2620 Router (Getting started)
jsponseller
I have a Cisco 2620 router and need to configure it. I already have a WIC T1 card in the router and the T1 implemented. Can anyone provide guidance on how to go about setting up this router?
Jerry
6 Replies 6
Here's the link for 2600 configuration guide. This should contain all the info you need to configure the router.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_configuration_guide_book09186a008007e5e4.html
Sundar
Sundar,
Thanks for the information. I have a couple of scripts provided by my internet service provider. would you recommend modifying the T1 information and running it to configure the router?
Jerry
Absolutely, they probably provided you a base configuration. You can/should customize the configuration according to your needs.
Sundar
Sundar,
Thanks. I will try to use one of the provided scripts.
Jerry
swapniljain
Jerry,
U can also use the setup command, which will take you thru a configuration wizard, and will be easy for you to configure the router.
Swapnil
Swapnil,
Thanks for the information. I will take a look at the setup command as well.
Jerry
