1841 with 2 x WIC-2T
joao
what do you think about a 1841 with 4 x 2Mbps links (2 x WIC-2T)?
karunakargupta
hi,
1841 have two modular slots for WAN access.WIC-2T is also supported. Please go through the data sheet on following link :
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd8016a59b.html
Please rate if found helpful.
Karunakar
my question is if the CPU can work with 4 x 2Mbps.
The slots are there, but can the hardware do the job?
The QPguide says the 1841 works with speeds up to 2M.
Can you elaborate the words written in QP guide ? This does not mean that you will not get throughput of 8 mbps. This router also support Fast ethernet, it does not mean that it will restrict the total traffic to 2 mbps. It may be the speed of bus.
Please rate if you find it helpful.
thanks
Exact words:
"Cisco 1841: Secure data access solution for customer environments up to T1/E1/xDSL WAN rates with services turned on"
