Backup ISDN line is not firing
talha_490
here is the debug of Q931
00:06:53: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x2A
00:06:53: Bearer Capability i = 0x8890
00:06:53: Channel ID i = 0x83
00:06:53: Called Party Number i = 0x80, '17348017', Plan:Unknown, Type:Unknown
00:06:53: ISDN BR0/0: RX <- SETUP_ACK pd = 8 callref = 0xAA
00:06:53: Channel ID i = 0x89
00:06:53: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xAA
00:06:54: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xAA
00:06:54: Cause i = 0x829B - Destination out of order
00:06:54: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x2A
00:06:54: Cause i = 0x809B - Destination out of order
00:06:54: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x2B
00:06:54: Bearer Capability i = 0x8890
00:06:54: Channel ID i = 0x83
00:06:54: Called Party Number i = 0x80, '17348017', Plan:Unknown, Type:Unknown
00:06:55: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xAA
00:06:55: ISDN BR0/0: RX <- SETUP_ACK pd = 8 callref = 0xAB
00:06:55: Channel ID i = 0x8A
00:06:55: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xAB
00:06:56: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xAB
00:06:56: Cause i = 0x829B - Destination out of order
00:06:56: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x2B
00:06:56: Cause i = 0x809B - Destination out of order
00:06:57: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xAB
00:06:58: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x2C
00:06:58: Bearer Capability i = 0x8890
00:06:58: Channel ID i = 0x83
00:06:58: Called Party Number i = 0x80, '17348017', Plan:Unknown, Type:Unknown
00:06:58: ISDN BR0/0: RX <- SETUP_ACK pd = 8 callref = 0xAC
00:06:58: Channel ID i = 0x89
00:06:58: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xAC
00:07:00: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xAC
00:07:00: Cause i = 0x829B - Destination out of order
00:07:00: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x2C
00:07:00: Cause i = 0x809B - Destination out of order
00:07:00: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xAC
00:07:02: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x2D
00:07:02: Bearer Capability i = 0x8890
00:07:02: Channel ID i = 0x83
00:07:02: Called Party Number i = 0x80, '17348017', Plan:Unknown, Type:Unknown
00:07:02: ISDN BR0/0: RX <- SETUP_ACK pd = 8 callref = 0xAD
00:07:02: Channel ID i = 0x89
00:07:02: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xAD
00:07:04: ISDN BR0/0: RX <- DISCONNECT pd = 8 callref = 0xAD
00:07:04: Cause i = 0x829B - Destination out of order
00:07:04: ISDN BR0/0: TX -> RELEASE pd = 8 callref = 0x2D
00:07:04: Cause i = 0x809B - Destination out of order
00:07:04: ISDN BR0/0: RX <- RELEASE_COMP pd = 8 callref = 0xAD
00:07:05: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x2E
00:07:05: Bearer Capability i = 0x8890
smothuku
Level 7
Level 7
Hi Talha ,
The debug output is showing that destination is out of order.Check whether the configured destination number is working or not.
If possible paste the local and remote router configurations.
The following link helps you a lot in troubleshooting the problem.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_command_reference_chapter09186a008017cfa4.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_command_reference_chapter09186a008007ff75.html
satish
Danilo Dy
Looking at the logs, you capture this from the router that initiates the call right?
Look at you error cause and refer to this link http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
The first error cause is 00:06:54: Cause i = 0x829B - Destination out of order
The second error cause is 00:06:54: Cause i = 0x809B - Destination out of order
