06-16-2005 06:04 AM - edited 03-03-2019 09:49 AM
Hi all,
I have a 2621 with 4 serial interfaces. 1 interface, serial0/0 has always been down. s0/1, s1/0, and s1/1 have always been up. Testing with TelCo has now brought up s0/0, but now s0/1 is down.
I don't physically think there is a problem with the circuit. I suspect there is something else going on.
On the local side, when I sh ip int brief, the serial interface shows "up, down", but the remote side show "down, down".
When Telco loops back, or when I loop back the local or remote sides, I see the state change from "up, down" to "down down".
When I phyically remove the circuit, also see the state change from "up, down", to "down, down".
I see green connection "CD" light, although the WIC has an amber light and is in alarm "AL".
Has anyone seen this problem on image c2600-ipbase-mz.123-6.bin? Or anyone know of problems with a 2621 with for T1 WICs/serial interfaces?
Any help or ideas would be appreciated.
Many thanks,
Warren
06-16-2005 06:08 AM
Also, the down s0/1 in question, will flap up and down throughout the day. Traffic was traversing this interface just fine, but now is down, and shows output packets, but only input errors, no input packets (presently admin down'd):
Serial0/1 is administratively down, line protocol is down
Hardware is PQUICC with Fractional T1 CSU/DSU
Description: Circuit ID: DHZA540606
Internet address is 10.1.252.129/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 248/255, txload 1/255, rxload 1/255
Encapsulation PPP, LCP Closed, loopback not set
Last input 02:41:40, output 01:00:31, output hang never
Last clearing of "show interface" counters 01:09:07
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 558 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
8794690 input errors, 69 CRC, 5616308 frame, 0 overrun, 0 ignored, 3178313 abort
30 packets output, 420 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
0 carrier transitions
DCD=up DSR=up DTR=down RTS=down CTS=up
Thanks all,
Warren
