2 ISPs Failover - Static NAT for Servers
     We have CISCO 1921/K9 Router for ISP Connectivity. We have 2 ISPs.
Route policy placed in Interface Fa0/1 for Proxy server traffic  through FA0/0/1. with static NAT (Default route)
Other public servers traffic through FA0/0 with STATIC NAT for  2 servers (2 static NAT).
Please find the attachment for details.
My query is, Is there a posible way to perform auto-Failover between two ISPs?
My Mailserver's A-record having 24hrs TTL.
To perform auto-failover should i add additional A-record with the IP of ISP 2?
Should I reduce TTL?
Looking forward support.
Hello.
Actually if you are talking about mail server only (inbound connections), then the best way to have a failover - is to have 2 MX records for yuor domain (via primary and via secondary ISP), so you won't be dependant on DNS TTL.
So, nedd need for other tools, as SMTP has built-in feature.
If we are talking about NAT configuration for 2 ISPs, you might have read the article:  http://docwiki.cisco.com/wiki/NAT_failover_with_DUAL_ISP_on_a_router_Configuration_Example
I would also note that it's possible for mail server to accept inbound connection via both ISPs (simultaneously) if you could assign additinal internal IP-address to your mail server, or could assign additional port to SMTP listener.
Please let me know your scenario and I could help you to craft the config.
Thanks for your quick response.
We are using mail server & spamd server (outgoing mail scan) in public.
And Proxy server for Internet access - Default gateway (ISP2)
Single Internal IP address only assigned to mail server.
Static NATing configured public IPs from ISP1 Pool.
As per your suggestions, I have to add secondary Static NAT with ISP2 Pool.
Auto failover can be done by IP SLA (for outbound).
The other change I have to do is add addtional Internal IP for Mail server.
Please correct me if I'm wrong.
Hi.
If you are using proxy as a proxy ONLY (not a firewall), then there is no reason to use it as router (at least on WAN link).
It's better to move proxy server into inside network, so it could be used over primary and over secondary links (in case of failover).
Yes, ip sla will help you to identify interface traffic should flow into.
NAT with route-map will help you to apply correct PAT (per destination interface).
If you assign additional internal IP to your SMTP server, then you are configuring static translations over both IPSs based
on SMTP source (internal) IP-address.
PS: please provide your NAT configuration including [falsified] IP-addresses.
PS2: you need 2 MX records for SMTP failover!
     Please find the NAT details.
interface GigabitEthernet0/0
description To Firewall
ip address 10.*.*.* *.*.*.*
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
ip policy route-map PUB
duplex auto
speed auto
interface GigabitEthernet0/1
description ISP2
ip address 125.17.*.* *.*.*.*
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
duplex full
speed 100
interface FastEthernet0/0/0
description ISP1
ip address 220.*.*.* *.*.*.*
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
ip nat pool Airtel 125.21.*.* 125.21.*.* netmask 255.255.255.240
ip nat pool reliance 220.227.*.* *.*.*.* netmask 255.255.255.240
ip nat inside source list 101 pool Airtel overload
ip nat inside source static (mailserver ip) 220.227.*.*
ip nat inside source static (spamdserver ip) 220.227.*.*
ip route 0.0.0.0 0.0.0.0 (ISP2 Gateway)
route-map PUB permit 10
match ip address 102
set ip next-hop 220.227.*.*
set interface FastEthernet0/0/0
access-list 102 permit ip host (mailserver ip) any
access-list 102 permit ip host (spamdserver ip) any
