IOS memory Requirements precisions
oattoumani
I want to upgrade my router in IOS 12.3;at the upgrade planner it is indicate 16MB flash minimum and the size( next URL) it is indicate 16,300MB.
The upgrade abort with 16Mb of flash with the message "not enough space".
What précisions are the memory requirements at the CCO ? Is it a error on the upgrade planner..
Thanks for your help.
Omar
6 Replies 6
spremkumar
Level 9
Level 9
Can u post out the url and also the IOS naming details over here ??
from my personal exp we do follow the software advisor and other tools here to get reqd ios features onto our box...
and i feel thats the exp with other peopl too ..
regds
The file size mentioned over there is in bytes once you get converted to Mega bytes it will be able to fit into the 16MB flash as presricbed in the first link.
I would suggest to post the show version and show flash output of your router here..
regds
hello
here is the show version:
show version ------------------
IOS (tm) C2600 Software (C2600-IO3-M), Version 12.3(15b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 25-Aug-05 13:39 by ssearch
Image text-base: 0x80008098, data-base: 0x80D548D4
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Router uptime is 17 minutes
System image file is "flash:c2600-io3-mz.123-15b.bin"
cisco 2621 (MPC860) processor (revision 0x102) with 58368K/7168K bytes of memory.
Processor board ID JAB04130629 (1105519758)
M860 processor: part number 0, mask 49
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
2 Serial(sync/async) network interface(s)
1 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
sincerly
Are you trying to load up this new image after erasing the earlier one or doing normal clean upload ??
if u do it without erasing the older ios which is lying in ther i dont think u will be able to load it up succesfully.
But do remember to backup the older ios and erase it and try loading the new ios file..
also u didnt post out the show flash o/p here.
regds
hi,
I want to upgrade in other feature in 12.3.15B,
here is the upgrade trace:
Router#dir flash:
Directory of flash:/
No files in directory
16252924 bytes total (16252924 bytes free)
Router#copy tftp: flash:
Address or name of remote host [172.28.5.44]?
Source filename [c2600-ik9o3s3-mz.123-15b.bin]?
Destination filename [c2600-ik9o3s3-mz.123-15b.bin]?
Accessing tftp://172.28.5.44/c2600-ik9o3s3-mz.123-15b.bin...
Erase flash: before copying? [confirm]
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ...erasedee
Erase of flash: complete
Loading c2600-ik9o3s3-mz.123-15b.bin from 172.28.5.44 (via FastEthernet0/0): !
%Error copying tftp://172.28.5.44/c2600-ik9o3s3-mz.123-15b.bin (Not enough space on device)
I am thing that I must upgrade the flash memory but I want that CCO change the memory requirement on this image .
sincerly
Omar
