1841, Routing between 2 interfaces for ADSL connection
infinitemonkee
hi all
trying to setup a 1841 with a adsl wic on board to handle the office traffic and a VPN tunnel
the adsl interface works, i can ping out to the internet from the router and i can ping the interface from the internet
the ethernet interfaces also works as i can ping the laptop from the router and the laptop can ping the ethernet interface
but i am unable to ping throught the router.  i have my nat in place and a static route to the dialer interface.
anyone got any ideas?
no access-list 1
access-list 1 permit 192.168.0.0 0.0.0.255
Alain
5 Replies 5
cadet alain
Could you delete your duplicate post.
Concerning your problem can you post your running config.
Alain
Hi Morgan,
I am also using 2 x ATM interface with cisco 1841 router and facing half of the original bandwidth, if I unplugged one onterface, bandwidth on other link will be doubled.
did you see any issue using 2 ATM interface ?
Please its an urgent query.
infinitemonkee
Router#sh run
Building configuration...
Current configuration : 1971 bytes
! Last configuration change at 17:36:27 UTC Tue Sep 10 2013
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.0.1 192.168.0.100
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp pool Ethnet-LAN
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 194.72.0.114 62.6.40.178
ip dhcp pool LAN-NO-VPN
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1 255.255.255.0
   dns-server 8.8.8.8
   lease infinite
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
license udi pid CISCO1841 sn FCZ122372H9
interface FastEthernet0/0
description Ethnet LAN
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
description Ethnet LAN no VPN
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
pvc 0/38
  pppoe-client dial-pool-number 1
interface ATM0/1/0
no ip address
shutdown
interface Dialer1
mtu 1458
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname b.lieberman@hg24.btclick.com
ppp chap password 0 pa55word
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool BT-Statics 217.34.96.137 217.34.96.141 netmask 255.255.255.248
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 ATM0/0/0
ip route 0.0.0.0 0.0.0.0 ATM0/1/0
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.0.1
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
no access-list 1
Alain
Perfect.
Just a simple thing to miss. Thanks for that.
