1841 Static IP Configuration
tarekesmail
I have issue after configuring the static IP here's the IP subnet from ISP
IPs: 51.39.10.42 - 51.39.10.46
Netmask : 255.255.255.248
Gateway : 51.39.10.41
and here's my router configuration
Building configuration...
Current configuration : 1419 bytes
! Last configuration change at 01:43:51 UTC Tue Feb 13 2018
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FTX115220A2
redundancy
controller Cellular 0/0
controller Cellular 0/1
interface FastEthernet0/0
 ip address 51.39.10.44 255.255.255.248
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip default-gateway 51.39.10.41
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/0 overload
ip default-network 51.39.10.41
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
logging esm config
access-list 10 permit any
control-plane
line con 0
line aux 0
line 0/0/0 0/0/1
 no exec
line 0/1/0 0/1/1
 no exec
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
i can't ping outside to 8.8.8.8, but when i gave the IP to any PC connected to the ISP router it's working without any issues also i can ping to gateway from 1841 Router
"no access-list 10"
"access-list 10 permit 192.168.2.0 0.0.0.255"
"no ip default-gateway 50.39.10.41"
"no ip route 0.0.0.0 0.0.0.0 fa0/0"
"ip route 0.0.0.0 0.0.0.0 50.39.10.41"
Jon
7 Replies 7
Julio E. Moisa
At simple sight there are 2 problems:
1) The NAT settings are not completed, so you must add:
Interface fa0/0
description TO-ISP
ip nat outside
interface fa0/1
description TO-MY-NETWORK
ip nat inside
2) You need to define your private network, for testing you could set up a loopback:
interface loopback 0
ip add 1.1.1.1 255.255.255.255
ip nat inside
then test:
ping 8.8.8.8 source loopback 0
It should work.
This command is not required, so you can remove it.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Dear, I have tested it but no chance to get it working
Current configuration : 1582 bytes
! Last configuration change at 06:11:36 UTC Tue Feb 13 2018
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
redundancy
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
 ip nat inside
 ip virtual-reassembly in
 ip address 50.39.10.44 255.255.255.248
 ip nat outside
 duplex auto
 speed auto
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface Cellular0/0/0
 no ip address
 encapsulation ppp
interface Cellular0/1/0
 no ip address
 encapsulation ppp
interface Cellular0/0/1
 no ip address
 encapsulation ppp
interface Cellular0/1/1
 no ip address
 encapsulation ppp
no ip http server
logging esm config
control-plane
line con 0
line aux 0
line 0/0/0 0/0/1
 no exec
line 0/1/0 0/1/1
 no exec
line vty 0 4
 login
 transport input all
end
"no access-list 10"
Jon
Thanks your help it's working
Have you tried to ping the ISP device? if you got a response the configuration should work. Otherwise is something wrong between your router and the ISP router.
ping 50.39.10.X source fastethernet 0/0  ; where 50.39.10.X is the gateway or IP configured on the ISP device.
why is
I think it should be :
Good catch. Clearly the original post did indicate that the ISP had provided subnet 51.39.10.40. If it still does not work after correcting the addressing then please post the output of show ip interface brief and of show arp.
Rick
Rick
