2610XM Router Ping FastEthernet Failure
Israel Logan
Please help.. is my 2610XM dead?   I can ping the fa0/0 ip address I assigned to the apparently bad 2610XM but no other device can ping it.  mac address doesn't show up in other devices after pinging the apparently dead 2610XM.  show interface fa0/0 looks identical to routers that are working (up/up).  All ip addresses are in the same subnet.
So... is there some way to activate the fa0/0 port to the outside world?  Is there some other way to verify that it is dead?  Attached "show tech-support" of each router.  And below
Bad Router INFO:
------------------ show version ------------------
IOS (tm) C2600 Software (C2600-IPBASE-M), Version 12.3(6c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 20-Jul-04 05:24 by kellythw
Image text-base: 0x80008098, data-base: 0x80ED06CC
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
2610a uptime is 2 hours, 15 minutes
System image file is "flash:c2600-ipbase-mz.123-6c.bin"
cisco 2610XM (MPC860P) processor (revision 0x401) with 126976K/4096K bytes of memory.
Processor board ID JMX0904L2RZ (60138634)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
------------------ show running-config ------------------
Building configuration...
Current configuration : 666 bytes
version 12.3
service password-encryption
hostname 2610a
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface FastEthernet0/0
ip address 192.168.1.15 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial0/1
no ip address
shutdown
ip classless
ip http server
line con 0
password 7 <removed>
login
line aux 0
line vty 0 4
login
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size   Name
9752/12000  Setup
5076/6000   Autoinstall
11536/12000  BootP Resolver
4416/6000   DNS Snoop
11100/12000  DHCP Autoinstall
5620/6000   SPAN Subsystem
9400/12000  Init
5456/6000   RADIUS INITCONFIG
9356/12000  Exec
Interrupt level stacks:
Level    Called Unused/Size  Name
  1        1811   8576/9000  Network interfaces
  2           0   9000/9000  Timebase Reference Interrupt
  3           0   9000/9000  PA Management Int Handler
  6        8992   8880/9000  16552 Con/Aux Interrupt
  7     2035764   8920/9000  MPC860 TIMER INTERRUPT
------------------ show interfaces ------------------
FastEthernet0/0 is up, line protocol is up
  Hardware is AmdFE, address is 0013.1959.bc80 (bia 0013.1959.bc80)
  Internet address is 192.168.1.15/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:23, output 00:00:08, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     385 packets input, 27307 bytes
     Received 385 broadcasts, 0 runts, 1 giants, 0 throttles
     0 watchdog
     1018 packets output, 177052 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     216 lost carrier, 0 no carrier
Serial0/0 is administratively down, line protocol is down
  Hardware is PowerQUICC Serial
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 02:14:56
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 carrier transitions
     DCD=down  DSR=down  DTR=down  RTS=down  CTS=down
Serial0/1 is administratively down, line protocol is down
  Hardware is PQUICC with Fractional T1 CSU/DSU
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     DCD=down  DSR=up  DTR=down  RTS=down  CTS=down
------------------ show controllers ------------------
Interface FastEthernet0/0
Hardware is AMD Am79c977
ADDR: 8198997C, FASTSEND: 800A9034, MCI_INDEX: 0
DIST ROUTE ENABLED: 0
Route Cache Flag: 11
LADRF=0x0000 0x0100 0x0000 0x0000
CSR0  =0x00000042, CSR3  =0x00000004, CSR4  =0x0000080C, CSR15 =0x00000000
CSR80 =0x00001800, CSR114=0x00000000, CRDA  =0x00000000, CXDA  =0x00000000
BCR9 =0x00000001
CSR5  =0x00000001, CSR7  =0x00000008, CSR100=0x00000000, CSR125=0x00005C3C
BCR2  =0x00001000, BCR9  =0x00000001, BCR18 =0x00001880, BCR22 =0x00001818
BCR25 =0x00000200, BCR26 =0x00000100, BCR27 =0x00000000, BCR32 =0x00004D80
HW filtering information:
  Promiscuous Mode Disabled, PHY Addr Enabled, Broadcast Addr Enabled
  PHY Addr=0013.1959.BC80, Multicast Filter=0x0000 0x0100 0x0000 0x0000
amdp2_instance=0x8198BDBC, registers=0x40000000, ib=0x7D17540
rx ring entries=64, tx ring entries=128
rxring=0x7D175A0, rxr shadow=0x8198C02C, rx_head=53, rx_tail=0
txring=0x7D179E0, txr shadow=0x8198C158, tx_head=50, tx_tail=50, tx_count=0
Software MAC address filter(hash:length/addr/mask/hits):
  0xC0:  0  0100.0ccc.cccc  0000.0000.0000         0
spurious_idon=0, throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=0
rx_bpe_err=0, rx_soft_overflow_err=0, rx_no_enp=0, rx_discard=0
tx_one_col_err=0, tx_more_col_err=0, tx_no_enp=0, tx_deferred_err=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=216
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
hsrp_conf=0, need_af_check=0
tx_limited=0(64)
PHY registers:
  Register 0x00:   1000  782D  0013  78E2  01E1  4D81  0007  2001
  Register 0x08:   0000  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF  FFFF
  Register 0x10:   0104  4780  0000  00F4        0000  0000  0000
  Register 0x18:   0000  0000  01C8  0000  FFFF
Interface Serial0/0
Hardware is PowerQUICC MPC860
DTE V.35 clocks stopped.
idb at 0x81991114, driver data structure at 0x81998EB0
SCC Registers:
General [GSMR]=0x2:0x00000000, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x0000, Status [SCCS]=0x00
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x0000C800
Mask   [CIMR]=0x00200000, In-srv  [CISR]=0x00000000
Command register [CR]=0x540
Port A [PADIR]=0x0000, [PAPAR]=0xFFFF
       [PAODR]=0x0000, [PADAT]=0xF6FE
Port B [PBDIR]=0x03A0F, [PBPAR]=0x0200E
       [PBODR]=0x00000, [PBDAT]=0x3FFDD
Port C [PCDIR]=0x00C, [PCPAR]=0x000
       [PCSO]=0x0A0,  [PCDAT]=0xFF0, [PCINT]=0x00F
Receive Ring
rmd(680126B0): status 9000 length 60C address 7C47F44
rmd(680126B8): status 9000 length 60C address 7C478C4
rmd(680126C0): status 9000 length 60C address 7C47244
rmd(680126C8): status 9000 length 60C address 7C66984
rmd(680126D0): status 9000 length 60C address 7C66304
rmd(680126D8): status 9000 length 60C address 7C65C84
rmd(680126E0): status 9000 length 60C address 7C65604
rmd(680126E8): status 9000 length 60C address 7C64F84
rmd(680126F0): status 9000 length 60C address 7C64904
rmd(680126F8): status 9000 length 60C address 7C64284
rmd(68012700): status 9000 length 60C address 7C63C04
rmd(68012708): status 9000 length 60C address 7C63584
rmd(68012710): status 9000 length 60C address 7C62F04
rmd(68012718): status 9000 length 60C address 7C62884
rmd(68012720): status 9000 length 60C address 7C62204
rmd(68012728): status 9000 length 60C address 7C61B84
rmd(68012730): status 9000 length 60C address 7C61504
rmd(68012738): status 9000 length 60C address 7C60E84
rmd(68012740): status 9000 length 60C address 7C60804
rmd(68012748): status 9000 length 60C address 7C60184
rmd(68012750): status 9000 length 60C address 7C5FB04
rmd(68012758): status 9000 length 60C address 7C5F484
rmd(68012760): status 9000 length 60C address 7C5EE04
rmd(68012768): status B000 length 60C address 7C5E784
Transmit Ring
tmd(68012770): status 0 length 0 address 0
tmd(68012778): status 0 length 0 address 0
tmd(68012780): status 0 length 0 address 0
tmd(68012788): status 0 length 0 address 0
tmd(68012790): status 0 length 0 address 0
tmd(68012798): status 0 length 0 address 0
tmd(680127A0): status 0 length 0 address 0
tmd(680127A8): status 0 length 0 address 0
tmd(680127B0): status 0 length 0 address 0
tmd(680127B8): status 0 length 0 address 0
tmd(680127C0): status 0 length 0 address 0
tmd(680127C8): status 0 length 0 address 0
tmd(680127D0): status 0 length 0 address 0
tmd(680127D8): status 0 length 0 address 0
tmd(680127E0): status 0 length 0 address 0
tmd(address 0
tx_limited=0(16)
SCC GENERAL PARAMETER RAM (at 0x68013C00)
Rx BD Base [RBASE]=0x26B0, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x2770, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x0, BD Ptr [RBPTR]=0x26B0
Tx State [TSTATE]=0x4000, BD Ptr [TBPTR]=0x2770
SCC HDLC PARAMETER RAM (at 0x68013C38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1608
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=0
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
0 aborted short frames
Interface Serial0/1
Hardware is PowerQUICC MPC860 with Integrated FT1 CSU/DSU module
TX and RX clocks detected.
idb at 0x8199ADCC, driver data structure at 0x819A2B68
SCC Registers:
Events [SCCE]=0x0000, Mask [SCCM]=0x0000, Status [SCCS]=0x03
Receive Ring
rmd(680127F0): status 9000 length 60C address 7C5E104
rmd(680127ess 7C5DA84
rmd(68012800): status 9000 length 60C address 7C5D404
rmd(68012808): status 9000 length 60C address 7C5CD84
rmd(68012810): status 9000 length 60C address 7C5C704
rmd(68012818): status 9000 length 60C address 7C5C084
rmd(68012820): status 9000 length 60C address 7C5BA04
rmd(68012828): status 9000 length 60C address 7C5B384
rmd(68012830): status 9000 length 60C address 7C5AD04
rmd(68012838): status 9000 length 60C address 7C5A684
rmd(68012840): status 9000 length 60C address 7C5A004
rmd(68012848): status 9000 length 60C address 7C59984
rmd(68012850): status 9000 length 60C address 7C59304
rmd(68012858): status 9000 length 60C address 7C58C84
rmd(68012860): status 9000 length 60C address 7C58604
rmd(68012868): status 9000d(68012870): status 9000 length 60C address 7C57904
rmd(68012878): status 9000 length 60C address 7C57284
rmd(68012880): status 9000 length 60C address 7C769C4
rmd(68012888): status 9000 length 60C address 7C76344
rmd(68012890): status 9000 length 60C address 7C75CC4
rmd(68012898): status 9000 length 60C address 7C75644
rmd(680128A0): status 9000 length 60C address 7C74FC4
rmd(680128A8): status B000 length 60C address 7C74944
Transmit Ring
tmd(680128B0): status 0 length 0 address 0
tmd(680128B8): status 0 length 0 address 0
tmd(680128C0): status 0 8): status 0 length 0 address 0
tmd(680128D0): status 0 length 0 address 0
tmd(680128D8): status 0 length 0 address 0
tmd(680128E0): status 0 length 0 address 0
tmd(680128E8): status 0 length 0 address 0
tmd(680128F0): status 0 length 0 address 0
tmd(680128F8): status 0 length 0 address 0
tmd(68012900): status 0 length 0 address 0
tmd(68012908): status 0 length 0 address 0
tmd(68012910): status 0 length 0 address 0
tmd(68012918): status 0 length 0 address 0
tmd(68012920): status 0 length 0 address 0
tmd(68012928): status 2000 length 0 address 0
tx_limited=1(2)
SCC GENERAL PARAMETER RAM (at 0x68013D00)
Rx BD Base [RBASE]=0x27F0, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x28B0, Fn Code [TFCR]=0x18
Rx State [RSTATE]=0x0, BD Ptr [RBPTR]=0x27F0
Tx State [TSTATE]=0x4000, BD Ptr [TBPTR]=0x28B0
SCC HDLC PARAMETER RAM (at 0x68013D38)
buffer size 1524
0 overruns
------------------ show file systems ------------------
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
       29688       27588     nvram     rw   nvram:
           -           -    opaque     rw   system:
           -           -    opaque     rw   null:
           -           -   network     rw   tftp:
*   33030144    23748064     flash     rw   flash:
           -           -   network     rw   rcp:
           -           -   network     rw   ftp:
           -           -    opaque     ro   cns:
------------------ dir nvram: ------------------
Directory of nvram:/
   27  -rw-           0                    <no date>  startup-config
   28  ----           0                    <no date>  private-config
    1  -rw-           0                    <no date>  ifIndex-table
    2  ----          12                    <no date>  persistent-data
29688 bytes total (27588 bytes free)
------------------ show flash: all ------------------
Partition   Size    Used      Free      Bank-Size  State  Copy Mode
  1        32256K   9064K    23191K    16384K      Read/Write   Direct
System flash directory:
File  Length   Name/status
        addr      fcksum  ccksum
  1   9282016  c2600-ipbase-mz.123-6c.bin
        0x40      0xCFFE  0xCFFE
[9282080 bytes used, 23748064 available, 33030144 total]
   Chip    Bank    Code      Size      Name
    1      1       8917      8192KB    INTEL 28F640J3
    2      1       8917      8192KB    INTEL 28F640J3
    1      2       8917      8192KB    INTEL 28F640J3
    2      2       8917      8192KB    INTEL 28F640J3
------------------ show memory statistics ------------------
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor   8186FEE4   105050476     4885004   100165472   100070116    99275388
      I/O    7C00000     4194304     1772592     2421712     2421712     2421664
------------------ show process memory ------------------
Total: 105050476, Used: 4885004, Free: 100165472
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0     146640      10892    2722748
   0   0        752     105088        752          0          0 *Sched*
   0   0    8162556    2757948     156560     165528          0 *Dead*
   1   0          0          0       6892          0          0 Chunk Manager
   2   0        188        188       3892          0          0 Load Meter
   3   0     144824     143816      22396          0          0 Exec
   4   0          0          0       6892          0          0 Check heaps
   5   0          0          0       6892          0          0 Pool Manager
   6   0          0          0       6892          0          0 AAA_SERVER_DEADT
   7   0        188        188       6892          0          0 Timers       188       6892          0          0 Environmental mo
   9   0          0          0       6892          0          0 ARP Input
  10   0        188        188       6892          0          0 ATM Idle Timer
  11   0        188        188       6892          0          0 AAA high-capacit
  12   0        188        188       6892          0          0 DDR Timers
  13   0       6196       1664      11424          0          0 Entity MIB API
  14   0          0          0       6892          0          0 HC Counter Timer
  15   0        188        188       6892          0          0 Serial Backgroun
  16   0        188        188       6892          0          0 GraphIt
  17   0        188        188      12892          0          0 Dialer event
  18   0          0          0       6892          0          0 SERIAL A'detect
  19   0          0          0       6892          0          0 Critical Bkgnd
  20   0      20940          0      13156          0          0 Net Background
  21   0        188        188      12892          0          0 Logger
  22   0      39256        408       7028          0          0 TTY Background
  23   0          0          0       9892          0          0 Per-Second Jobs
  24   0          0          0       6892          0          0 AggMgr Process
  25   0          0          0       3892          0          0 dev_device_inser
  26   0          0          0       3892          0          0 dev_device_remov
  27   0          0          0      12892          0          0 sal_dpc_process
  28   0          0          0       6892          0          0 ARL Table Manage
  29   0        220        220       6892          0          0 ESWILPPM
  30   0        188        188       6892          0          0 SM Monitor
  31   0          0          0       6892          0          0 Net Input
  32   0        188        188       6892          0          0 Compute load avg
  33   0          0          0       6892          0          0 Per-minute Jobs
  34   0          0          0       6892          0          0 Service-module a
  35   0       2380        188       9084          0          0 DTP Protocol
  36   0        188        188       6892          0          0 PI MATM Aging Pr
  37   0        188        188       6892          0          0 EtherChnl
  38   0       9020       1632      14280          0          0 VLAN Manager
  39   0        188        188       6892          0          0 AAA Dictionary R
  40   0        188        188       6892          0          0 AAA Server
  41   0          0          0       6892          0          0 AAA ACCT Proc
  42   0          0          0       6892          0          0 ACCT Periodic Pr
  43   0        556        188       7260          0          0 CDP Protocol
  44   0          0          0      12892          0          0 IP Input
  45   0          0          0       6892          0          0 ICMP event handl
  46   0        188        188       6892          0          0 MOP Protocols
  47   0        408        408      12892          0          0 PPP Hooks
  48   0          0          0      12892          0          0 SSS Manager
  49   0          0          0      12892          0          0 SSS Test Client
  50   0          0          0      12892          0          0 VPDN call manage
  51   0          0          0       6892          0          0 X.25 Encaps Mana
  52   0         76          0       9968          0          0 IP Background
  53   0        152          0      10044          0          0 IP RIB Update
  54   0        188        188      12892          0          0 PPP IP Route
  55   0        188        188      12892          0          0 PPP IPCP
  56   0          0          0       6892          0          0 Asy FS Helper
  57   0      74976       1524      73716          0          0 CEF process
  58   0          0          0      12892          0          0 TCP Timer
  59   0          0          0      12892          0          0     0          0      24892          0          0 COPS
  61   0          0          0       6892          0          0 SNMP Timers
  62   0    1055088        188    1054900          0          0 SCTP Main Proces
  63   0          0          0       6892          0          0 IUA Main Process
  64   0        188        188       6892          0          0 RUDPV1 Main Proc
  65   0          0          0       6920          0          0 bsm_timers
  66   0          0          0       6892          0          0 bsm_xmt_proc
  67   0          0          0       6892          0          0 Socket Timers
  68   0      29800        188      22720          0          0 DHCPD Receive
  69   0        188        188       6892          0          0 Dialer Forwarder
  70   0        188        188       9892          0          0 Adj Manager
  71   0       4060          0      13952          0          0 HTTP CORE
  72   0          0          0       6892          0          0 IP Cache Ager
  73   0          0          0       6892          0          0 RARP Input
  74   0          0          0       6892          0          0 PAD InCall
  75   0        188        188      12892          0          0 X.25 Background
  76   0        188        188       6892          0          0 PPP Bind
  77   0        188        188       6892          0          0 PPP SSS
  78   0        188        188       6892          0          0 CRM_CALL_UPDATE_
  79   0        188        188       6892          0          0 ENABLE AAA
  80   0        188        188       6892          0          0 LINE AAA
  81   0        188        188       6892          0          0 LOCAL AAA
  83   0       2072        188       8776          0          0 TPLUS
  84   0        188        188       3892          0          0 Inline Power
  85   0          0          0       6892          0          0 PM Callback
  86   0          0          0       6892          0          0 DHCPD Timer
  87   0        188        188       6892          0          0 AAA SEND STOP EV
  88   0          0          0       6892          0          0 Syslog Traps
  89   0          0          0       6892          0          0 VPDN Scal
  90   0        188        188       6892          0          0 fastblk backgrou
  91   0        188          0       7080          0          0 DHCPD Database
  92   0          0      25740       9892          0          0 DHCP Client
  94   0        152          0       7044          0          0 CEF Scanner
  96   0       5232        188      17936          0          0 PPP manager
  97   0        188        188      12892          0          0 PPP Event    188       6892          0          0 Multilink PPP
  99   0        188        188       6892          0          0 Multilink event
100   0          0          0       6892          0          0 FR LMI
101   0          0          0       6892          0          0 FR Broadcast Out
102   0        188        188       6892          0          0 compute load per
103   0          0          0       6892          0          0 FR ARP
104   0          0          0       6892          0          0 FR FRAGMENTATION
105   0          0          0       6892          0          0 FRF9 manager
106   0          0          0       6892          0          0 FRF9 timed event
                                  4882564 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 0%/0%; one minute: 3%; five minutes: 1%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         1          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2           0      1535      oad Meter
   3        2694        68      39617  0.55%  3.04%  0.82%   0 Exec
   4        4087       963       4244  0.00%  0.06%  0.05%   0 Check heaps
   5           0         1          0  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
   8           0       257          0  0.00%  0.00%  0.00%   0 Environmental mo
   9          12       144         83  0.00%  0.00%  0.00%   0 ARP Input
  10           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  11           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  12           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  13           4         2       2000  0.00%  0.00%  0.00%       0       409          0  0.00%  0.00%  0.00%   0 HC Counter Timer
  15           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  16           4      7659          0  0.00%  0.00%  0.00%   0 GraphIt
  17           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  18           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  19           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  20           4      2300          1  0.00%  0.00%  0.00%   0 Net Background
  21           4        27        148  0.00%  0.00%  0.00%   0 Logger
  22          16      7656          2  0.00%  0.00%  0.00%   0 TTY Background
  23           4      8163          0  0.00%  0.00%  0.00%   0 Per-Second Jobs
  24           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  25           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  26           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  27           0         1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  28           0         1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
  29           0         2          0  0.00%  0.00%  0.00%   0 ESWILPPM
  30           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  31           0        24          0  0.00%  0.00%  0.00%   0 Net Input
  32           0      1537          0  0.00%  0.00%  0.00%   0 Compute load avg
  33        4360       137      31824  0.00%  0.05%  0.00%   0 Per-minute Jobs
  34           0         5          0  0.00%  0.00%  0.00%   0 Service-module a
  35           4         2       2000  0.00%  0.00%  0.00%   0 DTP Protocol
  36           0      7661          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  37           0       768          0  0.00%  0.00%  0.00%   0 EtherChnl
  38           4         2       2000  0.00%  0.00%  0.00%   0 VLAN Manager
  39           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  40           0         2          0  0.00%  0.00%  0.00%   0 AAA Server
  41           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  42           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  43           4       770          5  0.00%  0.00%  0.00%   0 CDP Protocol
  44          28       173        161  0.00%  0.00%  0.00%   0 IP Input
  45           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  46           0        15          0  0.00%  0.00%  0.00%   0 MOP Protocols
  47           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  48           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  49           0      1091          0  0.00%  0.00%  0.00%   0 SSS Test Client
  50           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  51           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  52         561       170       3300  0.00%  0.00%  0.00%   0 IP Background
  53           8        10        800  0.00%  0.00%  0.00%   0 IP RIB Update
  54           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  55           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  56           0         1          0  0.00%  0.00%  0.00%   0 Asy FS Helper
  57          24     12260          1  0.00%  0.00%  0.00%   0 CEF process
  58           0         1          0  0.00%  0.00%  0.00%   0 TCP Timer
  59           0         1          0  0.00%  0.00%  0.00%   0 TCP Protocols
  60           0         1          0  0.00%  0.00%  0.00%   0 COPS
  61           0         1          0  0.00%  0.00%  0.00%   0 SNMP Timers
  62          68         2      34000  0.00%  0.00%  0.00%   0 SCTP Main   1          0  0.00%  0.00%  0.00%   0 IUA Main Process
  64           0      7664          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
  65           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
  66           8      8164          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
  67           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
  68           4         2       2000  0.00%  0.00%  0.00%   0 DHCPD Receive
  69           4         2       2000  0.00%  0.00%  0.00%   0 Dialer Forwarder
  70           0       129          0  0.00%  0.00%  0.00%   0 Adj Manager
  71           4        29        137  0.00%  0.00%  0.00%   0 HTTP CORE
  72           0       137          0  0.00%  0.00%  0.00%   0 IP Cache Ager
  73           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  74           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
  75           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
  76           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
  77           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
  78           0       329          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
  79           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
  80           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
  81           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
  83           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
  84           0     12766          0  0.00%  0.00%  0.00%   0 Inline Power
  85           0         1          0  0.00%  0.00%  0.00%   0 PM Callback
  86           0        64          0  0.00%  0.00%  0.00%   0 DHCPD Timer
  87           0         2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
  88           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
  89           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
  90           4     76602          0  0.00%  0.00%  0.00%   0 fastblk backgrou
  91           4      2166          1  0.00%  0.00%  0.00%   0 DHCPD Database
  92           0       223          0  0.00%  0.00%  0.00%   0 DHCP Client
  94           4       283         14  0.00%  0.00%  0.00%   0 CEF Scanner
  96          24    239741          0  0.00%  0.00%  0.00%   0 PPP manager
  97           4    239741          0  0.00%  0.00%  0.00%   0 PPP Events
  98           0      7667          0  0.00%  0.00%  0.00%   0 Multilink PPP
  99           0         2          0  0.00%  0.00%  0.00%   0 Multilink event
100           0         1          0  0.00%  0.00%  0.00%   0 FR LMI
101           0     81462          0  0.00%  0.00%  0.00%   0 FR Broadcast Out
102           0      1537          0  0.00%  0.00%  0.00%   0 compute load per
103           0         1          0  0.00%  0.00%  0.00%   0 FR ARP
104           0       137          0  0.00%  0.00%  0.00%   0 FR FRAGMENTATION
105           0         1          0  0.00%  0.00%  0.00%   0 FRF9 manager
106           0         1          0  0.00%  0.00%  0.00%   0 FRF9 timed event
------------------ show process cpu history ------------------
2610a   02:16:34 AM Monday Mar 1 1993 UTC
                                 1111122222
    111111111     7777711111222224444499999
100
90
80
70
60
50
40
30                                   *****
20                                   *****
10               *****          **********
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
                                               1   11        1
100
90
80
70
60
50
40
30
20
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
100
90
80
70
60
50
40
30  *
20  *
10  *
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
------------------ show context ------------------
No valid exception information to display.
------------------ show diag ------------------
Slot 0:
C2610XM 1FE Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision        : 4.1
PCB Serial Number        : JMX0904L2RZ (60138634)
Part Number              : 73-7677-06
RMA History              : 00
RMA Number               : 0-0-0-0
Board Revision           : B0
Deviation Number         : 0-0
EEPROM format version 4
EEPROM contents (hex):
  0x00: 04 FF 40 03 6A 41 04 01 C1 16 4A 4D 58 30 39 30
  0x10: 34 4C 32 52 5A 20 28 36 30 31 33 38 36 33 34 29
  0x20: 82 49 1D FD 06 04 00 81 00 00 00 00 42 42 30 80
  0x30: 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
  0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Serial 1T WAN daughter card
Hardware revision 1.0         Board revision B0
Serial number     35066469  Part number    800-01514-02
Test history      0x0         RMA numbe   Wan Module
EEPROM format version 1
  0x20: 01 02 01 00 02 17 12 65 50 05 EA 02 00 00 00 00
  0x30: 58 00 00 00 06 07 02 01 FF FF FF FF FF FF FF FF
WIC Slot 1:
FT1 PMC4351
Hardware Revision        : 1.2
PCB Serial Number        : FOC092301A8
Part Number              : 73-8346-05
Board Revision           : A0
RMA Test History         : 00
RMA History              : 00
Product (FRU) Number     : WIC-1DSU-T1-V2
Top Assy. Part Number    : 800-22193-03
CLEI Code                : IPUIAPRRAA
  0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 30 39 32
  0x10: 33 30 31 41 38 82 49 20 9A 05 42 41 30 03 00 81
  0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
  0x30: 2D 31 44 53 55 2D 54 31 2D 56 32 20 20 20 20 20
  0x40: 20 C0 46 03 20 00 56 B1 03 C6 8A 49 50 55 49 41
  0x50: 50 52 52 41 41 FF FF FF FF FF FF FF FF FF FF FF
------------------ show c2600 ------------------
C2600 Platform Information:
Interrupts:
Assigned Handlers...
  Vect  Handler   # of Ints   Name
    00  80124538   00000000   Xilinx bridge error interrupt
    01  8047B444   001F3BB5   MPC860 TIMER INTERRUPT
    02  80118998   00002CB6   16552 Con/Aux Interrupt
    04  8012307C   00000000   PA Network Management Int Handler
    05  80116004   00000000   Timebase Reference Interrupt
    06  801230CC   0000059A   PA Network IO Int Handler
    07  80123190   00000182   MPC860 CPM INTERRUPT
IOS Priority Masks...
  Level 00 = [ EF000000 ]
  Level 01 = [ EC000000 ]
  Level 02 = [ E8000000 ]
  Level 03 = [ E0000000 ]
  Level 04 = [ E0000000 ]
  Level 05 = [ E0000000 ]
  Level 06 = [ C0000000 ]
  Level 07 = [ 00000000 ]
SIU_IRQ_MASK  = FFFFFFFF  SIEN   = EF00xxxx   Current Level = 00
Spurious IRQs = 00000000  SIPEND = 0000xxxx
Interrupt Throttling:
  Throttle Count = 00000000   Timer Count      = 00000000
  Netint usec    = 00000FA0   Netint Mask usec = 000003E8
  Active         =        0   Configured       =        0
  Longest IRQ    = 00000000
IDMA Status:
Requests = 00000386  Drops                = 00000000
Complete = 00000386      Post Coalesce Frames = 00000386
Giant    = 00000000
Available Blocks = 256/256
PLD Status:
PLD version information not available.
DIMM Slot 0:
DIMM Type : Dual-bank
DIMM Size : 128MBytes
DIMM Slot 1:
DIMM Type : EMPTY
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show controllers j1 ------------------
------------------ show buffers ------------------
Buffer elements:
     500 in free list (500 max allowed)
     2198 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50):
     50 in free list (20 min, 150 max allowed)
     1333 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 28, permanent 25, peak 28 @ 02:08:08):
     28 in free list (10 min, 150 max allowed)
     88 hits, 1 misses, 0 trims, 3 created
Big buffers, 1536 bytes (total 50, permanent 50):
     50 in free list (5 min, 150 max allowed)
     433 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
     10 in free list (0 min, 20 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
     0 in free list (0 min, 10 max allowed)
Huge buffers, 18024 bytes (total 0, permanent 0):
     0 in free list (0 min, 4 max allowed)
Interface buffer pools:
CD2430 I/O buffers, 1536 bytes (total 0, permanent 0):
     0 in free list (0 min, 0 max allowed)
     0 hits, 0 fallbacks
Header pools:
Header buffers, 0 bytes (total 137, permanent 128, peak 137 @ 02:16:40):
     9 in free list (10 min, 512 max allowed)
     125 hits, 3 misses, 0 trims, 9 created
     128 max cache size, 128 in cache
     0 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
     128 in free list (128 min, 1024 max allowed)
     256 hits, 0 misses, 0 trims, 0 created
     256 max cache size, 256 in cache
Normal buffers, 1548 bytes (total 512, permanent 512):
     336 in free list (128 min, 1024 max allowed)
     240 hits, 0 misses, 0 trims, 0 created
Private particle pools:
FastEthernet0/0 buffers, 1548 bytes (total 192, permanent 192):
     0 in free list (0 min, 192 max allowed)
     192 hits, 0 fallbacks
     192 max cache size, 128 in cache
     388 hits in cache, 0 misses in cache
Serial0/0 buffers, 1548 bytes (total 48, permanent 48):
     0 in free list (0 min, 48 max allowed)
     48 hits, 0 fallbacks
     48 max cache size, 48 in cache
Serial0/1 buffers, 1548 bytes (total 48, permanent 48):
------------------ show inventory ------------------
NAME: "", DESCR: "2610XM chassis, Hw Serial#: 60138634, Hw Revision: 0x401"
PID:                   , VID:    , SN:
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x07C00000  0x07FFFFFF     4194304  Iomem  R/W    iomem
0x60000000  0x61FFFFFF    33554432  Flash  R/O    flash
0x80000000  0x87BFFFFF   130023424  Local  R/W    main
0x80008098  0x80ED06CB    15500852  IText  R/O    main:text
0x80ED06CC  0x81632DFF     7743284  IData  R/W    main:data
0x81593DB0  0x81632DFF      651344  Local  R/W    data:firmware
0x81632E00  0x8186FEE3     2347236  IBss   R/W    main:bss
0x8186FEE4  0x87BFFFFF   104399132  Local  R/W    main:heap
Good Router INFO:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 15:24 by dchih
Router uptime is 3 hours, 27 minutes
System returned to ROM by reload
System image file is "flash:c2600-is-mz.123-26.bin"
Processor board ID FTX1033A2BA (979235078)
Bridging software.
Current configuration : 662 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip address 192.168.1.12 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
ip http server
ip classless
line con 0
password <removed>
login
line aux 0
line vty 0 4
password <removed>
login
end
Free/Size   Name
4764/6000   Autoinstall
9720/12000  Setup
4424/6000   DNS Snoop
11540/12000  BootP Resolver
11732/12000  DHCP Autoinstall
5624/6000   SPAN Subsystem
2608/3000   allegro libretto init
9396/12000  Init
5460/6000   RADIUS INITCONFIG
2576/3000   Rom Random Update Process
9536/12000  Exec
  1        1915   8184/9000  Network interfaces
  6        2460   8880/9000  16552 Con/Aux Interrupt
  7     3103054   8920/9000  MPC860 TIMER INTERRUPT
  Hardware is AmdFE, address is 0018.b9ed.1500 (bia 0018.b9ed.1500)
  Internet address is 192.168.1.12/24
  Last input 00:00:31, output 00:00:01, output hang never
     241 packets input, 27371 bytes
     Received 209 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     1418 packets output, 112547 bytes, 0 underruns
     921 lost carrier, 0 no carrier
    55, rxload 1/255
  Last clearing of "show interface" counters 03:26:27
ADDR: 82F4A724, FASTSEND: 80024AF8, MCI_INDEX: 0
BCR9 =0x00000001
  PHY Addr=0018.B9ED.1500, Multicast Filter=0x0000 0x0100 0x0000 0x0000
amdp2_instance=0x82F4BEB4, registers=0x40000000, ib=0x7D17540
rxring=0x7D175A0, rxr shadow=0x82F4C40C, rx_head=49, rx_tail=0
txring=0x7D179E0, txr shadow=0x82F4C538, tx_head=3, tx_tail=3, tx_count=0
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=921
tx_limited=0(64)
PHY registers:
  Register 0x10:   0104  4780  0000  00F4        0000  0000  000  01C8  0000  FFFF
Interface Serial0/0
idb at 0x82F50978, driver data structure at 0x82F5874C
SCC Registers:
       [PAODR]=0x0000, [PADAT]=0xF6FF
Receive Ring
Transmit Ring
tmd(680127E8): status 2000 length 0 address 0
tx_limited=1(2)
buffer size 1524
0 overruns
Interface Serial0/1
idb at 0x82F5A68C, driver data structure at 0x82F62460
SCC Registers:
       [PAODR]=0x0000, [PADAT]=0xF0FF
Receive Ring
rmd(680127F8): status 9000 length 60C address 7C5DA84
rmd(68012868): status 9000 length 60C address 7C57F84
rmd(68012870): status 9000 length 60C address 7C57904
Transmit Ring
tmd(680128C0): status 0 length 0 address 0
tmd(680128C8): status 0 length 0 address 0
tx_limited=1(2)
buffer size 1524
0 overruns
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
*  0 con 0                idle                 00:00:19
  Interface    User               Mode         Idle     Peer Address
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
File Systems:
           -           -    opaque     rw   null:
           -           -    opaque     ro   xmodem:
           -           -    opaque     ro   ymodem:
*   33030140    14960008     flash     rw   flash:
           -           -   network     rw   rcp:
           -           -   network     rw   pram:
           -           -   network     rw   ftp:
           -           -    opaque     ro   cns:
  1        32255K  17646K    14609K    16384K      Read/Write   Direct
        addr      fcksum  ccksum
  1   18070068  c2600-is-mz.123-26.bin
        0x40      0xB256  0xB256
[18070132 bytes used, 14960008 available, 33030140 total]
    1      2       8917      819  2       8917      8192KB    INTEL 28F640J3
Processor   82D61720    83519344     6063388    77455956    76913116    75690908
      I/O    7C00000     4194304     1770200     2424104     2421712     2424060
Total: 83519344, Used: 6063544, Free: 77455800
   0   0     763088      10892    3437864          0          0 *Init*
   0   0      12984     125888      12984          0          0 *Sched*
   0   0    9547068    3873220     112248     165528          0 *Dead*
   3   0     369400     310076      72708          0          0 Exec
   4   0      65580          0      90472          0          0 EDDRI_MAIN
   5   0          0          0       6892          0          0 Check heaps
   6   0          0       2344       6892          0       2400 Pool Manager
   8   0        188        188       6892          0          0 Serial Backgroun
   9   0        188        188       6892          0          0 AAA high-capacit
  10   0        188        188       6892          0          0 Environmental mo
  11   0          0          0       6892          0          0 ARP Input
  12   0          0          0       6892          0          0 HC Counter Timer
  13   0        188        188       6892          0          0 DDR Timers
  14   0       6584       1484      11992          0          0 Entity MIB API
  15   0        188        188       6892          0          0 ATM Idle Timer
  16   0          0          0       6892          0          0 SERIAL A'detect
  17   0        188        188       6892          0          0 GraphIt
  18   0        188        188      12892          0          0 Dialer event
  19   0        188        188       6892          0          0 SMART
  20   0          0          0       6892          0          0 Critical Bkgnd
  21   0      20940          0      13156          0          0 Net Background
  22   0        188        188      12892          0          0 Logger
  23   0      52300        544       7028          0          0 TTY Background
  24   0          0          0       9892          0          0 Per-Second Jobs
  25   0          0          0       6892          0          0 AggMgr Process
  26   0        188        188       6892          0          0 SM Monitor
  27   0          0          0       3892          0          0 dev_device_inser
  28   0          0          0       3892          0          0 dev_device_remov
  29   0          0          0       6892          0          0 HDV background
  30   0      25832        188      32592          0          0 VNM DSPRM MAIN
  31   0          0          0       6892          0          0 DSPFARM DSP READ
  32   0       6640          0      13532          0          0 mxt5100
  33   0        188        188       6892          0          0 ESWILPPM
  34   0          0          0      12892          0          0 sal_dpc_process
  35   0          0          0       6892          0          0 ARL 0          0       6892          0          0 Net Input
  37   0        188        188       6892          0          0 Compute load avg
  38   0          0          0       6892          0          0 Per-minute Jobs
  39   0          0          0       6892          0          0 CES Line Conditi
  40   0          0          0      12892          0          0 AAL2CPS TIMER_CU
  41   0          0          0       6892          0          0 Service-module a
  42   0        188        188       6892          0          0 AAA Server
  43   0          0          0       6892          0          0 AAA ACCT Proc
  44   0          0          0       6892          0          0 ACCT Periodic Pr
  45   0          0          0       6892          0          0 AAA_SERVER_DEADT
  46   0        188        188       6892          0          0 AAA Dictionary R
  47   0          0          0      12892          0          0 IP Input
  48   0          0          0       6892          0          0 ICMP event handl
  49   0       4076       3676       7292          0          0 CDP Protocol
  50   0        440        440      12892          0          0 PPP Hooks
  52   0          0          0      12892          0          0 VPDN call manage
  53   0          0          0      12892          0          0 SSS Manager
  54   0          0          0      12892          0          0 SSS Test Client
  55   0          0          0       6892          0          0 SSS Feature Mana
  56   0          0          0       6892          0          0 SSS Feature Time
  57   0        188        188       6892          0          0 PI MATM Aging Pr
  58   0       9084       1672      14304          0          0 VLAN Manager
  59   0        188        188       6892          0          0 EtherChnl
  60   0       2380        188       9084          0          0 DTP Protocol
  61   0          0          0      12892          0          0 TCP Timer
  62   0          0          0      12892          0          0 TCP Protocols
  63   0          0          0       6892          0          0 Socket Timers
  64   0       4056          0      13948          0          0 HTTP CORE
  65   0        188        188      12892          0          0 PPP IP Route
  66   0        188        188      12892          0          0 PPP IPCP
  67   0        136          0      10028          0          0 IP Background
  68   0        176          0      10068          0          0 IP RIB Update
  69   0        188        188       9892          0          0 Adj Manager
  70   0          0          0       6892          0          0 Asy FS Helper
  71   0          0          0       6892          0          0 RARP Input
  72   0      29804        188      22724          0          0 DHCPD Receive
  73   0          0          0       6892          0          0 IP Cache Ager
  74   0          0          0      24892          0          0 COPS
  75   0        188        188       6892          0          0 PPP Bind
  76   0          0          0       6892          0          0 PAD InCall
  77   0        188        188      12892          0          0 X.25 Background
  78   0        188        188       6892          0          0 RUDPV1 Main Proc
  79   0          0          0       6892          0          0 bsm_timers
  80   0          0          0       6892          0          0 bsm_xmt_proc
  81   0          0          0       6892          0          0 SNMP Timers
  82   0        188        188       6892          0          0 Dialer Forwarder
  83   0      74964       1440      73852          0          0 CEF process
  84   0        188        188       6892          0          0 PPP SSS
  85   0          0          0       9892          0          0 CES Client SVC R
  86   0    1054980        188    1054792          0          0 SCTP Main Proces
  87   0          0          0       6892          0          0 IUA Main Process
  88   0        188        188       6892          0          0 CRM_CALL_UPDATE_
  89   0        188        188       6892          0          0 LOCAL AAA
  90   0        188        188       6892          0          0 ENABLE AAA
  91   0        188        188       6892          0          0 LINE AAA
  92   0       2072        188    LUS
  93   0          0          0       6892          0          0 Key chain liveke
  95   0        436        188       7140          0          0 ASNL
  96   0      17596        188      24300          0          0 CCVPM_HDSPRM
  97   0        188        188       6892          0          0 HDA DSPRM MAIN
  98   0        188        188       6892          0          0 VSP_MGR
  99   0          0          0      24892          0          0 VoIP AAA
100   0       5444          0      12336          0          0 QOS_MODULE_MAIN
101   0        268          0      25160          0          0 RPMS_PROC_MAIN
102   0      79916          0      89808          0          0 CCVPM_HTSP
103   0       5472          0      12364          0          0 CCVPM_R2
104   0        328          0       7220          0          0 CCSWVOICE
105   0        324          0       7216          0          0 sssapp
106   0       1868          0       8760          0          0 http client proc
108   0        188        188       6892          0          0 AAA SEND STOP EV
109   0          0          0       6892          0          0 Syslog Traps
110   0          0          0       6892          0          0 PM Callback
111   0          0          0       6892          0          0 DHCPD Timer
112   0        188        188       3892          0          0 Inline Power
113   0          0          0       6892          0          0 trunk conditioni
114   0       1196          0       8088          0          0 trunk conditioni
115   0          0          0       6892          0          0 VPDN Scal
117   0        188        188       6892          0          0 fastblk backgrou
118   0        188          0       7080          0          0 DHCPD Database
119   0          0          0       9892          0          0 DHCP Client
121   0        152          0       7044          0          0 CEF Scanner
123   0        188        188      12892          0          0 PPP manager
124   0        188        188      12892          0          0 PPP Events
125   0        188        188       6892          0          0 Multilink PPP
126   0          0          0       6892          0          0 FR LMI
127   0          0          0       6892          0          0 FR Broadcast Out
128   0        188        188       6892          0          0 compute load per
129   0          0          0       6892          0          0 FR ARP
130   0         76          0       6968          0          0 FR TUNNEL
131   0          0          0       6892          0          0 FR FRAGMENTATION
132   0          0          0       6892          0          0 FRF9 manager
133   0          0          0       6892          0          0 FRF9 timed event
                                  6060344 Total
CPU utilization for five seconds: 1%/0%; one minute: 3%; five minutes: 1%
   1           0         2          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2           4      2482          1  0.00%  0.00%  0.00%   0 Load Meter
   3        3133        73      42917  0.71%  3.39%  0.95%   0 Exec
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5        7637      1474       5181  0.00%  0.04%  0.05%   0 Check heaps
   6           0         2          0  0.00%  0.00%  0.00%   0 Pool Manager
   8           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
   9           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  10           0       415          0  0.00%  0.00%  0.00%   0 Environmental mo
  11          48       354        135  0.00%  0.00%  0.00%   0 ARP Input
  12           0      3112          0  0.00%  0.00%  0.00%   0 HC Counter Timer
  13           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  14           4         2       2000  0.00%  0.00%  0.00%   0 Entity MIB API
  15           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  16           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  17           0     12406          0  0.00%  0.00%  0.00%   0 GraphIt
  18           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  19           0         2          0  0.00%  0.00%  0.00%   0 SMART
  20           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  21           8      3767          2  0.00%  0.00%  0.00%   0 Net Background
  22           4        52         76  0.00%  0.00%  0.00%   0 Logger
  23          16     12382          1  0.00%  0.00%  0.00%   0 TTY Background
  24           0     12454          0  0.00%  0.00%  0.00%   0 Per-Second Jobs
  25           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  26           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  27           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  28           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  29           0         1          0  0.00%  0.00%  0.00%   0 HDV background
  30           4         2       2000  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  31           0         1          0  0.00%  0.00%  0.00%   0 DSPFARM DSP READ
  32           0      2075          0  0.00%  0.00%  0.00%   0 mxt5100
  33           0         2          0  0.00%  0.00%  0.00%   0 ESWILPPM
  34           0         1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  35           0         1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
  36           0         1          0  0.00%  0.00%  0.00%   0 Net Input
  37           0      2483          0  0.00%  0.00%  0.00%   0 Compute load avg
  38        8297       209      39698  0.00%  0.04%  0.05%   0 Per-minute Jobs
  39           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  40           0         1          0  0.00%  0.00%  0.00%   0 AAL2CPS TIMER_CU
  41           0         5          0  0.00%  0.00%  0.00%   0 Service-module a
  42           0         2          0  0.00%  0.00%  0.00%   0 AAA Server
  43           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  44           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  45           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  46           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  47          68       332        204  0.00%  0.00%  0.00%   0 IP Input
  48           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  49          24      1475         16  0.00%  0.00%  0.00%   0 CDP Protocol
  50           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  52           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  53           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  54           0      1661          0  0.00%  0.00%  0.00%   0 SSS Test Client
  55           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  56           8     48632          0  0.00%  0.00%  0.00%   0 SSS Feature Time
  57           8     12389          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  58           4         2       2000  0.00%  0.00%  0.00%   0 VLAN Manager
  59           0      1242          0  0.00%  0.00%  0.00%   0 EtherChnl
  60           0         2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  61           0         1          0  0.00%  0.00%  0.00%   0 TCP Timer
  62           0         1          0  0.00%  0.00%  0.00%   0 TCP Protocols
  63           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
  64           0        43          0  0.00%  0.00%  0.00%   0 HTTP CORE
  65           4         2       2000  0.00%  0.00%  0.00%   0 PPP IP Route
  66           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  67         881       451       1953  0.00%  0.00%  0.00%   0 IP Background
  68          24        22       1090  0.00%  0.00%  0.00%   0 IP RIB Update
  69           0       208          0  0.00%  0.00%  0.00%   0 Adj Manager
  70           0         1          0  0.00%  0.00%  0.00%   0 Asy FS Helper
  71           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  72           4         2       2000  0.00%  0.00%  0.00%   0 DHCPD Receive
  73           0       208          0  0.00%  0.00%  0.00%   0 IP Cache Ager
  74           0         1          0  0.00%  0.00%  0.00%   0 COPS
  75           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
  76           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
  77           0         2          0  0.00% d
  78           8     12391          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
  79           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
  80           0     12432          0  0.00%  0.00%  0.00%   0 bsm_xmt_proc
  81           0         1          0  0.00%  0.00%  0.00%   0 SNMP Timers
  82           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
  83          28     18633          1  0.00%  0.00%  0.00%   0 CEF process
  84           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
  85           0         1          0  0.00%  0.00%  0.00%   0 CES Client SVC R
  86          68         2      34000  0.00%  0.00%  0.00%   0 SCTP Main Proces
  87           0         1          0  0.00%  0.00%  0.00%   0 IUA Main Process
  88           0       500          0  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
  89           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
  90           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
  91           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
  92           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
  93           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
  95           0         2          0  0.00%  0.00%  0.00%   0 ASNL
  96         104         2      52000  0.00%  0.00%  0.00%   0 CCVPM_HDSPRM
  97           0         4          0  0.00%  0.00%  0.00%   0 HDA DSPRM MAIN
  98           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
  99           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
100           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
101           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
102           4         1       4000  0.00%  0.00%  0.00%   0 CCVPM_HTSP
103           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
104           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
105           0         1          0  0.00%  0.00%  0.00%   0 sssapp
106           0         1          0  0.00%  0.00%  0.00%   0 http client proc
108           0         2          0  0.00%  0.00%  0.00%   0 AAA         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
110           0         1          0  0.00%  0.00%  0.00%   0 PM Callback
111           0       104          0  0.00%  0.00%  0.00%   0 DHCPD Timer
112           4     20653          0  0.00%  0.00%  0.00%   0 Inline Power
113          20     12412          1  0.00%  0.00%  0.00%   0 trunk conditioni
114           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
115           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
117           4    123916          0  0.00%  0.00%  0.00%   0 fastblk backgrou
118           0      3509          0  0.00%  0.00%  0.00%   0 DHCPD Database
119           0         3          0  0.00%  0.00%  0.00%   0 DHCP Client
121          52       432        120  0.00%  0.00%  0.00%   0 CEF Scanner
123           8    387861          0  0.00%  0.00%  0.00%   0 PPP manager
124          20    387861          0  0.00%  0.00%  0.00%   0 PPP Events
125           0     12396          0  0.00%  0.00%  0.00%   0 Multilink PPP
126           0         1          0  0.00%  0.00%  0.00%   0 FR LMI
127           4    124183          0  0.00%  0.00%  0.00%   0 FR Broadcast Out
128           4      2485          1  0.00%  0.00%  0.00%   0 compute load per
129           0         1          0  0.00%  0.00%  0.00%   0 FR ARP
130           0       623          0  0.00%  0.00%  0.00%   0 FR TUNNEL
131           0       208          0  0.00%  0.00%  0.00%   0 FR FRAGMENTATION
132           0         1          0  0.00%  0.00%  0.00%   0 FRF9 manager
133           0         1          0  0.00%  0.00%  0.00%   0 FRF9 timed event
Router   03:27:55 AM Monday Mar 1 1993 UTC
                11
    1     22222111113333377777     11111222227777711111
100
90
80
70
60
50
40
30                                     *****
20                                     **********
10                      *****          **********
             0    5    0    5    0    5    0    5    0    5
    1 1   1 1 1               1         1         1         1
100
90
80
70
60
50
40
30
20
             0    5    0    5    0    5    0    5    0    5
100
90
80
70
60
50
40
30   *
20   *
10   *
Slot 0:
PCB Serial Number        : FTX1033A2BA (979235078)
RMA History              : 00
Board Revision           : C0
Product (FRU) Number     : C2610XM-1FE
  0x00: 04 FF 40 03 6A 41 04 01 C1 17 46 54 58 31 30 33
  0x10: 33 41 32 42 41 20 28 39 37 39 32 33 35 30 37 38
  0x20: 29 82 49 1D FD 06 04 00 81 00 00 00 00 42 43 30
  0x30: 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Hardware revision 1.0         Board revision M0
Serial number     30081003  Part number    800-01514-01
FRU Part Number   WIC-1T=
Test history      0x0         RMA number     00-00-00
Connector type    Wan Module
  0x20: 01 02 01 00 01 CA FF EB 50 05 EA 01 00 00 00 00
  0x30: B0 00 00 00 03 02 20 01 FF FF FF FF FF FF FF FF
WIC Slot 1:
FT1 PMC4351
PCB Serial Number        : FOC100619C8
Board Revision           : A0
RMA History              : 00
  0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 30 30
  0x10: 36 31 39 43 38 82 49 20 9A 05 42 41 30 03 00 81
Interrupts:
    00  8051B548   00000000   Xilinx bridge error interrupt
    01  8049DC04   002F8997   MPC860 TIMER INTERRUPT
    02  8050F298   00001442   16552 Con/Aux Interrupt
    04  8051A08C   00000000   PA Network Management Int Handler
    05  8050C95C   00000000   Timeba8051A0DC   00000691   PA Network IO Int Handler
    07  8051A1A0   000000F4   MPC860 CPM INTERRUPT
IDMA Status:
Requests = 00000243  Drops                = 00000000
Complete = 00000243      Post Coalesce Frames = 00000243
Giant    = 00000000
PLD Status:
DIMM Slot 0:
DIMM Slot 1:
DIMM Type : EMPTY
------------------ show voice port ------------------
------------------ show dial-peer voice ------------------
------------------ show gateway ------------------
H.323 ITU-T Version: 4.0   H323 Stack Version: 0.1
H.323 service is up
This gateway  is not registered to any gatekeeper
Alias list (CLI configured) is empty
Alias list (last RCF) is empty
------------------ show call active voice ------------------
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 0
MGCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 0
------------------ show call history voice last 50 ------------------
------------------ show raw reclaimed ------------------
NAME: "2610XM chassis", DESCR: "2610XM chassis, Hw Serial#: FTX1033A2BA (979235078), Hw Revision: 0x401"
PID:                   , VID: 0x401, SN: FTX1033A2BA (979235078)
Region Manager:
0x80008098  0x81AC2A17    28027264  IText  R/O    main:text
0x81AC2A18  0x82A697EB    16412116  IData  R/W    main:data
0x829618FC  0x82A6978B     1080976  Local  R/W    data:firmware
0x82A697EC  0x82D6171F     3112756  IBss   R/W    main:bss
0x82D61720  0x87BFFFFF    82438368  Local  R/W    main:heap
Buffer elements:
     1119 in free list (1000 max allowed)
     3260 hits, 0 misses, 1119 created
     1533 hits, 0 misses, 0 trims, 0 created
Middle buffers, 600 bytes (total 25, permanent 25, peak 28 @ 03:27:06):
     25 in free list (10 min, 150 max allowed)
     174 hits,    0 failures (0 no memory)
     97 hits, 0 misses, 0 trims, 0 created
     0 hits, 0 fallbacks
Header pools:
Header buffers, 0 bytes (total 137, permanent 128, peak 137 @ 03:28:03):
Particle Clones:
     243 hits in cache, 0 misses in cache
9 Replies 9
Israel Logan
show arp and sh ip route are below.  The other devices connecting to it have been my laptop, an 1841 and 2610XM router.  all of those devices interacted with pings just fine.
I cleared counters, pinged again, and there was no change.
2610a#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.1.50            -   0013.1959.bc80  ARPA   FastEthernet0/0
2610a#ping 192.168.1.50
Sending 5, 100-byte ICMP Echos to 192.168.1.50, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
2610a#ping 192.168.1.100
Sending 5, 100-byte ICMP Echos to 192.168.1.100, timeout is 2 seconds:
Success rate is 0 percent (0/5)
2610a#sh ip route
Gateway of last resort is not set
C    172.31.0.0/16 is directly connected, Serial0/0
C    192.168.1.0/24 is directly connected, FastEthernet0/0
192.168.1.100 is my 1841 router and it's connected to f0/0 on a crossover ethernet cable.
the sh arp for the 1841:
1841#sh arp
Internet  172.16.10.2             -   2893.fe97.5422  ARPA   FastEthernet0/0
Internet  192.168.1.100           -   2893.fe97.5423  ARPA   FastEthernet0/1
1841#
the ping to .50 and .100's sh arp after the ping
1841#ping 192.168.1.50
1841#sh arp
Internet  192.168.1.50            0   Incomplete      ARPA
The view from the bad router again, can ping itself but not what it's connected to and the sh arp indicates that it doesn't even see a physical connection:
2610a#sh arp
Internet  192.168.1.100           0   Incomplete      ARPA
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Could you set the speed and duplex on both sides to 100/full and try again and if it fails can you try with another cable.
Regards.
Alain.
Hello Alain,
Actually, I would personally suggest going to the lowest possible technical demands, i.e. 10 Mbps, Half Duplex. Also, I would connect a PC directly to the router (using a verified crossover cable) and try to use Wireshark to see any frames being sent from the router. At least the LOOP, CDP and MOP frames should be sent every now and then (LOOP frames are sent roughly each 10s, CDP and MOP are sent every 60s). If absolutely nothing can be seen in the Wireshark even after configuring an IP address on the interface, perhaps even running a routing protocol on that interface that emits periodic Hello messages then I am afraid that the interface is fried.
Best regards,
Peter
Thanks Peter and Alain for the responses.  I'm off to work for now but look forward to testing settings and monitoring on Wireshark as you've suggested.  I'll report back.  Thanks again!
Okay, I've updated the laptop and suspected bad fa0/0 ports to 10 Mbps/Half Duplex, they are connected with x-over ethernet cable.  I've attached the wireshark capture file and text:
No.     Time           Source                Destination           Protocol Length Info
      1 0.000000000    Cisco_00:bc:80        Cisco_cc:cc:00        CDP      324     [ETHERNET FRAME CHECK SEQUENCE INCORRECT]
Frame 1: 324 bytes on wire (2592 bits), 324 bytes captured (2592 bits) on interface 0
IEEE 802.3 Ethernet
Logical-Link Control
Cisco Discovery Protocol
      2 4.059321000    Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 2: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Ethernet II, Src: Cisco_00:bc:80 (00:13:19:00:bc:80), Dst: AppliedD_59:bc:00 (00:00:19:59:bc:00)
Configuration Test Protocol (loopback)
Data (40 bytes)
0000  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................
0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   ................
0020  00 00 00 00 00 00 00 00                           ........
      3 14.093445000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 3: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
      4 24.091525000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 4: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
      5 34.091590000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 5: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
      6 37.207170000   AsustekC_65:d2:62     Broadcast             ARP      42     Who has 192.168.1.50?  Tell 192.168.1.10
Frame 6: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface 0
Ethernet II, Src: AsustekC_65:d2:62 (20:cf:30:65:d2:62), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Address Resolution Protocol (request)
      7 44.091765000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 7: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
      8 54.091765000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 8: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
      9 60.000439000   Cisco_00:bc:80        Cisco_cc:cc:00        CDP      324     [ETHERNET FRAME CHECK SEQUENCE INCORRECT]
Frame 9: 324 bytes on wire (2592 bits), 324 bytes captured (2592 bits) on interface 0
IEEE 802.3 Ethernet
     10 64.091868000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 10: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     11 64.209656000   AsustekC_65:d2:62     Broadcast             ARP      42     Who has 192.168.1.50?  Tell 192.168.1.10
Frame 11: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface 0
     12 65.205661000   AsustekC_65:d2:62     Broadcast             ARP      42     Who has 192.168.1.50?  Tell 192.168.1.10
Frame 12: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface 0
     13 66.205600000   AsustekC_65:d2:62     Broadcast             ARP      42     Who has 192.168.1.50?  Tell 192.168.1.10
Frame 13: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface 0
     14 74.126011000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 14: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     15 84.124056000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 15: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     16 90.618652000   Cisco_00:bc:80        ff:01:ff:ff:ff:01     IPv4     60     Bogus IP header length (0, must be at least 20)
Frame 16: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Ethernet II, Src: Cisco_00:bc:80 (00:13:19:00:bc:80), Dst: ff:01:ff:ff:ff:01 (ff:01:ff:ff:ff:01)
Internet Protocol Version 4
     17 92.621836000   Cisco_00:bc:80        ff:01:ff:ff:ff:01     IPv4     60     Bogus IP header length (0, must be at least 20)
Frame 17: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
     18 94.124110000   Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 18: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     19 94.621032000   Cisco_00:bc:80        ff:01:ff:ff:ff:01     IPv4     60     Bogus IP header length (0, must be at least 20)
Frame 19: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
     20 96.624315000   Cisco_00:bc:80        ff:01:ff:ff:ff:01     IPv4     60     Bogus IP header length (0, must be at least 20)
Frame 20: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
     21 98.627537000   Cisco_00:bc:80        ff:01:ff:ff:ff:01     IPv4     60     Bogus IP header length (0, must be at least 20)
Frame 21: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
     22 104.124358000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 22: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     23 114.124349000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 23: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     24 120.001005000  Cisco_00:bc:80        Cisco_cc:cc:00        CDP      324     [ETHERNET FRAME CHECK SEQUENCE INCORRECT]
Frame 24: 324 bytes on wire (2592 bits), 324 bytes captured (2592 bits) on interface 0
IEEE 802.3 Ethernet
     25 124.124371000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 25: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     26 127.202151000  AsustekC_65:d2:62     Broadcast             ARP      42     Who has 192.168.1.50?  Tell 192.168.1.10
Frame 26: 42 bytes on wire (336 bits), 42 bytes captured (336 bits) on interface 0
     27 134.158686000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 27: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     28 144.156679000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 28: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     29 154.156832000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 29: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     30 164.156830000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 30: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     31 174.157002000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 31: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     32 180.001455000  Cisco_00:bc:80        Cisco_cc:cc:00        CDP      324     [ETHERNET FRAME CHECK SEQUENCE INCORRECT]
Frame 32: 324 bytes on wire (2592 bits), 324 bytes captured (2592 bits) on interface 0
IEEE 802.3 Ethernet
     33 184.156931000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 33: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     34 194.191407000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 34: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     35 204.189213000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 35: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     36 210.722951000  fe80::a57c:48ea:1108:880c ff02::1:2             DHCPv6   140    Solicit XID: 0x96acdb CID: 00010001142b7601485d60357d00
Frame 36: 140 bytes on wire (1120 bits), 140 bytes captured (1120 bits) on interface 0
Ethernet II, Src: AsustekC_65:d2:62 (20:cf:30:65:d2:62), Dst: IPv6mcast_00:01:00:02 (33:33:00:01:00:02)
Internet Protocol Version 6, Src: fe80::a57c:48ea:1108:880c (fe80::a57c:48ea:1108:880c), Dst: ff02::1:2 (ff02::1:2)
User Datagram Protocol, Src Port: dhcpv6-client (546), Dst Port: dhcpv6-server (547)
DHCPv6
     37 211.717498000  fe80::a57c:48ea:1108:880c ff02::1:2             DHCPv6   140    Solicit XID: 0x96acdb CID: 00010001142b7601485d60357d00
Frame 37: 140 bytes on wire (1120 bits), 140 bytes captured (1120 bits) on interface 0
DHCPv6
     38 213.717340000  fe80::a57c:48ea:1108:880c ff02::1:2             DHCPv6   140    Solicit XID: 0x96acdb CID: 00010001142b7601485d60357d00
Frame 38: 140 bytes on wire (1120 bits), 140 bytes captured (1120 bits) on interface 0
DHCPv6
     39 214.189299000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 39: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     40 217.717097000  fe80::a57c:48ea:1108:880c ff02::1:2             DHCPv6   140    Solicit XID: 0x96acdb CID: 00010001142b7601485d60357d00
Frame 40: 140 bytes on wire (1120 bits), 140 bytes captured (1120 bits) on interface 0
DHCPv6
     41 224.189446000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 41: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     42 225.716713000  fe80::a57c:48ea:1108:880c ff02::1:2             DHCPv6   140    Solicit XID: 0x96acdb CID: 00010001142b7601485d60357d00
Frame 42: 140 bytes on wire (1120 bits), 140 bytes captured (1120 bits) on interface 0
DHCPv6
     43 234.189461000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 43: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     44 240.001960000  Cisco_00:bc:80        Cisco_cc:cc:00        CDP      324     [ETHERNET FRAME CHECK SEQUENCE INCORRECT]
Frame 44: 324 bytes on wire (2592 bits), 324 bytes captured (2592 bits) on interface 0
IEEE 802.3 Ethernet
     45 241.715835000  fe80::a57c:48ea:1108:880c ff02::1:2             DHCPv6   140    Solicit XID: 0x96acdb CID: 00010001142b7601485d60357d00
Frame 45: 140 bytes on wire (1120 bits), 140 bytes captured (1120 bits) on interface 0
DHCPv6
     46 244.189468000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 46: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     47 254.223603000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 47: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     48 264.221676000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 48: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     49 273.713997000  fe80::a57c:48ea:1108:880c ff02::1:2             DHCPv6   140    Solicit XID: 0x96acdb CID: 00010001142b7601485d60357d00
Frame 49: 140 bytes on wire (1120 bits), 140 bytes captured (1120 bits) on interface 0
DHCPv6
     50 274.221838000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 50: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     51 284.221999000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 51: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
     52 294.221996000  Cisco_00:bc:80        AppliedD_59:bc:00     LOOP     60     Reply
Frame 52: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Data (40 bytes)
alright, so I can see when I ping from the router it says "60 Bogus IP header length (0, must be at least 20)".  Saw some other thread talking about reducing MTUs to 1200... ?
Nevermind, tried to change it on the interface fa0/0 and it said "Interface FastEthernet0/0 does not support user settable mtu."
also did a mop enabled on the interface fa0/0 and mop sysid.  still see no MOP in wireshark.  Thinking the port is fried.  Anyone have good experiences with replacements from cablesandkits?
Cablesandkits was awesome with the replacement.  They sent it out and I had it next day.  Just printed the UPS label they sent me and will send the bad one back, no cost to me.  Plus I learned more about troubleshooting :-)  thx again for the help here.  Take care.
Hi Israel,
We actually did not help much, I am afraid. But I am glad to know that your device was replaced without unnecessary hassle. Thank you for letting us know!
Best regards,
Peter
