VRF lite troubleshooting
teymur azimov
Hi Dears,
I attache my network topology  and configuration here. i configurate vrf lite in cisco 6500 series switch. router and asa connected to cisco 6500 switch.
i want to do ping from router to asa inside subnet and also ping from asa to router inside subnet. i configurate eigrp dynamic routing in router and asa,coresw.
the problem is.  Ping is not going from router to asa inside network and same thing in asa. is this problem in import/export? May i change some config in my configuration?
configuration in core switch:
ip vrf asa
rd 65515:1
route-target export 65515:1
route-target import 65515:100
route-target import 65515:101
ip vrf mapas
rd 65515:100
route-target export 65515:100
ip vrf mapas1
rd 65515:101
route-target export 65515:101
interface GigabitEthernet1/1/2
description connecte_to_ASA_outside
switchport
switchport access vlan 1000
switchport mode access
speed 100
interface GigabitEthernet1/1/3
description connect-to-Router-outside
switchport
interface Vlan340
ip vrf forwarding mapas
ip address 10.30.40.254 255.255.255.0
interface Vlan344
ip vrf forwarding mapas1
ip address 10.30.44.254 255.255.255.0
interface Vlan1000
ip vrf forwarding asa
ip address 10.100.100.254 255.255.255.0
router eigrp 2008
address-family ipv4 vrf mapas
  redistribute connected
  redistribute bgp 65515 metric 128 10000 255 1 1500
  network 10.30.40.0 0.0.0.255
  autonomous-system 2008
exit-address-family
address-family ipv4 vrf mapas1
  network 10.30.44.0 0.0.0.255
exit-address-family
address-family ipv4 vrf asa
  network 10.100.100.0 0.0.0.255
exit-address-family
router bgp 65515
bgp log-neighbor-changes
redistribute eigrp 2008
exit-address-family
exit-address-family
exit-address-family
CORE-VSS#show ip bgp vpnv4 all
BGP table version is 31, local router ID is 172.31.40.105
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 65515:1 (default for vrf asa)
*>  10.30.40.0/24    0.0.0.0                  0         32768 ?
*>  10.30.44.0/24    0.0.0.0                  0         32768 ?
*>  10.100.100.0/24  0.0.0.0                  0         32768 ?
Route Distinguisher: 65515:100 (default for vrf mapas)
Route Distinguisher: 65515:101 (default for vrf mapas1)
Route Distinguisher: 65515:102 (default for vrf mapa2)
Route Distinguisher: 65515:105 (default for vrf brs)
Route Distinguisher: 65515:110 (default for vrf wlan1)
*>  10.30.3.0/24     0.0.0.0                  0         32768 ?
CORE-VSS#
CORE-VSS#show ip route vrf mapas
Routing Table: mapas
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
C        10.30.40.0/24 is directly connected, Vlan340
L        10.30.40.254/32 is directly connected, Vlan340
B        10.30.44.0/24 is directly connected (mapas1), 00:10:33, Vlan344
L        10.30.44.254/32 is directly connected, Vlan344
B        10.100.100.0/24 is directly connected (asa), 00:10:35, Vlan1000
L        10.100.100.254/32 is directly connected, Vlan1000
CORE-VSS#
CORE-VSS#show ip route vrf mapas1
Routing Table: mapas1
B        10.30.40.0/24 is directly connected (mapas), 00:13:20, Vlan340
C        10.30.44.0/24 is directly connected, Vlan344
B        10.100.100.0/24 is directly connected (asa), 00:12:47, Vlan1000
CORE-VSS#
Router configuration:
Router# sh runn
Building configuration...
Current configuration : 1043 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
no dspfarm
username risk privilege 15 password 0 cisco
interface FastEthernet0/0
description outside
ip address 10.100.100.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description inside
ip address 10.30.40.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
router eigrp 2008
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
Router#sho ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
     10.0.0.0/24 is subnetted, 3 subnets
C       10.100.100.0 is directly connected, FastEthernet0/0
D       10.30.44.0 [90/28416] via 10.100.100.254, 00:11:48, FastEthernet0/0
                   [90/28416] via 10.100.100.2, 00:11:48, FastEthernet0/0
                   [90/28416] via 10.30.40.254, 00:11:48, FastEthernet0/1
C       10.30.40.0 is directly connected, FastEthern
ASA configuration:
ciscoasa# sh runn
: Saved
ASA Version 8.6(1)2
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 10.100.100.2 255.255.255.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.30.44.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/7
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
interface GigabitEthernet1/0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/5
shutdown
no nameif
no security-level
no ip address
boot system disk0:/asa861-2-smp-k8.bin
ftp mode passive
access-list 101 extended permit ip any any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-66114.bin
no asdm history enable
arp timeout 14400
access-group 101 in interface outside
router eigrp 2008
no auto-summary
network 10.30.44.0 255.255.255.0
network 10.100.100.0 255.255.255.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
tls-proxy maximum-session 1000
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:d41d8cd98f00b204e9800998ecf8427e
: end
ciscoasa# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
C    10.100.100.0 255.255.255.0 is directly connected, outside
C    10.30.44.0 255.255.255.0 is directly connected, inside
D    10.30.40.0 255.255.255.0 [90/3072] via 10.100.100.254, 0:10:59, outside
ciscoasa#
Thanks.
0 Replies 0
