04-22-2010 05:44 AM - edited 03-04-2019 08:14 AM
To the Forum
I have been tasked with developing an efficient and summarizable IP address scheme for one of my clients. Within the scheme, I want to have efficient use of IP address space.
The clients current configuration is basically a hodge podge of different IP addresses and networks all thrown together.
There are 4 Main sites that the company uses. My idea was to summarize at these 4 MPLS connections for all of the networks at each site.
I am attaching the spreadsheet I have developed and was hoping one of you with IP address design experience would evaluate my plan as it is layed out and let me know if this would work.
My main question centers around the /19 mask I am using at the main Site vs. the /20 and /21 masks I am using at the other sites. Will the networks be routable based upon what I have layed out?
Please take a look and let me know
Thank You
Kevin
| NEW | ||||
| NET | LOCATION | USE | ||
| Glen Allen /19 Block | ||||
| 192.168. | 0 | /19 | Glen Allen | |
| 192.168. | 0 | /24 | ||
| 192.168. | 1 | /24 | Servers - includes Servers, VM Hardware and FTP | |
| 192.168. | 2 | /24 | Firewall Transit | |
| 192.168. | 3 | /24 | SCADA A | |
| 192.168. | 4 | /24 | SCADA B | |
| 192.168. | 5 | /24 | SAN | |
| 192.168. | 6 | /24 | Loopbacks | |
| 192.168. | 7 | /24 | Users | |
| 192.168. | 8 | /24 | DMZ | |
| 192.168. | 9 | /24 | ||
| 192.168. | 10 | /24 | GA Frame | |
| 10.0-10.252 | /30's | Member Sites | ||
| 192.168. | 11 | /24 | Wireless | |
| 192.168. | 12 | /24 | Diesel Generators | |
| 192.168. | 13 | /24 | ||
| 192.168. | 14 | /24 | ISDN | |
| 192.168. | 15 | /24 | WAN | |
| 192.168. | 16 - 31 | /24 | Reserved for Future | |
| Louisa /20 Block | ||||
| 192.168 | 32 | /20 | Louisa | |
| 192.168. | 32 | /24 | Servers - includes Servers, VM Hardware and FTP | |
| 192.168. | 33 | /24 | Users | |
| 192.168. | 34 | /24 | SAN | |
| 192.168. | 35 | /24 | LO Frame | |
| 35.0 - 35.252 | /30's | |||
| 192.168. | 36 | /24 | WAN | |
| 192.168. | 37 | /24 | Transient Networks (Former 172.16.132.9/30, 172.16.132.3/29) | |
| /27's | ||||
| 192.168. | 38 | /24 | Loopbacks | |
| 192.168. | 39 | /24 | SCADA A | |
| 192.168. | 40 | /24 | SCADA B | |
| 192.168. | 41 - 47 | /24 | Reserved for Future | |
| Marsh Run /20 Block | ||||
| 192.168 | 48 | /21 | Marsh Run | |
| 192.168. | 48 | /24 | ||
| 192.168. | 49 | /24 | MPLS net | |
| 192.168. | 50 | /24 | SCADA | |
| 192.168. | 51 | /24 | Dominion Va Power | |
| 192.168. | 52 | /24 | PJM | |
| 192.168. | 53 | /24 | user | |
| 192.168. | 54 | /32 | loopbacks | |
| 192.168. | 55 | /24 | DMZ | |
| 192.168. | 56 | /24 | WiFi | |
| 192.168. | 57 - 63 | /24 | Reserved for Future | |
| Rock Springs /20 Block | ||||
| 192.168 | 64 | /21 | Rock Springs | |
| 192.168. | 64 | /24 | user | |
| 192.168. | 65 | /24 | SCADA | |
| 192.168. | 66 | /24 | DMZ | |
| 192.168. | 67 | /24 | WiFi | |
| 192.168. | 68 | /24 | ||
| 192.168. | 69 | /32 | Loopbacks | |
| 192.168. | 70-79 | /24 | Reserved for Future | |
04-22-2010 06:12 AM
Hello Kevin,
your address plan and the summary routes are correct and should not create routing problems.
only note: if you dedicate a /24 block for Loopbacks you should indicate it as a /24, then as a note you can add that you will further subnet it using /32 as you did before for 192.168.10.0/24
Hope to help
Giuseppe
04-22-2010 07:44 AM
thanks for the quick reply
Giuseppe
I am to pitch this to Management today. I will let you know what they say.
Kevin
04-22-2010 06:18 AM
Kevin
Looks fine. Key things to bear in mind when doing this sort of thing are -
1) always leave adequate room for growth within the address space for each site
2) loopbacks etc. used for management should still fall within the site allocated range(s)
3) always summarise as much as possible between sites.
With a new addressing scheme such as the one you are doing 1) + 3) means you should only have to advertise one IP block from each site.
Jon
04-22-2010 08:04 AM
Thanks for your response Jon. Hope you are well.
Kevin
06-09-2010 08:13 AM
Jon
The client asked me to develop a Class B range for consideration in addtion to the formerly proposed Class C range.
I came up with the following and wanted you to look it over and make sure that it is summarizable at each route point (location - glen Allen, Louisa, Marsh Run, Rock Springs).
Thanks for your input.
Kevin
| NEW | ||||
| Glen Allen /16 Block | ||||
| 172.16. | 0 | /16 | Glen Allen | |
| 172.16. | 0 | /24 | ||
| 172.16. | 1 | /24 | Servers - includes Servers, VM Hardware and FTP | |
| 172.16. | 2 | /24 | Firewall Transit | |
| 172.16. | 3 | /24 | SCADA A | |
| 172.16. | 4 | /24 | SCADA B | |
| 172.16. | 5 | /24 | SAN | |
| 172.16. | 6 | /24 | Loopbacks | |
| 172.16. | 7 | /24 | Users | |
| 172.16. | 8 | /24 | DMZ | |
| 172.16. | 9 | /24 | ||
| 172.16. | 10 | /24 | GA Frame | |
| 172.16. | 11 | /24 | Wireless | |
| 172.16. | 12 | /24 | Diesel Generators | |
| 172.16. | 13 | /24 | ||
| 172.16. | 14 | /24 | ISDN | |
| 172.16. | 15 | /24 | WAN | |
| 172.16. | 16 | /24 | VPN networks | |
| /27's or /28's as necessary | ||||
| 17 | VPN networks | |||
| 18-255 | Reserved for Future | |||
| Louisa /16 Block | ||||
| 172.17 | 0 | /16 | Louisa | |
| 172.17. | 1 | /24 | Servers - includes Servers, VM Hardware and FTP | |
| 172.17. | 2 | /24 | Users | |
| 3 | /24 | Wireless | ||
| 172.17. | 4 | /24 | SAN | |
| 172.17. | 5 | /24 | LO Frame | |
| 6 | /30's | |||
| 172.17. | 7 | /24 | WAN | |
| 172.17. | 8 | /24 | Transient Networks (Former 172.16.132.9/30, 172.16.132.3/29) | |
| 9 | /27's | |||
| 172.17. | 10 | /24 | Loopbacks | |
| 172.17. | 11 | /24 | SCADA A | |
| 172.17. | 12 | /24 | SCADA B | |
| 172.17. | 13 | /24 | VPN | |
| 172.17. | 14 | /24 | DMZ | |
| 172.17. | 15-255 | /24 | Reserved for Future | |
| Marsh Run /17 Block | ||||
| 172.18 | 0 | /17 | Marsh Run | |
| 172.18. | 1 | /24 | ||
| 172.18. | 2 | /24 | MPLS net | |
| 172.18. | 3 | /24 | SCADA | |
| 172.18. | 4 | /24 | Dominion Va Power | |
| 172.18. | 5 | /24 | PJM | |
| 172.18. | 6 | /24 | user | |
| 7 | /24 | Wireless | ||
| 172.18. | 8 | /24 | loopbacks | |
| 172.18. | 9 | /24 | DMZ | |
| 172.18. | 10 | /24 | ||
| 172.18. | 11 | /24 | VPN - DAHS | |
| 172.18. | 12-127 | /24 | Reserved for Future | |
| Rock Springs /17 Block | ||||
| 172.18 | 128 | /17 | Rock Springs | |
| 172.18. | 129 | /24 | user | |
| 172.18. | 130 | /24 | SCADA | |
| 172.18. | 131 | /24 | DMZ | |
| 172.18. | 132 | /24 | Loopbacks | |
| 172.18. | 133-255 | /24 | Reserved for Future | |
| RESERVED | ||||
| 172.19.1.0 | - | 172.31.254.255 | ||
