2-way mutual redistribution - OSPF and BGP
Babak KHorshid
Hello All,
I am practising a scenario and I got really frustrated. I am wondering if some one can put me in the right direction
Its a simple OSPF- BGP route filtering (and I'm stuck!) AND a simple MED config on R4 (Which doesn't work!)
Lets start with filtering to avoid confusion. I can deal with the MED issue later.
What I am doing is to tag any route from BGP into OSPF. (On router 2 tag with 2222 and on router 3 tag with 3333. )
The route-map OSPF2BGP should stop these routes to leak back into BGP and only allow network 1.1.1.1 to redistribute from OSPF into BGP.
route-map OSPF2BGP deny 5
match tag 3333 2222
route-map OSPF2BGP permit 10
match ip address 10
access-list 10 permit 1.1.1.0 0.0.0.255
BUT I do not have the ability to do the same thing while tagging OSPF into BGP. for example if I issue the following:
R2(config-route-map)#route-map OSPF2BGP permi 10
R2(config-route-map)#set tag 1111 (So further I could reject this tag on BGP )
R2(config-route-map)#router bgp 200
R2(config-router)#redistribute ospf 1 route-map
I'll get this error
" % "OSPF2BGP" used as redistribute ospf into bgp route-map, set tag not supported "
Then if dont tagg OPSF, I'll end up having the following issue:
#Show ip bgp
* i 1.1.1.1/32 10.1.3.1 2 100 0 ?
*> 10.1.2.1 2 32768 ?
* i 4.4.4.0/24 10.3.4.4 0 100 0 500 ?
R2 has no idea about directly attached 4.4.4.4
R2#sho ip route 4.4.4.0
Routing entry for 4.4.4.0/24
Known via "ospf 1", distance 110, metric 1
Tag 3333, type extern 2, forward metric 2
Redistributing via bgp 200
Last update from 10.1.2.1 on FastEthernet1/0, 00:02:46 ago
Routing Descriptor Blocks:
* 10.1.2.1, from 10.3.4.3, 00:02:46 ago, via FastEthernet1/0
Route metric is 1, traffic share count is 1
Route tag 3333
R2#
Its leaking from OPSF and the router is picking that up. If i use the Community option the same error would pop up.
Can some one please tell me what am I doing wrong?
The following is the BGP config on devices
R2
router ospf 1
redistribute bgp 200 subnets tag 2222
router bgp 200
bgp log-neighbor-changes
redistribute ospf 1 route-map OSPF2BGP
neighbor 10.1.3.3 remote-as 200
neighbor 10.1.3.3 ebgp-multihop 4
neighbor 10.1.3.3 update-source FastEthernet1/0
neighbor 10.2.4.4 remote-as 500
neighbor 10.2.4.4 ebgp-multihop 2
neighbor 10.2.4.4 update-source FastEthernet0/0
ip forward-protocol nd
no ip http server
no ip http secure-server
match tag 3333 2222
match ip address 10
R3
R3#sho run | b router ospf
router ospf 1
redistribute bgp 200 subnets tag 3333
router bgp 200
neighbor 10.1.2.2 remote-as 200
neighbor 10.1.2.2 ebgp-multihop 4
neighbor 10.1.2.2 update-source FastEthernet0/0
neighbor 10.3.4.4 remote-as 500
neighbor 10.3.4.4 ebgp-multihop 2
neighbor 10.3.4.4 update-source FastEthernet1/0
no ip http server
match tag 3333 2222
match ip address 10
R4:
router bgp 500
redistribute connected route-map connected
neighbor 10.2.4.2 remote-as 200
neighbor 10.2.4.2 ebgp-multihop 2
neighbor 10.2.4.2 update-source FastEthernet0/0
neighbor 10.2.4.2 route-map ME out
neighbor 10.3.4.3 remote-as 200
neighbor 10.3.4.3 ebgp-multihop 2
neighbor 10.3.4.3 update-source FastEthernet1/0
no ip http server
access-list 10 permit 4.4.4.0 0.0.0.255
access-list 20 permit 1.1.1.1
route-map ME permit 10
match ip address 20
set metric 100
route-map connected permit 10
match ip address 10
Hello
By default when bgp is redistributed into ospf the ASN of the bgp will be the route-tag in ospf however when ospf is redistributed into bgp those tags and the origin of those routes will be lost.
sh ip ospf data topol  | in Tag
So when you advertise ospf into bgp,  If you add in your route- map to set as-path tag then the tag and origin will be retained and as such you should be able filter on it.
Kind Regards
Paul
Hello
Kind Regards
Paul
Thanks Paul for your respond.
So my understanding is when I am advertising from OSPF to BGP, I should have a route-map with set as-path tag.
Then to stop thos route from leaking back to OSPF I can filter them on BGP.
I am going to try that and let you know how did it go.
appreciate your time
Babak
