Bookmark
Subscribe
355
1841 ISR electronic components
StefanHeymans
A couple of days ago my 1841 ISR blew up. As I am a CCNA student (certifying soon) and on a low budget, I would try to repair it, so I can establish a VPN with another 1841. The defective components are C388 and C389. Does anyone know where I can find these? I have no idea what they are, but they don't seem IC's to me...
A Google search on the numbers "22-25L X4" didn't bring any useable information.
Thanks in advance!
Stefan
Reza Sharifi
Even if you can find the parts, the cost of replacing these parts will most likely be more than buying another one. The 1841 is end of life and support and you can probably find it on ebay for a very reasonable price.
here is one:
http://www.ebay.com/bhp/cisco-1841
