1841 hangs...
madathilsiva
Hi All,
Recently i upgraded my 1841 router with 1HWIC card  and using 4 mbps connection. After that my route geting hanged and after restart its start working.
its happening daily once. What may be the issue ? please help
IOS details :
Cisco IOS Software, 1841 Software (C1841-IPBASEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Memory usege :
Directory of flash:/
    1  -rw-        2746  Nov 13 2008 09:39:24 +05:30  sdmconfig-18xx.cfg
    2  -rw-      931840  Nov 13 2008 09:39:46 +05:30  es.tar
    3  -rw-     1505280  Nov 13 2008 09:40:10 +05:30  common.tar
    4  -rw-        1038  Nov 13 2008 09:40:32 +05:30  home.shtml
    5  -rw-      112640  Nov 13 2008 09:40:48 +05:30  home.tar
    6  -rw-    27542552   Apr 1 2011 23:17:52 +05:30  c1841-ipbasek9-mz.124-24.T.bin
32071680 bytes total (1961984 bytes free)
1961984 bytes available (30109696 bytes used)
regards
SP
George Horton
When you say the router hangs. I am assuming that you get no throughput.
Are you able to connect to a VTY line (telnet, ssh)? Or get a response from the console?
As the current solution is to reset the router you are loosing all logs, setting up a syslog server may help identify what happens just prior to the crash.
Rozsa Illes
Hi SP,
As George mentioned, we need to figure out if the hang affects only transmit traffic or if we have lost console access to the router as well.
If we have console access, I would recommend checking: CPU, memory, buffers, interfaces and if any errors are logged.
If we have no console access either, it will be more tricky but there is a procedure to get information:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a0080106fd7.shtml
If it turns out that we do not even have console access, you might consider upgrading the IOS because it is usually a software failure.
Warm Regards,
Rose
Hi George/Rozsa
Thanks for your valuble replay..
I am waiting for more update on this from my client.
i got the update that client can ping the router but internet is not working .
But after restart the internet started working.
SP
paolo bevilacqua
Update IOS.
