QoS on ASR 1002x causes restart
mahditalebi
Hey Guys,
I'm planning for a service provider network QoS. My customer has ASR 1002x for its BRASs and has about 15k PPPoE users on each BRAS. In order to serve a better service to users, my customer decided to run QoS on the downstream traffic toward users. What I have done till now is very simple as bellow:
policy-map PLM
  class 4C-REAL
     priority percent 10
  class class-default
    bandwidth percent 90
    random-detect
policy-map PLM-PR
  class 4C-PERMIT
    police 8000 conform-action transmit exceed-action transmit violate-action transmit
  class 4C-REAL
    priority percent 10
  class class-default
    random-detect
policy-map 3839
  class class-default
    shape peak 10000 100000 100000 // Numbers are not accurate
       service-policy PLM
policy-map 3840
  class class-default
    shape peak 10000 100000 1000000 // Numbers are not accurate
       service-policy PLM-PR
My problem is that my router reloads after some hours even I put only 2k users on it. I check Memory, CPU usages but they are less than 10 percent. I also checked my total active queues, but they are about 4000 queues which is much lower than router capability. The error that cause the reload is "watchdog" in earlier IOSs or "Software Crticial Error" in newest IOSs (in show ver result). Please check my scenario and give me a solution to do it.
Best Regards,
Mahdi
mahditalebi
No One ?!
