1841 / 2801 DSL Firmware update
I've been looking and I can really find much info about this, I got a 1841 and 2801 router with ADSL WIC cards and both are synching really low compared to my cheap home router
This leads me to believe I need a firmware update so I got the adsl_alc_20190.bin and loaded it into flash and reloaded my router but its still saying my firmware is using an embedded one.
Can some one please point me into the right direction for a firmware update and what its called?
sh flash:
-#- --length-- -----date/time------ path
1      1000636 Oct 4 2011 05:59:54 +00:00 adsl_alc_20190.bin
sh dsl interface atm0/1/0
ATM0/1/0
Alcatel 20166/20174 chipset information
ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:     0x01                            0x1
Vendor ID:       'ALCB'                          'BDCM'
Vendor Specific: 0x0000                          0x544D
Vendor Country:  0x0F                            0xB5
Capacity Used:   99%                             97%
Noise Margin:     6.0 dB                          8.0 dB
Output Power:    20.0 dBm                        12.0 dBm
Attenuation:     54.0 dB                         31.5 dB
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0x55
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0xA1
Interrupts:      4055 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         embedded
Operation FW:    embedded
FW Version:      13.101
Interleave             Fast    Interleave              Fast
Speed (kbps):          2912                0           800                 0
Cells:                  243                0        102482                 0
Reed-Solomon EC:          2                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Bit Errors:               0                0
BER Valid sec:            0                0
BER Invalid sec:          0                0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 6 8 9 A B B B C C
010: C C C C C C C C C C C C B B 0 0
020: 0 0 0 0 0 0 5 6 6 7 7 8 8 8 9 9
030: 9 9 9 9 9 9 9 8 8 8 7 7 8 2 7 7
040: 7 7 6 6 6 6 6 5 5 5 5 5 5 5 5 5
bump so im trying to find a firmware update for:
Alcatel 20166/20174
Can any one help?
The firmware you've been trying is for a different ADSL chipset and HWIC so that's why it won't load.
It looks like you've got a WIC-1ADSL-I-DG or WIC-1ADSL-DG and, according to
http://www.cisco.com/en/US/prod/collateral/routers/ps221/prod_bulletin0900aecd801d5c4c.html, firmware
13.101, which you're running, seems like the latest.
Thanks for clearing that up for me , i am now synching with a Billion Router and ive bridged it to my 1841 so i can get better sync speeds
