1841 Router behind cable modem not routing
Kevin Pisarsky
I KNOW there has to be a ton of examples but I'm unable to find them.  The router is behind a cable modem and it gets DHCP from that.  I can see the router get the DHCP but for some reason it won't route or is not subnetted properly.   Maybe I've just plain screwed it up: for example, it seems like there are two DHCP addresses it gets.
__________________________________________________________________________________________________-
*Sep 30 19:24:49.783: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0/1 assigned DHCP address 192.168.100.10, mask 255.255.255.0, hostname hillside.lan
*Sep 30 19:25:08.895: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0/1 assigned DHCP address 24.165.208.144, mask 255.255.254.0, hostname hillside.lan
hillside.lan#show ip interface brief
Interface                  IP-Address      OK? Method Status                Prot                                                ocol
FastEthernet0/0            192.168.1.1     YES NVRAM  up                    up
FastEthernet0/1            24.165.208.144  YES DHCP   up                    up
Serial0/0/0                unassigned      YES NVRAM  administratively down down
NVI0                       192.168.1.1     YES unset  up                    up
hillside.lan#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 24.165.208.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 24.165.208.1
      24.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        24.165.208.0/23 is directly connected, FastEthernet0/1
L        24.165.208.144/32 is directly connected, FastEthernet0/1
      142.254.0.0/32 is subnetted, 1 subnets
S        142.254.151.209 [254/0] via 24.165.208.1, FastEthernet0/1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, FastEthernet0/0
L        192.168.1.1/32 is directly connected, FastEthernet0/0
Here is the config from the router:
version 15.1
boot-start-marker
boot-end-marker
enable password XXXXXX
no aaa new-model
dot11 syslog
no ip source-route
ip cef
ip domain name hillside.lan
ip name-server 8.8.8.8
ip name-server 8.8.4.4
license udi pid CISCO1841 sn XXXXXX
username XXXXX password 0 15 XXXXXX
redundancy
interface FastEthernet0/0
 description LAN_LINK
 ip nat inside
 ip virtual-reassembly in
 no ip route-cache
 speed auto
 full-duplex
 no mop enabled
interface FastEthernet0/1
 description WAN_LINK
 ip address dhcp
 ip nat outside
 no ip route-cache cef
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 102 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
 password XXXXXX
 login
line aux 0
line vty 0 4
 login local
 transport input all
line vty 5 15
 password XXXXXXX
 login
 transport input all
scheduler allocate 20000 1000
end
And here are the statistics from show ip traffic:
hillside.lan#show ip traffic
IP statistics:
  Rcvd:  6233 total, 5544 local destination
         0 format errors, 0 checksum errors, 0 bad hop count
         0 unknown protocol, 1 not a gateway
         0 security failures, 0 bad options, 0 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
         0 other
  Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
         0 fragmented, 0 fragments, 0 couldn't fragment
  Bcast: 5451 received, 14 sent
  Mcast: 0 received, 0 sent
  Sent:  182 generated, 533 forwarded
  Drop:  22 encapsulation failed, 0 unresolved, 0 no adjacency
         129 no route, 0 unicast RPF, 0 forced drop
         0 options denied
  Drop:  0 packets with source IP address zero
  Drop:  0 packets with internal loop back IP address
         11 physical broadcast
  Reinj: 0 in input feature path, 0 in output feature path
ICMP statistics:
  Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 1 unreachable
        0 echo, 0 echo reply, 0 mask requests, 0 mask replies, 0 quench
        0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
        0 irdp solicitations, 0 irdp advertisements
        0 time exceeded, 0 info replies
  Sent: 0 redirects, 125 unreachable, 0 echo, 0 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp replies
        0 info reply, 0 time exceeded, 0 parameter problem
TCP statistics:
  Rcvd: 48 total, 0 checksum errors, 1 no port
  Sent: 47 total
BGP statistics:
  Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
        0 keepalives, 0 route-refresh, 0 unrecognized
  Sent: 0 total, 0 opens, 0 notifications, 0 updates
EIGRP-IPv4 statistics:
  Rcvd: 0 total
  Sent: 0 total
PIMv2 statistics: Sent/Received
  Total: 0/0, 0 checksum errors, 0 format errors
  Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0,  Hellos: 0/0
  Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
  Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
  Queue drops: 0
  State-Refresh: 0/0
IGMP statistics: Sent/Received
  Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
  Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
  DVMRP: 0/0, PIM: 0/0
  Queue drops: 0
UDP statistics:
  Rcvd: 5495 total, 0 checksum errors, 5413 no port
  Sent: 14 total, 0 forwarded broadcasts
OSPF statistics:
  Last clearing of OSPF traffic counters never
  Rcvd: 0 total, 0 checksum errors
        0 hello, 0 database desc, 0 link state req
        0 link state updates, 0 link state acks
  Sent: 0 total
ARP statistics:
  Rcvd: 4550 requests, 49 replies, 0 reverse, 0 other
  Sent: 14 requests, 67 replies (0 proxy), 0 reverse
  Drop due to input queue full: 0
Jon Marshall
You are referencing the wrong interface in your NAT statement ie. you should be referencing the interface with "ip nat outside" on it not "ip nat inside".
Jon
5 Replies 5
Jon Marshall
Jon
Is this the reference you are talking about?
So I would reference it as:
ip nat outside source list 102 interface FastEthernet0/0 overload
Is that the only mistake I've made?
It is the reference but I didn't explain it very well ie. it should be -
"ip nat inside source list 102 interface fa0/1 overload"
note the actual interface being used.
Can't see anything else obviously wrong assuming your clients have a DNS server in their configuration for resolving internet addresses.
Jon
Yes, I have an internal DNS and DHCP server.  Sorry, I didn't think to mention that.  I have to disconnect to try that config change.
Thank you, Jon.
