1811 Router as Two Internet load balancer + VPN Server
junshah22
I am trying to configure my Cisco 1811 Router as Internet Load Balancer,
It has 2 WAN ports and 8 L2 Ports,
2 WANs will be using for 2 Internet connection
1 L2 port will be using for Internal connectivity,
I configured vlan1 for inside
One Internet connection has Live IP address and Soft VPN Server should be configured on that interface,
the other WAN interface has DSL connection,
I am having a problem in solving this issue, I should apply NAT on both WAN interfaces,
when two internet connections work fine, my soft VPN dont connects, but as soon I Down that interface,, my VPN connects successfully,
please advise,,
Giuseppe Larosa
Hello Junaid,
post a filtered version of your C1811 configuration changing public ip addresses in private ip addresses or using letters like x.y.z.k
remove also usernames/pwds
only guess is that NAT configuration has to take in account the VPN connection and it has to avoid to translate it.
Also you could face a problem of asymmetrical routing that is a different internet path is used by VPN return traffic and this breakes the VPN.
When only one internet link is working the VPN works too.
Hope to help
Giuseppe
