1921 Router PPPoe issue
steve.robinson
I have setup a 1921 Cisco router to connect to and ISP to provide Guest Wifi and I am in the early stages of setting it up. the config is below but from a client PC plugged in gi0/1 I can ping 216.589.214.35 but when I open IE it won't connect.
I can also ping everything from the router except the client PC 192.168.0.11 which is supplied via DHCP from the router
version 15.1
hostname TEST
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool DHCP_GUEST
 import all
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
password encryption aes
username admin privilege 15 secret 5
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Link_to_ZEN
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
 no mop enabled
interface GigabitEthernet0/1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 no ip virtual-reassembly in
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
 clock rate 2000000
interface Dialer1
 mtu 1492
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp chap hostname xxxxxxx
 ppp chap password 0 xxxxxxx
 ppp pap sent-username xxxxxxx password 0 xxxxxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
ip nat inside source list DSL_ACCESSLIST interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended DSL_ACCESSLIST
 permit ip any any
access-list 10 permit 192.168.0.0 0.0.0.255
control-plane
line con 0
 login local
line aux 0
line 2
line vty 0 4
 login local
 transport input ssh
scheduler allocate 20000 1000
end
Also the out put from "sh ip route" and "sh ip int bri"
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Dialer1
      62.0.0.0/32 is subnetted, 1 subnets
C        62.3.80.17 is directly connected, Dialer1
      88.0.0.0/32 is subnetted, 1 subnets
C        88.97.23.187 is directly connected, Dialer1
      192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.0.0/24 is directly connected, GigabitEthernet0/1
L        192.168.0.1/32 is directly connected, GigabitEthernet0/1
Any interface listed with OK? value "NO" does not have a valid configuration
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES unset  administratively down down
GigabitEthernet0/0         unassigned      YES unset  up                    up
GigabitEthernet0/1         192.168.0.1     YES manual up                    up
Serial0/0/0                unassigned      YES unset  administratively down down
Dialer1                    88.97.23.187    YES IPCP   up                    up
NVI0                       unassigned      NO  unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    up
could be just a DNS problem. Try and add the Google DNS servers to your DHCP pool:
import all
dns-server 8.8.8.8 8.8.4.4
try and add:
dialer-list 1 protocol ip permit
to the configuration.
I added dialer-list 1 protocol ip permit but the client still fails to open a web page from IE but yet can still ping 216.58.214.35, I have tried another PC and that to has the same issue.
import all
steve.robinson
I had just thought of the very same thing, and once added the DNS servers everything worked, Thanks.
