5000 RTO EIGRP
Not applicable
Hi everybody,
I have a issue in my network, i have 2 data connections with 2 different ISP (Principal & Backup connection).
But with ISP "X" the RTO are stable (RTO 240), but with the ISP "Y" the RTO is in 5000 and the connection always are flapping
What can i say to my "Y" ISP?
Thanks!!
13 Replies 13
what about the other neighbors' values? Try posting the output of
show ip eigrp neighbors
Those timeouts might be due to a number of reasons...
Hi Francesco,
This is it:
XXXX#sh ip eigrp neighbors
IP-EIGRP neighbors for process 18
H   Address                 Interface       Hold       Uptime     SRTT   RTO    Q      Seq
                                                     (sec)                       (ms)             Cnt    Num
0   30.30.30.2              Fa0/0          14        03:47:51     137    5000    0     122758
Thanks!
You might have occasionally (actually not in you output) high SRTT values, which
lead to timeouts and consequently highs RTO values.
You should gather some stats about rtt, jitter and packet loss values: for instance
you could try running an extended ping to 30.30.30.2 with your router-id as the source
of icmp packets
pleasepost more info:
show ip eigrp interface
show ip eigrp nei
show interface point_to_Y
and post the RTT as well, the full output. 5000 is not a casual value.
http://www.cisco.com/en/US/docs/ios/12_0/np1/command/reference/1reigrp.html
Alessio
H guys,
read here that can help :)
http://ieoc.com/forums/p/5028/16536.aspx
Alessio
Sure... there's a lot of reason why that would do so, high rtts, jitter over wan, maybe even
a unidirectional wan link...
You did not get what i meant.
No matters
Alessio
Hi!!
this is the information that you ask:
XXXXX>sh ip eigrp neighbors
                                            (sec)         (ms)       Cnt Num
0   192.168.1.1             Fa0               13 05:59:16 1191  5000  0  4
XXXXXX>sh ip eigrp interfaces fa0
IP-EIGRP interfaces for process 1
                        Xmit Queue   Mean   Pacing Time   Multicast    Pending
Interface        Peers  Un/Reliable  SRTT   Un/Reliable   Flow Timer   Routes
Fa0                1        0/0      1191       0/10        5956           0
XXXXX>sh int fa0
FastEthernet0 is up, line protocol is up
  Hardware is PQUICC_FEC, address is 0019.e8c9.d469 (bia 0019.e8c9.d469)
  Internet address is 192.168.1.2/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     150811 packets input, 201215750 bytes
     Received 5207 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     153684 packets output, 201503066 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
This is the another point:
XXXXX#show ip eigrp interface fa0
Fa0                1        0/0         4       0/10          50           0
XXXXXX#show ip eigrp nei
                                            (sec)         (ms)       Cnt Num
0   192.168.1.2             Fa0               13 06:03:55    4   200  0  12
XXXXXXX#show interface fa0
  Hardware is PQUICC_FEC, address is 0013.c42c.732f (bia 0013.c42c.732f)
  Internet address is 192.168.1.1/24
  5 minute input rate 0 bits/sec, 1 packets/sec
     5408 packets input, 494337 bytes
     Received 5092 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     7624 packets output, 640891 bytes, 0 underruns
Thanks!!
rizwanr74
Level 7
Level 7
Hi Kenneth,
neighbors flapping is due to, missed hello-packet from remote-eigrp peer.
what is the bandwidth set on the interface, on one which neighbors is flapping?
Look forward to hear from you.
thanks
Not applicable
rizwanr74
The interface bandwidth set 100mbps and it is 192.168.1.2 that is constantly flapping....
thanks
what is actually flapping - interface or EIGRP? can we have a 'sh logg' please?
EIGRP uses multicast for hello transmission, right? hence verifying unicast might not be the way forward. Do you have any issues with multicast? can you ping 224.0.0.10 off that interface?
the interface speed should be 100 Mbps ... no 10..
check again
Alessio
Not applicable
Smooth Round Trip Time (SRTT) - the average time in milliseconds between the transmission of a packet to a neighbour and the receipt of an acknowledgement.
Retransmission Timeout (RTO) - if a multicast has failed, then a unicast is sent to that particular router, the RTO is the time in milliseconds that the router waits for an acknowledgement of that unicast.
I talk to with "Y" ISP and they said that problem is that between these two points in the ring of them, is a very long distance, they will change the route of the fiber.
Thank you very much for your help.
