1841 SHDSL configuration
romeoval1
I am trying to configure an 1841 router with an SHDSL modem card. The ISP has given us the routable IP address, subnet mask and gateway, but nothing else. They say we should be able to create a bridged connection from the SHDSL modem to fe 0/1.
In order to set this up wont we need a username and password to input into the modem configuration? Is it is possible to bridge the connection between the modem and the ethernet interface.
Any help would be appreciated, I have searched the web looking for help with this and am finding it mighty hard to find. I have configured pppoe connections before on 827 routers, is it similiar to this?
Matt
paolo bevilacqua
According to your description, ISP is running "bridged 1483" encapsulation. Please confirm with them, if that is the case, configure:
int atm0.1 point-to-point
pvc 8/35 <-- or whatever else
bridge-group 1
int bvi 1
ip address 1.2.3.4 255.255.255.240 <-- As given by ISP
ip nat inside
int vlan1
ip address Y.Y.Y.1 255.255.255.0
ip nat outside
bridge irb
bridge 1 route ip
bridge 1 protocol ieee
ip route 0.0.0.0 0.0.0.0 x.x.x.x <--- default GW as per ISP
ip nat inside source list 1 interface atm0.1 overload
access-list 1
permit ip Y.Y.Y.0 0.0.0.255
