linking atm0 to ethernet0
zombiecrab
Hi I have been trying to configure a 837 for a while now and I'm finally nearly there. So far the tests run(SDM interface test) and pass on atm0(WAN connection to the internet) but not on ethernet0. I am guessing i need to link them somehow but since I don't know the terminology searching for how to do it is turning out to be difficult.
Here is my config:
!This is the running config of the router: 192.168.0.1
!version 12.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$j4/M$/YkFiP.GPRtivQdLd.2wE1
username alex privilege 15 password 0 password1
no aaa new-model
ip subnet-zero
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ips po max-events 100
no ftp-server write-enable
interface Ethernet0
description ethernet
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname #########3@adsl.virgin.net
ppp chap password 0 samsung905
ppp pap sent-username ########@adsl.virgin.net password 0 ##########
ppp ipcp mask request
ppp ipcp route default
ppp ipcp address accept
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 ATM0
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
control-plane
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
I tried ip route 0.0.0.0 0.0.0.0 Dialer0 first with no luck to i added the ip route 0.0.0.0 0.0.0.0 ATM0 still nothing
Any suggestions are appreciated.
8 Replies 8
manish arora
Level 6
Level 6
Hey Alex,
Few changes :-
1> router(config)# access-list 1 permit 192.168.0.0 0.0.0.255
2> router(config)#int atm 0
                        #no ip nat outside
                        #exit
3> router(config)#int dialer 0
                       #ip nat outside
                       #ip mtu 1492
                       #exit
4> you need just one default route out of dialer 0 so ,
router(config)# no ip route 0.0.0.0 0.0.0.0 ATM0
5> router# wr
Manish
No luck sorry
here is what SDM is outputting:
ethernet0:
checking exit interface...               Failed
     exit interfae found: Dialer0
Failure Reasons
To test connectivity, SDM tries to ping the configured DNS servers. Howesver, there is no configured route to any of the DNS servers through the selected interface.
Recommended Actions
Select 'User-specified' option or add a 'host specific/network specific/default' route through this interface and retest connection.
My bad dude ,
The ip nat outside stays under atm 0 , so please change it back :-
                   # no ip nat outside
                   #exit
                   #int atm 0
                  # ip nat outside
                 # exit
Nope sorry same result. ATM0 passes and ethernet0 faills in the same place.
I wouldn't worry about what SDM says , Just connect a laptop/pc with eth0 and give an ip
address 192.168.0.10 , 255.255.255.0 gateway 192.168.0.1 , test connectivity.
or try extended ping from the router.
Manish
Sorry about the wait, it's been hectic at work.
I hooked up the lan cable and was able to communicate with the router but not able to connect to the internet.
I have fiddled with the config a bit so I'll post the changes(differences are in bold):
!version 12.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
username alex privilege 15 password 0 ########
no aaa new-model
ip subnet-zero
interface Ethernet0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
pvc 0/38
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface Dialer0
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname ####################
ppp chap password 0 ###################
ppp pap sent-username alex.wood3@adsl.virgin.net password 0 ################
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
Humm I though I changed more then that but notepad++ disagrees.
Anyway. Can you see anything that would be preventing it from connecting the two interfaces?
I really apriciate the help you have given me.
Hi Alex,
Can you please do the following :-
interface Ethernet0
ip tcp adjust-mss 1452
interface Dialer0
ip mtu 1492
Rest of the configuration looks good to me. Please post output of "sh version" if you still have issues.
Manish
Sorry no luck. Ping from computer connected to router didn't work neither did the SDM connection test from ethernet0 but the connection test from ATM0 did work as usaual.
Here is the output you asked for:
Router#sh version
Cisco IOS Software, C837 Software (C837-K9O3SY6-M), Version 12.3(8)YG, RELEASE S                                             OFTWARE (fc1)
Synched to technology version 12.3(10.3)T2
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Fri 17-Dec-04 17:01 by ealyon
ROM: System Bootstrap, Version 12.2(11r)YV1, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, C837 Software (C837-K9O3SY6-M), Version 12.3(8)YG, RELE                                             ASE SOFTWARE (fc1)
Router uptime is 5 minutes
System image file is "flash:c837-k9o3sy6-mz.123-8.YG.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C837 (MPC857DSL) processor (revision 0x501) with 44237K/4915K bytes of memory.
Processor board ID FCZ091043L1 (3846568980), with hardware revision 0000
CPU rev number 7
2 Ethernet interfaces
4 FastEthernet interfaces
1 ATM interface
128K bytes of NVRAM.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Router#
Sorry for the late responce I was stuck in Wales due to a train strike.
