2 different subnets sharing one printer and file server
Hi Guys
Cisco newbie here.
Question.
Can 2 different subnets lets say 192.168.1.x AND 10.10.6.X share the same printer (10.10.6.10) and fileserver 192.168.1.10.  Thanks for your help
7 Replies 7
not without a layer 3 device (router or L3 capable switch)...or put an additional network card in both the printer and the file server, for the purpose of assigning IP addresses from both subnets...
Ok...
Is the Cisco Catalyst 3500 a L3 Switch
post the output of 'show version' so we can see which model you have...
User Access Verification
Password:
3500work>show ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:04 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
ROM: Bootstrap program is C3500XL boot loader
3500work uptime is 2 days, 19 hours, 47 minutes
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC17.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID FAA0514G10N, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:05:9B:A4:EE:00
Motherboard assembly number: 73-3903-08
Power supply part number: 34-0971-01
Motherboard serial number: FAB0513E0PM
Power supply serial number: PAC04510AYJ
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FAA0514G10N
Configuration register is 0xF
you have a (very old) 3500XL switch, which does layer 2 only, unfortunately...
How can I tell if it's a L2 or L3 from the show ver
the 'show ver' tells you which exact model you have. You need to know which models are L3 capable (such as the 3550). The 3500XL is not, as a matter of fact, it was a very popular L2 switch...about 20 years ago...;)
