2651XM unable to create pri-group
m.ateeque
hello all, im unable to create pri-group unter T1 controllers in 2651xm , I have 3 T1 VWIC controller cards [dual port], tried using differnt IOS [advance enterprise/IPVoice/SPservices], i can onyl see channel-group unter the controllers.
network-clock-particiapte slot 1
network-clock-participate wic 0
i havent added "isdn switch type", does addign these command enables the Pri-group, also wheni do sh inv, i see 3 pvdms, but no serail number,
appreciate help
6 Replies 6
mavespig
Level 3
Level 3
hi,
can you post here a show inventory and show diag?
Not all cards can support pri-group, those commands will clarify which cards you are using, and also if the router recognized them
Marco
Hi marco, thanks for the reply, please see below the sh diag, im tryign tosetup a PSTN for my voicelab,
thanks for your help.
PSTN#sh diag
Slot 0:
C2651XM 2FE Mainboard Port adapter, 4 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision        : 1.0
PCB Serial Number        : FFFF
Part Number              : 73-7756-02
RMA History              : 00
RMA Number               : 0-0-0-0
Board Revision           : D0
Deviation Number         : 0-0
Product (FRU) Number     : C2651XM-2FE
EEPROM format version 4
EEPROM contents (hex):
   0x00: 04 FF 40 03 6F 41 01 00 C1 0B FF FF FF FF 46 46
   0x10: 46 46 FF FF FF 82 49 1E 4C 02 04 00 81 00 00 00
   0x20: 00 42 44 30 80 00 00 00 00 FF FF FF FF FF FF FF
   0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
   0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
T1 (2 port) Multi-Flex Trunk (Drop&Insert) WAN daughter card
Hardware revision 1.0          Board revision B0
Serial number     28184225   Part number    800-04614-03
FRU Part Number     VWIC-2MFT-T1-DI=
Test history      0x0          RMA number     00-00-00
Connector type    PCI
EEPROM format version 1
   0x20: 01 24 01 00 01 AE 0E A1 50 12 06 03 00 00 00 00
   0x30: 58 00 00 00 02 05 31 00 FF FF FF FF FF FF FF FF
WIC Slot 1:
T1 (2 port)
Multi-Flex Trunk WAN daughter card
Serial number     34602219   Part number    800-04477-04
FRU Part Number     VWIC-2MFT-T1=
Connector type    PCI
   0x20: 01 22 01 00 02 0F FC EB 50 11 7D 04 00 00 00 00
  0x30: 58 00 00 00 06 04 25 00 FF FF FF FF FF FF FF FF
Slot 1:
High Density Voice Port adapter
Hardware Revision        : 1.1
Top Assy. Part Number    : 800-03567-01
Board Revision           : G0
Fab Version              : 02
PCB Serial Number        : JAE07430E5D
RMA Test History         : 00
RMA History              : 00
Product (FRU) Number     : NM-HDV=
   0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
   0x10: 42 47 30 80 00 00 00 00 02 02 C1 8B 4A 41 45 30
   0x20: 37 34 33 30 45 35 44 03 00 81 00 00 00 00 04 00
HDV SIMMs: Product (FRU) Number: PVDM-12=
  SIMM slot 0: PVDM-12 SIMM present.
  SIMM slot 1: PVDM-12 SIMM present.
  SIMM slot 2: PVDM-12 SIMM present.
  SIMM slot 3: PVDM-12 SIMM present.
  SIMM slot 4: Empty.
VIC Slot 0:
T1 (2 Port)
Multi-Flex Trunk WAN Daughter Card
Serial number     34725256   Part number    800-04477-04
           Connector type    PCI
   0x20: 01 22 01 00 02 11 DD 88 50 11 7D 04 00 00 00 00
   0x30: 58 00 00 00 06 04 18 00 FF FF FF FF FF FF FF FF
HDV firmware: Compiled Fri 19-Nov-04 14:23 by michen
HDV memory size 524280 heap free 193977
PSTN#sh run
Building configuration...
Current configuration : 987 bytes
version 12.4
no service pad
no service timestamps debug uptime
no service timestamps log uptime
hostname PSTN
boot-start-marker
boot-end-marker
enable secret 5 $1$aDIw$gkzo/JNSavdCwFVDIvPqb/
no aaa new-model
clock timezone CST -6
clock summer-time CST recurring
network-clock-participate slot 1
voice-card 1
controller T1 0/0
framing sf
linecode ami
controller T1 0/1
framing sf
linecode ami
controller T1 0/2
framing sf
linecode ami
controller T1 0/3
framing sf
linecode ami
controller T1 1/0
framing sf
linecode ami
controller T1 1/1
framing sf
linecode ami
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
PSTN#
These T1 cards can support both data and voice, see this doc for reference:
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps259_Products_Data_Sheet.html
After you configure isdn switch-type in global config, you should be able to see the pri-group option under the controllers.
Can you please follow these configuration steps, and capture the logs when you are typing the commands?
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htpvdm2.html#wp1088585
Marco
Marco, thanks for the docs... i did add the following to router last night and it didn't madenay differnce still imunabel to see the PRI-Group under the T1 controllers.
network-clock-partiicapte
network-clock-select
isdn swtich-type primary-ni
saveconfig reload router, still no luck....[im thinkign of write erase and reload the IOS to see if that makes any differnce]
Hi, I'm not sure I understand correctly what you mean, can you please past the log of what you are configuring?
Do you see the pri-group option or not?
Primary-ni is used only in U.S., are you sure it's the one you need? Europe and most of the other countries use primary-net5.
In the log, please try the following:
Type "controller T1 0/0" and press enter.
Type "pri-group " and press question mark.
basically imtryig to setup [emulate] PSTN usign cisco 2651XM, im using 3 VWIC 2MFT cards [dual ports] previsouly these router was used as voice gateway, the guys who sold me showed the config before erasing it, clearly he had the pri-group setup, in his case he was using single port t1 cards on 2 slots, the differenceis im usign 3 dual port T1 cards, initally i have installed advance enterprise IOS tried configurig the router, sicne the ios is ver 12.4 (25)  and the cards are T1 only so i dont have to type "card-type" etc.  next step i tried ios ipservices etc. still no luck
i can see all 6 T1 contollers, on global config i have selected the network-clock particiapte / network-clock-select sicne i'm in us i did selelct the switch-type primary ni.
i can configure channel-group not the PRI,  [ please check my previous post for config]  so my question is how do you setup 2651xm for PSTN to support 3 test site for WAN/PRI
