04-24-2021 08:23 AM
Looking for guidance/recommendations on setting up a RV340 in bridged mode with ISP PPOE connection. I have found separate Cisco articles on how to setup PPPOE & Bridge, but need to know what is recommended when using both. The ISP PPOE connection assigns an IP to the router that is a different subnet from our Static IP block that I need to make available on the other side of the this router. I think I can set this up using the hardware DMZ, but was wondering if using bridge would be a better approach? Thanks in advance for your help!
Solved! Go to Solution.
04-25-2021 07:47 PM
Thanks for your responses guys but I've come up with an alternate configuration solution on the Sonicwall that eliminates the need for the RV340 in between. I'm all set now, thanks.
05-14-2021 06:04 PM
This is just in case somebody would want to use the RV340 in this scenario
ISP Modem >>>>RV340 >>>>Sonicwall
>>>PPPOE ISP assigned IP (WAN1): 111.222.333.444
>>>Public Static IPs allocated by ISP: 111.999.888.73/netmask 255.255.255.248
>>>Need to pass all traffic through the Cisco RV340 to the SonicWall which uses those public static IPs
On the RV340, do the below to solve the above:
1. configure the Hw-DMZ in WAN/Hw-DMZ page
a) Select "Subnet" option, and click "Yes" on the warning page
b) Enter your subnet provided by the ISP that is used by the sonicwall router...
c) click on Apply and do a permanent save
2. Connect the Sonicwall wan interface to LAN4 port of the RV340 (which will become the Hw-DMZ port when enabled)
thats it, it will work as required
Br
04-24-2021 10:26 AM
Hello
Can you post a topology diagram on what you are trying to accomplish, be most better to provide an answer if we can visualize it.
04-24-2021 02:06 PM
Thanks Paul,
Really the only thing I need the Cisco RV340 to do us authenticate and establish the PPPoe connection, and pass all the inbound/oubound traffic through to the SonicWall.
Example.
ISP Modem 61.61.61.61 > >><<<Cisco RV340 WAN1:111.222.333.444 >>><<< Sonicwall Firewall (static IPs 111.999.888.777/netmask 255.255.255.248)
04-24-2021 11:15 AM
here is PPPoe example :
Not sure same IP can extend using bridge to other device (or am i miss understood the requirement)
04-24-2021 02:09 PM
Yes that is the article on the PPPOE setup , and I've read this one on the Bridge setup, https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/Configure-Bridge-Settings-on-the-RV34x-Router.html
but doing both does not seem to work in this situation.
04-25-2021 07:47 PM
05-14-2021 06:04 PM
Br
