2600 flash upgrade tftpdnld problem
turnermr
I have just upgraded the flash and bootrom on my 2621 but when I run tftpdnld from rommon I get the message Missing or illegal ip address for variable IP_ADDRESS
I have set all of the required variables and obviously checked the syntax on the ip address but to no avail, any ideas?
many thanks
In a recent posting about tftpdnld someone made the point that the variables must be configured with the variable names in capital letters, and that lower case will not work. It has been a long time since I had to use tftpdnld and I do not remember if that was the case. Give it a try using captial letters and let us know if that helps.
Rick
Rick
Josef Oduwo
Level 7
Level 7
Could you leave some more info, especially on the IP addressing and "required variables"?
Josef.
hi josef
thanks for the reply
it is configured as follows
PS1=rommon ! >
ip_subnet_mask=255.255.000.000
default_gateway=150.14.185.1
tftp_server=150.14.100.123
tftp_file=c2600-is-mz.122-15.t16.bin
ip_address=150.014.125.200
fe_speed_mode=3
?=1
I have also tried it without the leading zeros
thanks Mark
Rick
Rick
many thanks Rick that has sorted it!
