2522 Logging
David Santos
I´m trying to setup a lab, i´m using a 2522 for a FR switch but i can´t see any messages on the output, no warnings or debug messages.
What am i doing wrong? Can someone help me with this?
FRSW.LAB#sh line
Tty Typ     Tx/Rx     A Modem  Roty AccO AccI  Uses    Noise   Overruns
   0 CTY               -    -      -    -    -     0        0        0/0
Line 1 is currently invalid
Line 2 is currently invalid
Line 3 is currently invalid
Line 4 is currently invalid
Line 5 is currently invalid
Line 6 is currently invalid
Line 7 is currently invalid
Line 8 is currently invalid
Line 9 is currently invalid
  10 AUX   9600/9600   -    -      -    -    -     0        0        0/0
* 11 VTY   9600/9600   -    -      -    -    -     4        0        0/0
  12 VTY   9600/9600   -    -      -    -    -     0        0        0/0
  13 VTY   9600/9600   -    -      -    -    -     0        0        0/0
  14 VTY   9600/9600   -    -      -    -    -     0        0        0/0
  15 VTY   9600/9600   -    -      -    -    -     0        0        0/0
FRSW.LAB#who
    Line     User      Host(s)               Idle Location
* 11 vty 0   admin     idle                     0 1.1.2.1
FRSW.LAB#
FRSW.LAB#sh ver
IOS (tm) 3000 Software (IGS-I-L), Version 11.0(8), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1996 by cisco Systems, Inc.
Compiled Sat 27-Apr-96 01:23 by vprasad
Image text-base: 0x0301DE2C, data-base: 0x00001000
ROM: System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
ROM: 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(8a), RELEASE SOFTWARE (fc1)
FRSW.LAB uptime is 23 hours, 34 minutes
System restarted by reload
System image file is "flash:ie1108", booted via flash
cisco 2522 (68030) processor (revision M) with 14336K/2048K bytes of memory.
Processor board ID 03850160, with hardware revision 00000002
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
Basic Rate ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
8 Low-speed serial(sync/async) network interfaces.
1 ISDN Basic Rate interface.
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
FRSW.LAB#sh logging
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
    Console logging: level debugging, 124 messages logged
    Monitor logging: level debugging, 0 messages logged
        Logging to: vty11(0)
    Trap logging: disabled
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
transport input all
line vty 0 4
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
12 Replies 12
Richard Burts
David
You have not told us where (and how) you are looking for syslog output. From the output that you posted it looks like logging to the console is enabled and has displayed 124 messages. Were you on the console while things were going on?
From the output that you posted it looks like monitor logging is enabled. Have you done terminal monitor on the session before you start testing?
From what you have posted it looks like buffered logging is not enabled. So the show log command would not display syslog messages.
Rick
Rick
Richard,
thanks for the quick reply.
About the 124 messages i can´t see a single one. when i do show log the only output that i gives me it´s this:
FRSW.LAB(config)#logg
FRSW.LAB(config)#logging on
FRSW.LAB(config)#logging console debugging
FRSW.LAB(config)#logging buffered 20000
FRSW.LAB(config)#logging monitor debugging
FRSW.LAB#term mon
FRSW.LAB#
FRSW.LAB#sh log
nothing more. I have tried to configured in all forms but i simply can´t see messages from this router. From term mon to logging everything i just can´t see any type of messages.
Any more ideias? I doing something wrong... :X
David
You show this command as if you have entered it
but the output that you posted implies that it has not been entered. Can you clarify this?
I would suggest this as a quick test:
- in global config mode enter the logging buffered command.
- if you are not on the console, then enter the terminal monitor command
- go into config mode
configure terminal
- exit config mode
exit
- the console or the terminal monitor show display a message about router configured ...
- show logging should now display the message about router configured
try that and let us know what happens.
Rick
Rick
Richard,
FRSW.LAB#conf term
Enter configuration commands, one per line.  End with CNTL/Z.
FRSW.LAB(config)#
FRSW.LAB(config)#
FRSW.LAB#
FRSW.LAB#
FRSW.LAB#term mon
FRSW.LAB#
FRSW.LAB#
FRSW.LAB#conf term
FRSW.LAB(config)#inter ser
FRSW.LAB(config)#inter serial 8
FRSW.LAB(config-if)#sh
FRSW.LAB(config-if)#no sh
FRSW.LAB#
FRSW.LAB#
FRSW.LAB#sh logging
        Logging to: vty11(0) vty12(0)
FRSW.LAB#
and last but not the least,
FRSW.LAB#sh privilege
Current privilege level is 15
FRSW.LAB#
I  can´t see any thing . This is weird!
David
That is very strange. Thanks for showing exactly what you had done - and the lack of logging.
Can you post the complete config? Perhaps there is something there that I am not expecting?
Rick
Rick
here´s the full configuration:
FRSW.LAB#sh run
Building configuration...
Current configuration:
version 11.0
service timestamps debug uptime
service timestamps log uptime
no service udp-small-servers
no service tcp-small-servers
hostname FRSW.LAB
aaa new-model
aaa authentication login default local
aaa authentication login none none
aaa authorization exec local
enable secret 5 $1$8e2H$Pp8XasdasdasdxaPFROxnwdasasd1
username admin nocallback-verify callback-dialstring "" password 7 *password removed*
username student nocallback-verify callback-dialstring "" password 7 *password removed*
no ip domain-lookup
frame-relay switching
interface Ethernet0
description !! NAO ALTERAR ESTE INTERFACE !!
ip address 1.1.1.5 255.255.255.0
interface Serial0
description Connected to R1
no ip address
encapsulation frame-relay
clockrate 64000
frame-relay intf-type dce
frame-relay route 102 interface Serial1 201
frame-relay route 103 interface Serial2 301
frame-relay route 104 interface Serial4 401
frame-relay route 105 interface Serial5 501
frame-relay route 113 interface Serial3 311
interface Serial1
description Connected to R2
no ip address
clockrate 64000
frame-relay route 201 interface Serial0 102
frame-relay route 203 interface Serial2 302
frame-relay route 204 interface Serial4 402
frame-relay route 205 interface Serial5 502
frame-relay route 213 interface Serial3 312
interface Serial2
description Connected to R3 S1/0
no ip address
clockrate 64000
frame-relay route 301 interface Serial0 103
frame-relay route 302 interface Serial1 203
frame-relay route 304 interface Serial4 403
frame-relay route 305 interface Serial5 503
interface Serial3
description Connected to R3 S1/1
no ip address
clockrate 64000
frame-relay route 311 interface Serial0 113
frame-relay route 312 interface Serial1 213
frame-relay route 314 interface Serial4 413
frame-relay route 315 interface Serial5 513
interface Serial4
description Connected to R4
no ip address
clockrate 64000
frame-relay route 401 interface Serial0 104
frame-relay route 402 interface Serial1 204
frame-relay route 403 interface Serial2 304
frame-relay route 405 interface Serial5 504
frame-relay route 413 interface Serial3 314
interface Serial5
description Connected to R5
no ip address
clockrate 64000
frame-relay route 501 interface Serial0 105
frame-relay route 502 interface Serial1 205
frame-relay route 503 interface Serial2 305
frame-relay route 504 interface Serial4 405
frame-relay route 513 interface Serial3 315
interface Serial6
no ip address
frame-relay route 611 interface Serial8 116
interface Serial7
interface Serial8
description LIGADO R3 S0/0/1
no ip address
clockrate 64000
frame-relay route 116 interface Serial6 611
interface Serial9
description LIGADO R5
no ip address
clockrate 64000
interface BRI0
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 1.1.2.0 255.255.255.0 1.1.1.1
logging buffered
no logging trap
banner motd ^C
^C
alias exec sir sh ip route
alias exec si sh ip int brief
alias exec showrun ere
privilege interface level 15 frame-relay
privilege interface level 15 description
privilege configure level 15 interface
privilege exec level 15 copy running-config startup-config
privilege exec level 15 configure terminal
privilege exec level 15 clear line
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
transport input all
line vty 0 4
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
end
FRSW.LAB#
David
Thanks for posting the config. I would suggest trying this in the config
logging trap info
Give that a try and let us know if it changes things.
Rick
Rick
Richard,
i´ve changed the configuration to
FRSW.LAB(config)#logging trap informational
FRSW.LAB#sh logging
    Trap logging: level informational, 128 message lines logged
same output as allways!! Nothing in sight.
David
Thank you for trying all of my suggestions. At this point I do not have a good explanation of what is causing the problem and am beginning to think about buggy behavior. I wonder if a router reboot would change the symptoms.
Rick
Rick
I´ve done it!
Every time i change a setting in the logging configuration i have to reload the switch to take efect.
Case solved!
David
I am still puzzled at what is causing this.
But at this point I am happy to have a case solved
Rick
Rick
Richard,
thanks for all but for know i don´t want to troubleshoot hardware to the max. I hope that everything else works correct
Thanks for all again!
