2629xm -vwic2
john.w.hart
Will a Vwic2-1mft-703 card in slot 1 of a 2620XM work at this time the router is running c2600-advipservicesk9-mz.123-19a? What ios is needed? - we normal run the 19a range
Richard Burts
John
I found a document on the Cisco web site which identifies the minimum release required to support this card on 2600XM as being 12.2(8)T. So I believe that you are good with your 12.3(19a).
If you want to see details here is the link to the document:
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps259_Products_Data_Sheet.html
Rick
Rick
