2600 showing no interfaces
midhungopi
i loaded a 2610 xm with a c2600-c-mz.122-4.T1 and after booting it s not showing any of the onboard interfaces..
it was also showing an error on booting up If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 4Mb.
zhiqiang.yan
I think that is a wrong IOS, you are using a 2610"XM",
find a IOS can use for "XM"
olorunloba
Level 5
Level 5
Are you sure that image is officially supported on the 2610XM. I have a feeling that it is not.
Also, unless any of the memory requirements state unknown, the above message is normal
