Cant ping firewall...
harrisgirls
I have just setup a 2650 hp switch, the IP of the firewall is 10.52.100.123............I can ping fine........if I put a workstation in this vlan (id 100) i can ping firewall and access the internet fine.
Now if I am in a different vlan, say vlan 16 I cannot ping the firewall ip but can ping the vlan default gateway 10.52.100.254, my config is below of the switch:
Startup configuration:
; J4899A Configuration Editor; Created on release #H.10.83
hostname "bmi-2650-core1"
max-vlans 50
time daylight-time-rule Western-Europe
console inactivity-timer 15
interface 49
   no lacp
exit
interface 50
   no lacp
exit
trunk 49-50 Trk1 LACP
ip routing
timesync sntp
sntp unicast
snmp-server community "public" Unrestricted
vlan 1
   name "DEFAULT_VLAN"
   untagged 3-46,Trk1
   ip address dhcp-bootp
   no untagged 1-2,47-48
   exit
vlan 100
   name "bmi_fwall"
   untagged 47-48
   ip address 10.52.100.254 255.255.255.0
   tagged Trk1
   ip igmp
   exit
vlan 10
   name "bmi_svr"
   untagged 2
   ip address 10.52.10.254 255.255.255.0
   tagged Trk1
   ip igmp
   exit
vlan 16
   name "bmi_wired"
   untagged 1
   ip address 10.52.16.254 255.255.255.0
   ip helper-address 10.52.10.1
   ip helper-address 10.52.10.2
   tagged Trk1
   ip igmp
   exit
vlan 20
   name "bmi_guestw"
   ip address 10.52.20.254 255.255.255.0
   tagged Trk1
   ip igmp
   exit
vlan 25
   name "bmi_wless"
   ip address 10.52.25.254 255.255.255.0
   tagged Trk1
   ip igmp
   exit
vlan 40
   name "bmi_print"
   ip address 10.52.40.254 255.255.255.0
   tagged Trk1
   ip igmp
   exit
vlan 90
   name "bmi_cctv"
   ip address 10.52.90.254 255.255.255.0
   tagged Trk1
   ip igmp
   exit
vlan 5
   name "bmi_mgmt"
   ip address 10.52.5.254 255.255.255.0
   tagged Trk1
   ip igmp
   exit
vlan 167
   name "VLAN167"
   exit
ip route 0.0.0.0 0.0.0.0 10.52.100.123
spanning-tree
spanning-tree Trk1 priority 4
spanning-tree priority 0
password manager
password operator
bmi-2650-core1(vlan-100)#
I've added the static-route to the firewall 10.52.0.0, if I telnet to the switch I can ping 10.52.100.123 fine
this is from the firewall (pix 515): when I try and ping 10.52.100.123 from 10.52.16.222 (ip of workstation):
Teardown ICMP connection for faddr 10.52.16.222/1 gaddr 10.52.100.123/0 laddr 10.52.100.123/0
0 Replies 0
