1841 router error
jonesl1
We have an 1841 router (version 12.4(25) IOS)and recently it has been kicking out the following errors:
.Jun  8 05:19:00: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=634554D0,
count=FFFFF15B -Traceback= 0x609670D0 0x602B2ADC 0x6001D054 0x61C365D0 0x61C3C9C
0 0x61C39F7C 0x61C3A260 0x60048414
.Jun  8 05:29:56: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=634554D0,
count=FFFFFB29 -Traceback= 0x609670D0 0x602B2ADC 0x6001D054 0x61C365D0 0x61C3C9C
Can anyone explain what this is or what I need to do?  It obviously don't look good.
Giuseppe Larosa
Hello Jones,
traceback = software bug just to start
the error message decoder about %SYS-2-BADSHARE says:
%SYS-2-BADSHARE:
Bad refcount in [chars], ptr=[hex], count=[hex]
A reference count is used to track the usage of many data  structures. A function  increments the count when it begins to use a structure and decrements it  when it finishes. When the  count becomes zero, the data structure is freed. This message indicates  that when the count was  accessed, it was found to be negative which means that the data  structure will not be freed until the  system is reloaded.
Recommended Action: If this message recurs, copy the message exactly as it appears on  the console  or in the system log. Research and attempt to resolve the issue using  the tools and utilities provided  at
http://www.cisco.com/tac.  With some messages, these tools and utilities will supply clarifying  information. Also perform a search of the Bug Toolkit
http://www.cisco.com/pcgi-bin/Support/Bugtool/home.pl.  If you still require assistance, open a case  with the Technical Assistance Center via the Internet
http://tools.cisco.com/ServiceRequestTool/create,  or contact your Cisco technical support  representative and provide the representative with the gathered  information. Include the stack trace.
means that a packet that is held in a buffer for process switching at the moment to be examined by main cpu has been "lost" in memory
This is cleary a software bug.
Hope to help
Giuseppe
podhillo
CSCsz84764
Router crash by memory corruption in I/O 12.4(25)
Symptom: Router crashing by memory corruption in I/O region (corrupted redzone) AND reporting the crash due to Unexpected exception to CPUvector 700. Conditions: Affected router is a 1700 series. Affected software is 12.4(25). Workaround: Admin shut the unused ports prevents the crash from happening.
