2 links for redundancy
in my lab i have this topology :
between R1 and R4 there are two links.
i want to know how can i use Ipsla  on router R1 to track 199.99.9.9 and  to have only one  operational link , and when it's down ,the second one replace it automatically.
regards
2 Accepted Solutions
Bilal Nawaz
Hello - you can do this:
R1:
ip sla monitor 99
type echo protocol ipIcmpEcho 199.99.9.9
frequency 10
ip sla monitor schedule 99 life forever start-time now
track 1 rtr 99 reachability
delay down 10 up 1
ip route 199.99.9.9 255.255.255.255 fa0/0 track 1
ip route 199.99.9.9 255.255.255.255 fa1/0 100
This has a floating static route "ip route 199.99.9.9 255.255.255.255 fa1/0 100" this has a metric of 100 and will only be used if the primary route goes down.
Hope this helps.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Oh! i understand, Yes you will need ipsla for R4 as well on any subnet that R1 has or knows how to get to.
11 Replies 11
Bilal Nawaz
R1:
ip sla monitor 99
frequency 10
delay down 10 up 1
Hope this helps.
ok i'm trying this thank you for the reply
it works just one question if i want to do it this time not to track 199.99.9.9 but all destinations it is enough to replace :
by
ip route 0.0.0.0 0.0.0.0 fa0/0 track 1
ip route 0.0.0.0 0.0.0.0 fa1/0 100
Yes, this will be for all routes that your router does not know about. i.e. anything that is not in the routing table, it will be using the default route.
Hope this helps.
i do what you say first time it works , i entered the command ping 199.99.9.9 repeat 1000 and i delete the  first link :
etc
but whene i replace
by
i have this
until  the primary become active then it pings :
what i'm trying to have is not an ipsla for just 199.99.9.9 but for all destination : i want the primary links as default route,and when it is down the secondary become active and this not just for 199.99.9.9
should i define an ip sla for all destinations ?
may be it is possible without ip sla just by defining two routes with different administrative distance,is it possible with ipsla?
thank you
Hello, I have created the same setup as you, with R1 and R4. I have added the 'source-interface' key word in the tracking SLA.
Here is my config on R1:
ip sla monitor 99
type echo protocol ipIcmpEcho 199.99.9.9 source-interface FastEthernet0/0
frequency 5
delay down 5 up 1
ip address 150.0.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 150.0.1.1 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 track 1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 100
Here is my config on R4
interface Loopback0
ip address 199.99.9.9 255.255.255.0
interface Loopback1
ip address 1.1.1.1 255.255.255.255
ip address 150.0.0.4 255.255.255.0
duplex auto
speed auto
ip address 150.0.1.4 255.255.255.0
duplex auto
speed auto
On R1 I will do a continuous ping and shut down interface fa0/0 on R2... I will ping 1.1.1.1
R1#ping 1.1.1.1 repeat 1000
Sending 1000, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
*Mar  1 00:20:03.659: %TRACKING-5-STATE: 1 rtr 99 reachability Up->Down!!!!!!!!!!!!!!!!!!!!!!!!!
Success rate is 98 percent (726/735), round-trip min/avg/max = 12/20/40 ms
R1#
So it does work, and works pretty fast!
So please give this a go and let me know the results.
with using
type echo protocol ipIcmpEcho 150.0.0.4
it works,so i should track 150.0.0.4
thank you for help it was useful .
In my opinion you should use this command instead of tracking the interface IP on the other side like this:
The loopback is the most reliable interface on the router and therefor you should track the loopback but from a particular interface. In our case fa0/0.
Hope this helps
thank you,yes you are right,but  if i ping from router R2 to router R1 (see the primary topology) which link will be used to reach the destination ?
ping 172.16.1.1  (the loopback of R1)
should i define an other ipsla on router R4 ?
I cant' use a default route this time because it is reserved to the loopback 199.99.9.9 (internet)
In your case if you ping from router R2 to a  loopback interface in router R1 which link will be used(your topology).
the icmpecho may go through the  secondary links but when it hit router R1 it will return through the primary link .i don't want that router R2 use the secondary link
Ok thanks ;-)
