2 ISP's, 1 external Network Router on a stick
amatorjnr
Hi, please I'm testing out a scenario where I have 2 ISP's, and 1 external Network configuration on a router on a stick configuration,
I have 5 Vlans, All should be able to access the internet 1 ISP interface.
vlan 2 and 5 should be able to access all 2 ISPs at will
only vlan 4 should be able to hit the external network (Bank Server)
ALL INSIDE NETWORKS SHOULD BE NAT'D ACROSS ALL OUTSIDE INTERFACES INCLUDING THE EXTERNAL NETWORK
Configuration on router:
Building configuration...
Current configuration : 1799 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX152470A8
no ip domain-lookup
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 10.10.10.190 255.255.255.0
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.5.100
ip nat inside
interface GigabitEthernet0/1.3
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.4
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.5
encapsulation dot1Q 5
ip address 192.168.5.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Serial0/3/0
ip address 4.1.1.2 255.255.255.0
ip nat outside
interface Serial0/3/1
ip address 5.1.1.2 255.255.255.0
ip nat outside
interface Vlan1
no ip address
shutdown
ip classless
ip route 3.1.1.0 255.255.255.0 GigabitEthernet0/1
ip route 3.1.1.0 255.255.255.0 10.10.10.189
ip route 0.0.0.0 0.0.0.0 4.1.1.1
ip route 0.0.0.0 0.0.0.0 5.1.1.1
ip flow-export version 9
ip access-list standard INTERNET
permit 192.168.5.0 0.0.0.255
permit 192.168.4.0 0.0.0.255
permit 192.168.3.0 0.0.0.255
permit 192.168.2.0 0.0.0.255
permit 192.168.1.0 0.0.0.255
line con 0
logging synchronous
line aux 0
line vty 0 4
password amator
login
end
here is what I have come up with initially (additions in bold):
version 15.1
hostname Router
no ip cef
no ipv6 cef
no ip domain-lookup
description Link to External Network
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip policy route-map PBR
ip nat inside
ip nat inside
ip nat inside
no ip address
duplex auto
speed auto
shutdown
description Link to ISP1
ip nat outside
description Link to ISP2
ip nat outside
interface Vlan1
no ip address
shutdown
ip nat inside source route-map ISP1 interface Serial0/3/0 overload
ip nat inside source route-map ISP2 interface Serial0/3/1 overload
ip nat inside source route-map EXTERNAL_NETWORK interface GigabitEthernet0/0 overload
ip classless
access-list 100 permit ip 192.168.0.0 0.0.7.255 any
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 102 permit ip 192.168.4.0 0.0.0.255 10.10.10.0 0.0.0.255
route-map PBR permit 10
match ip address 100
set ip next-hop 4.1.1.1
route-map PBR permit 20
match ip address 101
set ip next-hop 4.1.1.1 5.1.1.1
route-map PBR permit 30
match ip address 102
set ip next-hop 10.10.10.189
route-map ISP1 permit 10
match interface Serial0/3/0
route-map ISP2 permit 10
match interface Serial0/3/1
route-map EXTERNAL_NETWORK permit 10
match interface GigabitEthernet0/0
line con 0
logging synchronous
line aux 0
line vty 0 4
password amator
login
end
Deepak Kumar
You can archive your solution with Route MAP configuration. I am thinking that you are new to Cisco So I am sharing a link:
https://supportforums.cisco.com/t5/network-infrastructure-documents/how-to-configure-static-nat-with-route-maps/ta-p/3132855
if you will face any difficulty then tell me i will share the configuration also.
regards,
Deepak
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thanks for the help, I'll have to get back to you. I'm yet to try it out.
version 15.1
hostname Router
no ip cef
no ipv6 cef
no ip domain-lookup
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
ip nat inside
no ip address
duplex auto
speed auto
shutdown
ip nat outside
ip nat outside
interface Vlan1
no ip address
shutdown
ip classless
line con 0
logging synchronous
line aux 0
line vty 0 4
password amator
login
end
