2 Layer 3 Switches with 1 router cannot ping from vlan (packet tracer)
will3498
the only way to make your current topology work, that is, for the router to simultaneously talk to both switches, is to put another layer 2 device (either a switch or a hub) between the switches and the router (as in the attached, revised file).
Okay Thank you thats very helpful of you
what are the actual requirements of this project ?
