1841 - Ospf Routing
Andreas Sinn
Hello!
I have the following situation:
I have 4 1841 routers configured for load balancing and failover:
                 net 1
router1 ------------------- router10
router2 ------------------- router11
                net 2
I want to configure the ospf to make load sharing over both connections. How does the configuration look?
Andreas
mrdogantr
Hi Andreas,
You can use equal cost for loadsharing or use unequal cost for failover config.
for example;
interface fastethernet0/0
ip ospf cost 3000
hth
Muammer
I know this, but I want to know how i configure the routes from net 1 and net 2 over the
"router ospf" command.
thanks
Andreas
You can put all interfaces in same area, eg  network 0.0.0.0 255.255.255.255 a 0
or you can put specific interfaces with  eg network 192.168.10.1 0.0.0.0 a 0 192.168.10.1 being ip address of interface
you can also do the same under interface instead of routing process with command ip ospf a 0
Where are net1 and net2, what is there between your routers?  ethernet with switches, serial links?
Regards.
Alain.
