2800 speed issue
vishwancc
Level 3
Level 3
Hi ALL:
When i am connnecting my laptop to the MUX ethernet prot i am getting the download speed of 450-500 KB/s
But when i am connecting the MUX to the 2800 router and then connecting my laptop to ethernet port of router i am only 230KB/s.
While i am doing this there is no LAN connection to be sure that no one else is using the bandwidth, also there is only default config on the router no access-list etc.
I have tried all possible speed and duplex combinations.
Could any one suggest why is this happening,or is this something to do with 2800?
satish_zanjurne
Level 4
Level 4
Terminate the link from MUX to switch.
Connect your laptop to the switch, then see what speed you are getting ???
