1900 Seriers
TRACY HARTMANN
I have been getting in 1900 series routers and they are coming with a 1Gig usb drive.  What is this used for?  It looks like it just gives it extra memory but what would I use it for except maybe a backup for the IOS?
handoko wiyanto
Level 3
Level 3
Hi there,
I was reading something here
http://www.cisco.com/en/US/docs/routers/access/1900/hardware/installation/guide/19over.html
It turns out that you can use the usb port to connect to a usb device for flash memory where you can save ios or backup config. This port you can also use to connect to security token.
Cheers,
