1941 Router with 4G LTE interface
Earl Granger IV
All,
Im trying to figure out why am I unable to ping the outside.
Building configuration...
Current configuration : 6634 bytes
! Last configuration change at 06:12:26 PDF Mon Jul 2 2012
version 15.1
hostname *********_FNO_R
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$IYVA$6iuMPP1kiOafiucmUSI4o0
aaa new-model
aaa authentication login aaaVPN local
aaa authorization network aaaVPN local
aaa session-id common
memory-size iomem 10
clock timezone PST -8 0
clock summer-time PDF recurring
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
ip cef
ip domain name ******.com
ip name-server 8.8.8.8
ip name-server 8.8.8.9
ip inspect name OUTSIDE tcp
ip inspect name OUTSIDE http
ip inspect name OUTSIDE ftp
ip inspect name OUTSIDE dns
ip inspect name OUTSIDE udp
ip inspect name OUTSIDE pptp
ip inspect name OUTSIDE pop3
ip inspect name OUTSIDE icmp
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK"
crypto pki trustpoint TP-self-signed-1448230907
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1448230907
revocation-check none
rsakeypair TP-self-signed-1448230907
crypto pki certificate chain TP-self-signed-1448230907
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343438 32333039 3037301E 170D3131 31313132 30313530
  31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34343832
  33303930 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CAE6 41DD1366 B726692C 637C6B74 57D41277 23D48183 0B38C79D 73445C15
  256708CD E732B554 BCD9DEA0 76244504 67A45255 182E4EB6 73B94D39 8212FF08
  CCF73B7A 0C690EEC 0D2096AA 08DAB99D 7015D9EB 3BA87BA2 ECAA1E6A 1A66B2DD
  2ED2B8B2 A028FE60 B06ADD61 BDAF0732 A039CE46 CBFBCE3B 00844135 87C7C989
  83B10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14A32D2B 4D1EE678 A2E3AC22 222BD8AA 544F352A 65301D06
  03551D0E 04160414 A32D2B4D 1EE678A2 E3AC2222 2BD8AA54 4F352A65 300D0609
  2A864886 F70D0101 05050003 818100C3 5219207A 841EFB54 038404F6 9B839240
  F6D971FB 024385CB DCB28438 59ED7C18 DAB8261A 47704678 6D24E59A B997737A
  14A355DD 23FF5C30 12E65556 6EEA2F7C 0676AEC2 9BF3012C 8A75E22E C7643E28
  64B713E1 C40E06BE 696062D6 AB2D8817 87199036 AB45ECDE 0E9BC821 88405B0C
  928385EF A3B64981 30221EBE 78B91B
        quit
license udi pid CISCO1941W-A/K9 sn FTX1546842C
hw-module ism 0
username ****** password 0 cisco
username ****** privilege 15 secret 5 $1$mLPu$5Y4Kc9ggJc8yvJPN21Kdl1
username Admin privilege 15 secret 5 $1$/qQX$O7Dt8EKu/0JMkxiPNLSPE1
username guestn privilege 15 secret 5 $1$du8/$qW25linQjceGRtZgv4vcT/
username guests privilege 15 secret 5 $1$4KF1$Gl18Msm5.l4M7HPwAzkQv.
username caltransn privilege 15 secret 5 $1$C2Zc$pMrlXYZYG4Y4c26HWRhMZ0
username caltranss privilege 15 secret 5 $1$Rl0T$YheDklce.VP8S2x5bqPFf/
username ccjpa privilege 15 secret 5 $1$..Jr$AAPMTbcllZOSIhI.KHypv.sMt.
redundancy
controller Cellular 0/0
ip ssh version 2
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp client configuration group grpVPN
key *******
dns 10.0.48.254
domain amtrak.com
pool poolVPN
acl aclSPLIT
save-password
split-dns amtrak.com
netmask 255.255.255.0
crypto isakmp profile ikeRPF1
   match identity group grpVPN
   client authentication list aaaVPN
   isakmp authorization list aaaVPN
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ts1 esp-aes 256 esp-sha-hmac
crypto ipsec profile crRPF1
set transform-set ts1
interface Loopback0
ip address 192.168.255.255 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.10.1 255.255.255.248
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
shutdown
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
no ip address
interface Cellular0/0/0
ip address neogiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.0.48.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Vlan10
ip address 172.16.200.1 255.255.255.240
ip nat inside
ip local pool poolVPN 192.168.200.1 192.168.200.254
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 10 interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
ip access-list extended OUTSIDE_IN
permit udp host 8.8.8.8 eq domain any
permit udp host 8.8.8.9 eq domain any
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any port-unreachable
permit icmp any any ttl-exceeded
permit icmp any any packet-too-big
permit udp host 192.5.41.41 eq ntp any eq ntp
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
permit esp any any
deny   ip any any log
ip access-list extended aclSPLIT
permit ip 10.0.48.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 10 permit 172.16.200.0 0.0.0.15
access-list 10 permit 10.0.48.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
script dialer lte
modem InOut
no exec
line 0/0/1 0/0/3
no exec
line 67
no exec
transport input all
line vty 0 4
transport input all
line vty 5 15
access-class 23 in
transport input all
5 Replies 5
Chris Allen
Did you ever find the resolution?  I have a similar configuration and same result.
Verizon wireless doesn't seem to have a clue.
You need to make sure that your APN name is matched for your region.  It depends on what type of setup you want for this card..Do you want it always up or as a backup.  Mine was configured for Primary.
brian holmes
Did you ever get this figured out? I seem to be having the same issue.
Debug when i attempt a connection.
Jan  9 14:53:11.687: TTY0: resume timer type 1 (OK)
Jan  9 14:53:11.691: Ce0/1/0 DDR: place call
Jan  9 14:53:11.691: Ce0/1/0 DDR: Dialing cause ip (s=x.x.x.x, d=8.8.8.8)
Jan  9 14:53:11.691: Ce0/1/0 DDR: Attempting to dial lte
Jan  9 14:53:11.691: CHAT0/1/0: Attempting async line dialer script
Jan  9 14:53:11.691: CHAT0/1/0: Dialing using Modem script: lte"" & System script: none
Jan  9 14:53:11.691: CHAT0/1/0: process started
Jan  9 14:53:11.691: CHAT0/1/0: Asserting DTR
Jan  9 14:53:11.691.: CHAT0/1/0: Chat script lte"" started
Jan  9 14:53:11.691: CHAT0/1/0: Expecting string: AT!CALL1.
Jan  9 14:53:16.691: CHAT0/1/0: Timeout expecting: AT!CALL1
Jan  9 14:53:16.691: CHAT0/1/0: Chat script lte"" finished, status = Connection timed out; remote host not responding
Jan  9 14:53:16.691: TTY0/1/0: Line reset by "Async dialer"
Jan  9 14:53:16.691: Ce0/1/0 DDR: disconnecting call
Jan  9 14:53:16.691: TTY0/1/0: Modem: (unknown)->HANGUP
Jan  9 14:53:16.691: TTY0/1/0: no timer type 0 to destroy
Jan  9 14:53:16.691: TTY0/1/0: no timer type 1 to destroy
Jan  9 14:53:16.691: TTY0/1/0: no timer. type 3 to destroy
Jan  9 14:53:16.691: TTY0/1/0: no timer type 4 to destroy
Jan  9 14:53:16.691: TTY0/1/0: no timer type 10 to destroy
Jan  9 14:53:16.691: TTY0/1/0: no timer type 2 to destroy
Jan  9 14:53:17.363: TTY0/1/0: dropping DTR, hanging up
Some Information from show cell all
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = VZWINTERNET
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Mobile Country Code (MCC) = 311
Mobile Network Code (MNC) = 480
Radio Information
Radio power mode = ON
Current RSSI = -74 dBm
LTE Technology Preference = AUTO
LTE Technology Selected = LTE
The issue was with my chat script.
chat-script lte"" "AT!CALL1" TIMEOUT 60 "OK"
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK" /added space and changed timeout. Connection is now working.
I was given the wrong APN information by my SP/vendor, once I had that and verified the "space" in the chat script, it also worked for me.
Thanks for the reply.
