1921 router with dual ADSL nat problem
svansteensel
I'm having issues with setting up a 1921 router with dual ADSL lines for failover. For some reason internet traffic keeps using dialer 1 as primary internet connection, while dialer 2 should be primary. Also when I end my NAT acl with permit any any, it translates the public ip of dialer 2 to dialer 1 before it sends it out in the internet.
This is my config:
interface GigabitEthernet0/0
 description voice netwerk
 ip address 192.168.77.254 255.255.255.0
 ip helper-address 192.168.177.1
 ip helper-address 192.168.177.254
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1400
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description inside interface
 ip address 192.168.177.254 255.255.255.0
 ip mtu 1492
 ip nat inside
 duplex auto
 speed auto
interface ATM0/0/0
 description ADSL 1/10 Mb Tele2
 no ip address
 no atm ilmi-keepalive
 pvc 0/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0/0/0
 no ip address
 shutdown
interface ATM0/1/0
 no ip address
interface Ethernet0/1/0
 description VDSL 5/50 Mb KPN
 no ip address
interface Ethernet0/1/0.6
 description KPN VDSL
 encapsulation dot1Q 6
 pppoe enable group global
 pppoe-client dial-pool-number 2
 service-policy output parent-policy
interface Dialer1
 description ADSL Tele2
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp authentication chap callin
 ppp pap sent-username **************
 no cdp enable
 crypto map SAL_map
interface Dialer2
 description VDSL KPN
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 load-interval 30
 dialer pool 2
 ppp authentication pap callin
 ppp pap sent-username **************************
 no cdp enable
 crypto map SAL_map_VDSL
ip nat inside source route-map nonat interface Dialer1 overload
ip nat inside source route-map nonat2 interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer2 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 254
ip sla auto discovery
ip sla 10
 icmp-echo 62.69.174.75 source-interface Dialer2
 timeout 30000
 frequency 30
ip sla schedule 10 life forever start-time now
access-list 102 deny   ip 192.168.177.0 0.0.0.255 host 192.168.1.249
access-list 102 deny   ip 192.168.178.0 0.0.0.255 host 192.168.1.249
access-list 102 deny   ip 192.168.179.0 0.0.0.255 host 192.168.1.249
access-list 102 deny   ip 192.168.177.0 0.0.0.255 172.28.1.0 0.0.0.255
access-list 102 deny   ip any 192.168.255.0 0.0.0.255
access-list 102 deny   ip any 192.168.254.0 0.0.0.255
access-list 102 deny   ip 192.168.177.0 0.0.0.255 192.168.179.0 0.0.0.255
access-list 102 deny   ip 192.168.177.0 0.0.0.255 192.168.178.0 0.0.0.255
access-list 102 deny   ip 192.168.177.0 0.0.0.255 192.168.79.0 0.0.0.255
access-list 102 deny   ip 192.168.177.0 0.0.0.255 192.168.78.0 0.0.0.255
access-list 102 deny   ip 192.168.77.0 0.0.0.255 192.168.179.0 0.0.0.255
access-list 102 deny   ip 192.168.77.0 0.0.0.255 192.168.178.0 0.0.0.255
access-list 102 deny   ip 192.168.77.0 0.0.0.255 192.168.79.0 0.0.0.255
access-list 102 deny   ip 192.168.77.0 0.0.0.255 192.168.78.0 0.0.0.255
access-list 102 permit ip 192.168.177.0 0.0.0.255 any
access-list 102 permit ip 192.168.77.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map nonat2 permit 10
 match ip address 102
 set interface Dialer2
route-map nonat permit 10
 set interface Dialer1
the ACL is build to exclude some private ips for ipsec VPN destinations.
Any suggestions on what I am missing? It should use dialer 2 as primary internet connection and failover to dialer 1 if IP SLA fails. The SLA config seems to work fine:
sh ip route
S*    0.0.0.0/0 is directly connected, Dialer2
      84.0.0.0/32 is subnetted, 1 subnets
C        84.246.25.231 is directly connected, Dialer1
      145.131.0.0/32 is subnetted, 1 subnets
C        145.131.131.112 is directly connected, Dialer2
      192.168.77.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.77.0/24 is directly connected, GigabitEthernet0/0
L        192.168.77.254/32 is directly connected, GigabitEthernet0/0
      192.168.177.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.177.0/24 is directly connected, GigabitEthernet0/1
L        192.168.177.254/32 is directly connected, GigabitEthernet0/1
      192.168.254.0/24 is variably subnetted, 2 subnets, 2 masks
S        192.168.254.0/24 is directly connected, Dialer2
S        192.168.254.37/32 [1/0] via 77.241.229.241
S     192.168.255.0/24 is directly connected, Dialer1
      212.121.121.0/32 is subnetted, 1 subnets
C        212.121.121.183 is directly connected, Dialer2
      213.144.228.0/32 is subnetted, 1 subnets
C        213.144.228.72 is directly connected, Dialer1
Vishesh Verma
http://docwiki.cisco.com/wiki/Category:NAT
Document above states "Beware of using ACL for NAT with "permit ip any any" as you can get unpredictable results." I suggest that you use the "route-map nonat/nonat2 permit 20" instead of "permit any any"
For the remaining, modify the config as following -
ip sla 10
 icmp-echo 8.8.8.8 source-interface Dialer2
 timeout 30000
 frequency 30
ip route 8.8.8.8 255.255.255.255 dialer2 permanent
 match interface Dialer2
 match interface Dialer1
event manager applet NAT-TRACK
event track 1 state any
action 0.1 cli command "enable"
action 0.2 wait 2
action 0.3 cli command "clear ip nat translations forced"
action 0.4 syslog msg "NAT translation cleared after track state change"
-Vishesh
5 Replies 5
Vishesh Verma
ip sla 10
 timeout 30000
 frequency 30
action 0.2 wait 2
-Vishesh
Hi Vivesh, thx for your reply. I am not. dure what You mean by permit 20 instead of permit any any. I am using acl 102 now and removed permit any any, but still it uses dialer 1 as primary internet link. Do You mean one of route maps should have sequence no 20?
I have tried to add the dialer 1 route-map as a permit 20 in the nonat2 and then apply it to both NAT statements, but that does not work. When you use the same route-map for your NAT statement  (ip nat inside source nonat....etc) the second statement overwrites the first.
So I do need 2 route-maps. The only thing I am doubting about now is how the dialer is selected, is it possible that dialer 1 is always preferred over dialer 2? So I need to change the sequence number?
Ah, I see the difference now. I have used the match interface instead set interface now and it works like a dream. Thx!
svansteensel
