1 det"
"term mon"
And then:
"ping 74.125.65.99 so 172.16.1.1"
Success rate is 0 percent (0/5)
I am also running ping -t from the laptop to 74.125.65.99
Debug shows nothing.
When I run:
"show ip nat translation"
It returns a blank, nothing.
When I run:
"show ip nat statistics"
I get:
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
  FastEthernet0
Inside interfaces:
  FastEthernet1
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 pool internet refcount 0
pool internet: netmask 255.255.255.252
        start [public ip] end [public ip]
        type generic, total addresses 1, allocated 0 (0%), misses 0
Queued Packets: 0
Note: I have removed the public IP here, but it is the same in both places.
Can you change -
to
access-list 1 permit 172.16.1.0 0.0.0.31
Jon
can you do this:
ip nat pool [name] [public ip] [public ip] prefix-length 28
Regards.
Alain.
1st, this is correct now:
"access-list 1 permit 172.16.1.0 0.0.0.31"
Rerunning "show ip nat statistics" I show this:
Total active translations: 68 (0 static, 68 dynamic; 68 extended)
Outside interfaces:
  FastEthernet0
Inside interfaces:
  FastEthernet1
Hits: 994  Misses: 1
CEF Translated packets: 49, CEF Punted packets: 1871
Expired translations: 210
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 pool internet refcount 68
        type generic, total addresses 1, allocated 1 (100%), misses 0
Queued Packets: 0
Running: "show ip nat translation" I get:
Pro Inside global      Inside local       Outside local      Outside global
icmp [public ip]:19   172.16.1.1:19     74.125.65.99:19    74.125.65.99:19
icmp [public ip]:1    172.16.1.2:1      74.125.65.99:1     74.125.65.99:1
udp [public ip]:49579 172.16.1.2:49579  66.18.32.2:53      66.18.32.2:53
udp [public ip]:49579 172.16.1.2:49579  66.18.32.3:53      66.18.32.3:53
[continues with 172.16.1.2 udp traffic; 172.16.1.2 is the laptop running ping -t to google ip]
However, I still get no replies from the 1811 when sourcing a ping from the inside int to the google ip, and it still works good when just pinging from public int.
The laptop also cannot get to google or the google ip from the inside.
After changing the line:
"ip nat pool internet [public ip] [public ip] prefix-length 30"
To:
"ip nat pool internet [public ip] [public ip] prefix-length 28"
I still get 0 success rate when doing:
"ping 74.125.65.99 source 172.16.1.1"
And show about the same:
#show ip nat translation
icmp [public ip]:4    172.16.1.1:4      74.125.65.99:4     74.125.65.99:4
#show ip nat statistics
Total active translations: 1 (0 static, 1 dynamic; 1 extended)
Outside interfaces:
  FastEthernet0
Inside interfaces:
  FastEthernet1
Hits: 15  Misses: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 pool internet refcount 1
pool internet: netmask 255.255.255.240
Queued Packets: 0
Can you post the running config.
Alain.
Here it is.  The VPN is not mapped to any interface.  I have removed anything sensitive:
version 12.4
hostname [hostname]
boot-start-marker
boot-end-marker
enable secret 5 [secret]
enable password [password]
no aaa new-model
resource policy
ip cef
crypto isakmp policy 5
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key [key] address [public ip]
crypto ipsec transform-set [name] esp-3des esp-sha-hmac
crypto map [name] 10 ipsec-isakmp
set peer [public ip]
set transform-set [name]
match address 101
ip nat outside
speed auto
half-duplex
ip address 172.16.31.5 255.255.255.224
ip nat inside
speed auto
half-duplex
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
shutdown
interface Vlan1
no ip address
shutdown
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 [public ip gateway]
no ip http server
no ip http secure-server
access-list 1 permit 172.16.31.0 0.0.0.31
access-list 101 permit ip 172.16.31.0 0.0.0.31 192.168.17.0 0.0.0.255
snmp-server community public RO
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password [password]
login
webvpn context Default_context
ssl authenticate verify all
no inservice
end
what about a PC pinging 8.8.8.8 ?
if it sill doesn't work then do this:
config#int f0
no ip route-cache cef
config#int f1
config# no service-timestamp debug
config#access-list 100 permit icmp any any
config# logging buffered debug
config# logging buffered 100000
#debug ip packet detail 100
#debug ip nat
# sh loggin
and  do your ping from host to 8.8.8.8 and post output
then reenable CEF on both interfaces with ip route-cache cef
Alain.
NAT is working now.  Basically, I did 3 things today:
I changed this:
To this:
ip nat inside source list 110 interface FastEthernet0 overload
access-list 110 permit ip 172.16.31.0 0.0.0.31 any
It still would not work, but I was only trying to ping from the router, sourcing from the private, 172.16.31.5, interface.
I then had a nagging feeling about having the 2 interfaces set at half duplex, so I set both to auto.  Then, I tried pinging google.com from the laptop, and voila! It pinged.
I went back to do:
"ping google.com source 172.16.31.5"
From the router, and it worked too.
I _think_ setting the interfaces from half duplex to auto might have been it, but who knows.
Anyhow, before making those 3 changes, it did not work today, and it did not really work until after changing the duplexing.
