1941 crashinfo - first configuration problem
pwolsza_wolfik1
I tried to made first configuration for the router using CCP Express Wizard.
After information that the router will be restarted nothing is written to the configuration and in the flash new file has shown : crashinfo.
Any suggestions ??
This is fragment of the file:
CMD: 'ip ssh time-out 60' 15:02:44 PCTime Thu Jan 27 2011
CMD: 'ip ssh authentication-retries 2' 15:02:44 PCTime Thu Jan 27 2011
CMD: 'banner login ~Authorized access only!' 15:02:44 PCTime Thu Jan 27 2011
%ALIGN-1-FATAL: Illegal access to a low address 15:02:44 PCTime Thu Jan 27 2011
addr=0x4, pc=0x24A0D83Cz , ra=0x22266C08z , sp=0x318CDE68
15:02:44 PCTime Thu Jan 27 2011: TLB (store) exception, CPU signal 10, PC = 0x24A1707C
   Possible software fault. Upon reccurence, please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 0x24A0D83Cz 0x22266C08z 0x22226880z 0x2222CE94z 0x22267EB0z 0x22268330z 0x235E87B0z 0x235E5F24z 0x2279DA34z 0x227B3DE4z 0x227B4084z 0x227B43F4z 0x233E7980z 0x233E7964z
$0 : 00000000 00000000, AT : 00000000 26A50000, v0 : 00000000 00000004, v1 : 00000000 0000000D
a0 : 00000000 00000004, a1 : 00000000 25C80C04, a2 : 00000000 00000FFF, a3 : 00000000 00000004
t0 : 00000000 0000000D, t1 : 00000000 0000005E, t2 : 00000000 00000072, t3 : 00000000 0000000D
t4 : 00000000 00000021, t5 : 00000000 00000001, t6 : 00000000 00000001, t7 : 00000000 00000001
s0 : 00000000 00000004, s1 : 00000000 27F831D6, s2 : 00000000 30BF70D4, s3 : 00000000 27F831B4
s4 : 00000000 0000007E, s5 : 00000000 26C27934, s6 : 00000000 00000000, s7 : 00000000 00000000
t8 : 00000000 00000002, t9 : 00000000 25C80000, k0 : 00000000 504080E1, k1 : FFFFFFFF FFFFFFFE
gp : 00000000 26A5EDE0, sp : 00000000 318CDE68, s8 : 00000000 00000000, ra : 00000000 22270448
EPC  : 24A1707C, ErrorEPC : 80412AE4, SREG     : 50009FE3
MDLO : 0000005B, MDHI     : 0000547E, BadVaddr : 00000004
CacheErr_Icache : 0x007F7F00 - 00000360, CacheErr_Dcache : 0x00000000 - 00002C70
TagLo_Icache : 0x00000000 - 22234D83, DataLo_Icache : 0x8FBF0074 - 8E061A4C
DataHi_Icache: 0x00000000 - 00000000
TagLo_Dcache : 0x00000000 - 317D5203, TagHi_Dcache : 0x00000000 - 06A56F01
DataLo_Dcache: 0x27A40240 - 0CD14435, DataHi_Dcache : 0x00000000 - 00000070
TEXT_START : 0x2100A118
DATA_START : 0x24A33840
Cause 0000000C (Code 0x3): TLB (store) exception
=== Start of Crashinfo Collection (15:02:44 PCTime Thu Jan 27 2011) ===
For image:
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(2)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 22-Oct-10 23:32 by prod_rel_team
========= Show Alignment =============================
Alignment data for:
No alignment data has been recorded.
Total Spurious Accesses 1, Recorded 1
Address  Count  Traceback
       4      1  0x24A0D80Cz  0x22266C08z  0x22226880z  0x2222CE94z
Michael Simon
The TLB (store) exception, CPU signal 10, is a kind of bus error crash.
In this case the system tried to write to the address 0x4.  There is no physical memory at this address. That failure causes the crash.
You should open a TAC case to have this crash investigated in detail.
You are running a very new IOS image and this is likely a new bug that needs to be identified and resolved.
........Mike
So what to do??
How to use this TAC case ??
This FAQ explains how to open a TAC case from the community:
https://supportforums.cisco.com/docs/DOC-13613
If you do not have a support contract and your router is still in warranty call +1 800-553-2447 to open a TAC support case.
........Mike
