1921 Router ACL/NAT issue?
Robert Ansell
I have configured my 1921 with nat overload for my network. NAT/PAT is working fine and everyone can access the internet, and my static address translations for remote desktop are working as well.
However, when I go to apply access list 101 to my inbound outside interface, all internet connectivity is lost. For some reason my RDP connections are being allowed when the access list isn't applied to the interface.
Also, port 23 (telnet) is showing as open to the outside (canyouseeme.org) without an access list. I want only the ports in the access list (RDP, ect.) to be accessible from the outside, and I want SSH access to the router from the outside as well. Any help would be appriciated...thanks!
This config is without the access list outside_access_in applied to the outside interface.
Building configuration...
Current configuration : 2274 bytes
! Last configuration change at 01:01:13 UTC Sat Jul 7 2012 by ADMIN
! NVRAM config last updated at 00:59:39 UTC Sat Jul 7 2012 by ADMIN
version 15.1
hostname *****1921
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1921/K9 sn *******
username ******* privilege 15 secret *****
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address X.X.X.X 255.255.255.224
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.254.51.1 255.255.255.248
ip nat inside
duplex auto
speed auto
router eigrp 1
network 10.0.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.100.51.10 3389 interface GigabitEthernet0/0 3389
ip nat inside source static tcp 10.100.51.251 1723 interface GigabitEthernet0/0 1723
ip route 0.0.0.0 0.0.0.0 gi0/0
access-list 100 remark Allow PAT
access-list 100 permit ip 10.0.0.0 0.255.255.255 any
access-list 101 remark Outside_Access_in
access-list 101 permit icmp any any echo
access-list 101 permit tcp any any eq 3389
access-list 101 permit tcp any any eq 1723
access-list 101 permit gre any any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
John Blakley
Try adding:
access-list 101 permit tcp any any established
This line should fix your browsing issues. You'll need to allow DNS back in specifically though by also adding:
access-list 101 permit udp any any eq 53
To enable only ssh, you'll need to set a domain name:
ip domain-name
Generate keys:
crypto key generate rsa modu 1024
Create a user:
username secret
Create an enable password:
enable secret
Enable SSH on your vty lines and authenticate against the local account database:
line vty 0 4
transport input ssh
login local
At this point, you should only be able to ssh into the router and not telnet.
HTH,
John
HTH, John *** Please rate all useful posts ***
