1841 crash after configured ip nat
worapat
I found some problems when I configured ip nat inside at FastEthernet0/1. Router 1841 will reboot and cannot do anything. After I console this router, I found many crash files, like this;
---- crashinfo_20051201-102249 ----
*Dec 1 10:22:45.391: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Dec 1 10:22:45.391: %LINK-3-UPDOWN: Interface Serial0/1/0, changed state to down
*Dec 1 10:22:46.391: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to down
*Dec 1 10:22:47.319: %SYS-6-LOGGERSTART: Logger process startedCMD: 'version 12.3' 10:22:47 UTC Thu Dec 1 2005
CMD: 'service timestamps debug datetime localtime' 10:22:47 UTC Thu Dec 1 2005
CMD: 'service timestamps log datetime localtime' 10:22:47 UTC Thu Dec 1 2005
*Dec 1 17:22:47: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:22:47 UTC Thu Dec 1 2005 to 17:22:47 THAI Thu Dec 1 2005, configured from console by console.CMD: 'mmi polling-interval 60' 17:22:47 THAI Thu Dec 1 2005
CMD: 'no mmi auto-configure' 17:22:47 THAI Thu Dec 1 2005
CMD: 'no mmi pvc' 17:22:47 THAI Thu Dec 1 2005
CMD: 'mmi snmp-timeout 180' 17:22:47 THAI Thu Dec 1 2005
CMD: 'no aaa new-model' 17:22:47 THAI Thu Dec 1 2005
CMD: 'ip subnet-zero' 17:22:47 THAI Thu Dec 1 2005
CMD: 'ip cef' 17:22:47 THAI Thu Dec 1 2005
CMD: 'interface FastEthernet0/1' 17:22:47 THAI Thu Dec 1 2005
CMD: ' ip nat inside' 17:22:47 THAI Thu Dec 1 2005
Every crash file will be like this. It will finish at "ip nat inside".
IOS version: c1841-spservicesk9-mz.123-8.YG3.bin
Anyone know about this problem?
Ps. Now, I upgrade to a new version c1841-spservicesk9-mz.123-14.T5.bin, it works but I would like to know that what the problem is?
Thank you very much :-)
spremkumar
Level 9
Level 9
I did try finding out any error or bug related to the code which u have mentioned out here and couldnt find anything inline with that code.
Since it got solved on its own after ur upgrade to the other version would suggest to escalate this to the TAC team ,so they can find out the root cause and list the bug/error for this code..
regds
